Finally a fix from Toyota for Stumble condition (TSB 0062-18)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by AWDDude, Jul 19, 2018.
  1. Sep 21, 2018 at 5:56 AM
    #2081
    GMP
    GMP Well-Known Member
    Glenn
    2018 DCSB TRD OR Quicksand
    The biggest issue with D for me is the upshift to 6th on a 45-50 mph road, and then back down at the first small hill. S5 eliminates that. Just moving that 6th threshold up a lot higher would make it really good. FWIW, I'm a software engineer. The new calibration in firmware almost certainly does not revert. The variables in the program that are permitted to change within limits (learning, self tuning) may but the code no. Also, remember that whatever they may do in the future must be bound to EPA requirements, so somewhat limited there. As Moondog stated, this is the new age of ATs. My nephew has a Jeep GC with an 8 speed that has been reflashed and still has issues. My wife's Pilot has that system that shuts down 3 cyls., and when you hit the gas they come back on along with a converter unlock and downshift, its a much rougher delay than the Tacoma. Personally I'm just so used to driving V8 Tundras since 2001 everything might just seem worse than it actually is.
    Comato$e and rosebud like this.
  2. Sep 21, 2018 at 5:58 AM
    #2082
    BlackdogGS
    BlackdogGS Well-Known Member
    This is my experience also. Even going 65-70mph the transmission is constantly shifting between 4th and 6th. This is with an empty truck. I can’t imagine towing anything. I need to either re -gear to 4:30 or install the OV Tune. I’m pretty sure both would void my warranty.
  3. Sep 21, 2018 at 6:23 AM
    #2083
    bCaff
    bCaff Well-Known Member
    Brian
    2017 Tacoma TRD OR DCSB
    Just got the updated calibration this morning at Fred Anderson Toyota in Raleigh. My service adviser Chris was excellent. He listened to my concerns and told me that they would perform a health check for software updates on the ECU. Normally I wait to do this sort of thing at my 5,000 mile service intervals but went in at 12,500 miles since most people were having so much improvement. My visit took about 1.5 hours but I was also having them test drive for the rear diff whine issue.
    Will wait to see if the update helps. I already had the 0300 calibration before this visit so I'm not expecting as large of an improvement as others with the 0100 or 0200 calibrations. During the short drive home I think the truck was still figuring things out as part of the fresh ECU reset hopefully it will settle down and learn good habits throughout the day today.
    Tibetan Nomad likes this.
  4. Sep 21, 2018 at 6:36 AM
    #2084
    Tibetan Nomad
    Tibetan Nomad Well-Known Member
    2016TRDOR:DCLB:JBL
    NitroGear5.29,B6112,.25"spcr,SPC:UCA,Diff-drop,ECGS
    B5160,Dakar-HD-leaf-pk+OL,UBolt-Flip,33s,Superbumps
    So since I’m fresh off of ECU flash, what if i start driving fast/quick. Would the ECU learn based off of that and keep as much of the new uodated feel as possible?
    Maybe not a solution..since it continues to learn i guess..
  5. Sep 21, 2018 at 6:44 AM
    #2085
    tater taco
    tater taco no it all
    Todd
    ground zero of the zombie apocalypse
    2016 ACLB TRD OR Quicksand OV Tuned 2.0 (91)
    OVTuned, decatted dump tubes
    OVTune is undetectable at a dealer, your Cal ID will still show a factory flash code.
    not sure how the 4.30 gear would effect your warrenty, adain, I doubt they could even detect the change at a dealership.
  6. Sep 21, 2018 at 7:46 AM
    #2086
    ChrisK7UND
    ChrisK7UND Well-Known Member
    Colorado
    2017 Tacoma TRD Sport Double-Cab
    LED Interior Bulbs, Hondo Garage Phone Mount, Tacoma Bed Mat
    Not sure I follow. I had the original one done a year ago that fixed some shifting issues and that CAL ID ended in .......0300. The new one ends in ......0400. They gave me a before and after report from the Techstream.
  7. Sep 21, 2018 at 8:19 AM
    #2087
    The Real Moondog
    The Real Moondog Well-Known Member
    Moondog
    Somewhere in the SE USA
    2017 Quicksand Tacoma TRD Off-Road (Sold :()
    Yes, my mileage got much better after the learning period.
    rosebud[QUOTED] likes this.
  8. Sep 21, 2018 at 8:23 AM
    #2088
    MtnLessGoat
    MtnLessGoat Well-Known Member
    So. FL
    The Warthog - 2018 TRD OR DCSB in Cement
    i just called my local dealer and left a message. i wonder if they will have any issues/excuses applying the update due to the truck having CAI and Catback installed...again my local dealer are a bunch of scumbags. lets see.
