Finally a fix from Toyota for Stumble condition (TSB 0062-18)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by AWDDude, Jul 19, 2018.
  1. Oct 19, 2018 at 4:54 AM
    #2521
    Fitzwilly
    Fitzwilly Well-Known Member
    Bill
    South Central Mass
    2018 JKU "Golden Eagle" Edition
    At the dealership with my 4800 mi 18 now and they’re questioning the shit out of my complaint of stumble. Made the master tech take a ride to “replicate”. Anyone else getting as much hassle?
  2. Oct 19, 2018 at 5:13 AM
    #2522
    mlr69
    mlr69 I had a savings account before I joined TW
    South Carolina
    2018 TRD Sport 4x4 DCSB
    2" ToyTec/Eibach Pro Sport Lift Kit -SparksParts.com 3/4" ToyTec Front Top Plate Spacer Kit -SparksParts.com SPC Performance Upper Control Arms -SparksParts.com Nitto Ridge Grapplers 285/75/17 (34") -SparksParts.com 1.25" Spidertrax Wheel Spacers -SparksParts.com Hypertech Speedometer Calibrator -hypertech.com Predator Tube Steps -SparksParts.com BAKFlip G2 Tonneau -SparksParts.com OEM Rubber Bed Mat -SparksParts.com OEM All-weather Floor Liners -SparksParts.com Gentex Frameless Mirror with Homelink @RJP869 Subaru/Kicker Tweeters -amazon.com Kicker Door Speakers (x4) -crutchfield.com Radio Knobs @Tacowiede Vehicle OCD Glove Box Organizer -amazon.com ‎JoyTutus Center Console Tray -amazon.com FormulaOne Pinnacle Window Tint -SparksParts.com ACDF Horn Kit @BartMaster1234 Total Tail Light S1 Kit @MESO ECT Button Relocation Kit @Tacowiede Minimalist Key Fobs @MESO Ultimate Map & Dome Lights @MESO Fortin EVO-ALL Remote Start w/Cell Module @jmeitz Coin Bucket with Lid @MESO GermesLab Camera Control System @FreshMexicanTaco Natika Front View Camera -amazon.com VLEDS LP Reverse Light System -vleds.com LIFTd Customs Fuel Cap Cradle @JIMMEISTER OEM Power Tailgate Lock -SparksParts.com OEM 2022 Limited Grille -SparksParts.com OEM 2022 Limited LED Headlamps -SparksParts.com LED Headlight Conversion Harness @daveeasa Headlight Trim Plates @MESO OEM Door Sill Protectors -SparksParts.com Diode Dynamics Elite Fog Lights @memario1214 Fog Light Backlighting PNP Harness @daveeasa
    Can I assume you haven't read the previous 2500 posts in this thread? LOL Yes, lots of push-back from some dealers. The consensus seems to be either call Toyota corporate to complain about that dealership or go to a different dealership.
  3. Oct 19, 2018 at 6:20 AM
    #2523
    Fitzwilly
    Bill
    South Central Mass
    TLDR
    I browsed through. I had a ‘17 for 2 years before the lease was up and got the 18. I had absolutely no problem with TSB reflashes when I took that one in. The tech acknowledged the stumble and said he’d look into a software update.
  4. Oct 19, 2018 at 7:13 AM
    #2524
    YMMPRO
    YMMPRO Well-Known Member
    Northern Alberta, Canada
    2018 Super White Tacoma Pro
    TRD Intake / Falken Wildpeak AT3W
    Thanks, could you screenshot the work order, just so i have something to show to the service guy as they say TSB # are diffrent in Canada? Thanks
  5. Oct 19, 2018 at 9:33 AM
    #2525
    weretaco
    weretaco Well-Known Member
    2018 Cement Grey TRD-Sport
    Had my 2018 done yesterday at Destination Toyota in Burnaby, BC. Service adviser didn't even blink when i told him I wanted the update. He said he's had at least a few 2018s in for it. In my case I wanted them to try it since I've been doing some drives up long hills and it wants to hold the lower gear for far too long (especially bad with cruise control on). It'll sit at 5000+rpm with no need as when it finally shifts up it has ample power at the rpm range it's at to maintain speed.
    I definitely noticed the change on my way home yesterday. There is a highway on ramp I go over every day commuting and previously right at the spot i needed to speed up it always seemed to be lacking in power at the gear it was in (maybe the stumble condition range?). This time it just cruised right through it with no issue getting quickly up to merge speed.
  6. Oct 19, 2018 at 10:11 AM
    #2526
    Matusik1
    Matusik1 Active Member
    Kerri
    Calgary, AB Canada
    2018 Tacoma Sport
    Here ya go!
    YMMPRO[QUOTED] likes this.