  9. Sep 21, 2018 at 9:10 AM
    #2089
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    Ignore that post. I'm a big dummy sometimes.
  10. Sep 21, 2018 at 10:10 AM
    #2090
    NMTrailRider
    NMTrailRider Well-Known Member
    New Mexico
    Nah just drive like you normaly would. You're not gonna "beat" this system. We really don't even know how it works for sure. Some guys will tell you to drive like you stole it for 2k miles to teach it who you are. I'm not on that bandwagon. In the end, I just don't think it matters.
  11. Sep 21, 2018 at 10:38 AM
    #2091
    Bubbabow
    Bubbabow Member
    Jim
    TRD PRO
    You answered this before for me about the ECT having same effect in S mode as D. But what I am confuse by is someone posted that the ECT learns just like D. So if that is true what overrides when you have ECT on in S mode which has no learning mode not sure then if learning is off or in?
  12. Sep 21, 2018 at 11:16 AM
    #2092
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    Need to understand the design of this ECU.
    Whatever you do, ECU will stay within its modeled range. ECU calculates user's input (pushing pedal for more power, etc.) and checks against the model. If you power, torque, etc. are exceeding predicted model, ECU limits those inputs.
    Read up on OVtunes explanations.
    Tibetan Nomad[QUOTED] likes this.
  13. Sep 21, 2018 at 11:28 AM
    #2093
    rosebud
    rosebud Love that transmission!
    SE Texas
    2017 TRD OR
    Stock suspension, stock wheels, stock bumper, stock, stock, stock, dammit!
    I just got a shock! I drove it like I normally do and got 21.6mpg!! WTF??? I'll take it! Damn!
    StayinStock and Lt. Dangle like this.
  14. Sep 21, 2018 at 11:33 AM
    #2094
    Lt. Dangle
    Ohio
    I am unaware of ECT learning. I do know ECT changes the throttle mapping and shift points though.
    StayinStock likes this.
  15. Sep 21, 2018 at 11:35 AM
    #2095
    slowboater
    slowboater Well-Known Member
    I'm picking up the truck in the next few minutes. The guy a the desk of the service department of Jim Pattison (Vancouver BC) was a little bit of a pain - telling me that I would have to have a drive with the service manager in order for him to see the problem. I politely asked him if he was going to drive over the mountain pass with me in order to replicate the problem. He was a bit persnickity but said the manager would ride with me.
    I said 'sure' 'no problem'.
    5 minutes later the manager came over and said they'll take it in. He knew there were already 3 updates since I bought the truck - even told me that the most recent one was released on July 31 (Canada).
    I'll report after I drive it to Kamloops over the Coquihalla this afternoon.
    Loaded NightraiN likes this.
  16. Sep 21, 2018 at 11:50 AM
    #2096
    Bubbabow
    Bubbabow Member
    Jim
    TRD PRO
    Thanks that answers it I have switched it on and off (ECT) in s mode with it on the throttle is notably increased. It even burnt rubber from a stop light with both S and ECT on which I never try to do. It caught me by surprise thanks for the thoughts on this
  17. Sep 21, 2018 at 12:05 PM
    #2097
    Loaded NightraiN
    Loaded NightraiN Well-Known Member
    17 TRD Off Road
    Sitting at the dealership now, with my truck in the bay.
    Just wanna be clear my new Cal ID should be "8966304B0400" correct?
  18. Sep 21, 2018 at 12:14 PM
    #2098
    HelloMyNameIs
    HelloMyNameIs I know words, I have the best words.
    2018 TRD Off Road in Cement
    OME 2885, Billie 5100s, HS Prog AAL, 255/85r16 Cooper ST Maxxs
    Just bought my truck less than two weeks ago and my Cal ID is 896630A6000. Based on that can anyone tell me how out of date the ECU is?
    Trying to understand all of this. Thanks!
  19. Sep 21, 2018 at 12:18 PM
    #2099
    AMOORE_93
    AMOORE_93 Well-Known Member
    Richmond, va
    2016 Tacoma 4x4 Offroad
    Just had the TSB done. Holy Crap!! What a difference. No more surging and gear hunting. Like butter now. :bikewhoops:
  20. Sep 21, 2018 at 12:28 PM
    #2100
    Kryptonite0106
    Kryptonite0106 Well-Known Member
    2018 TRD Sport access cab
    You have the calibration before the newest update which is 896630A6100 for the 18s.