  7. Oct 19, 2018 at 10:23 AM
    #2527
    weretaco
    If you have an ODBII reader you can check the current ID to see if it's been updated.
    It'll show 8966304A6100 as the calibration ID if it's current for a 2018.
    CorpsTaco likes this.
  8. Oct 19, 2018 at 10:44 AM
    #2528
    weretaco
    Might be worth grabbing a reader for future use. < $20 and handy to be able to read codes at home on a variety of vehicles.
    https://www.amazon.com/dp/B011NSX27A if you have an Android phone
    https://www.amazon.com/dp/B00WPW6BAE to support IOS as well.
    mlr69 and CorpsTaco[QUOTED] like this.
  9. Oct 19, 2018 at 11:25 AM
    #2529
    NMTrailRider
    NMTrailRider Well-Known Member
    New Mexico
    Can you make settings changes with this (ex. Seatbelt chime) or just read codes?
  10. Oct 19, 2018 at 11:26 AM
    #2530
    NMTrailRider
    New Mexico
    There are many of us feeling the same way as you. Regrets here big time. Mine was built after the ECU update was published and it did NOT have the latest software. You should get it done.
  11. Oct 19, 2018 at 11:29 AM
    #2531
    mlr69
    South Carolina
    It's just a reader.
    NMTrailRider[QUOTED] likes this.
  12. Oct 19, 2018 at 11:34 AM
    #2532
    Rodchester
    Rodchester Well-Known Member
    Baton Rouge
    2017 Quicksand SR5 DCSB V6
    Weather tech mats, LED interior lights and reverse lights, tube steps, bed extender, bed mat, folding bed cover, TRD Pro grill, blacked out badges and wheel center caps. Kicker speakers(all 6). Front bed rail header. Under hood LEDs. Tufskinz door and interior foam inserts. Chrome interior door handles. Fumoto drain valve. Aluminum oil filter canister. Rear view mirror with Homelink. Quick charge USB charging ports. TRD badge on grill. MESO fuse box cover. Redline Tuning hood struts. Ceramic coating. Pop & Lock auto tailgate lock. LED bed lights. Lower bumper LED light that bar. MESO coin holder. TRD cat back exhaust. Hikari Ultra LEDs high and low beams. 2020 TRD Sport wheels and TRD center caps. RSC Nano dashcam. DSM from the Taco Garage. Blue Sea dual USB outlet on back of center console. KDMax7.0
    Look at the ads on the bottom of the page.
    CorpsTaco[QUOTED] likes this.
  13. Oct 19, 2018 at 12:14 PM
    #2533
    VMVIWI
    VMVIWI 2018 TRD Off-Road Cement Grey
    Tawaitai
    Hawaii
    ***Taking delivery 10/10/18*** 2018 Tacoma TRD Off-Road, Cement Grey.
    BILSTEIN 6112/5160, TRD Pro-Grill, TRD PRO Tacoma Wheels (Replica) 17x8, LED light-upgrade headlight, tail-light & interior. Black-out emblems, Black tail-gate raised letters, TRD shift-knob. ***I absolutely hate hub-caps***
  14. Oct 19, 2018 at 2:04 PM
    #2534
    Rodchester
    Baton Rouge
    It’s what you can plug into the “computer port” on your vehicle and see all kinds of info. There are a couple of them advertised on the bottom of the page you’re looking at.
  15. Oct 19, 2018 at 4:45 PM
    #2535
    2006Jackpot
    2006Jackpot Well-Known Member
    Indiana
    Carver finally got the parts in this week.... had both done today noticed shifting improvement when going up a slight incline it will now just down shift one gear to 5th instead of holding 6th too long and then dropping all the way down to 4th. Can't say much more yet but I see an improvement so far
    I can still find the howl but not near as noticeable.
    I worked with Ruth Miller Asst. Service Manager - she was great. She told me after it was done that they have had some Tacoma's that the ECU flash didn't stay and they have had to open cases with Toyota on those trucks. She was very open about telling me to pay close attention to it and call if it should start to show the weird shifting again.
    Very pleased as this was my first experience with them - won't be my last!
  16. Oct 19, 2018 at 5:24 PM
    #2536
    NMTrailRider
    New Mexico
    ECU flash didn't stay? I don't think that's possible.
  17. Oct 19, 2018 at 5:26 PM
    #2537
    2006Jackpot
    Indiana
    Yeah me either - but maybe she meant it reverts back to being the same condition as before like others have stated here. Hope I don't have to find out.....
  18. Oct 21, 2018 at 6:02 PM
    #2538
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    It will revert back..
    I had to disconnect the battery to get it reset.
    Truck feels as it was after tsb.
    Will try to drive in S until 1.05 release
  19. Oct 21, 2018 at 7:07 PM
    #2539
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    I'm gonna say something that goes against the conventional wisdom around here...
    My tsb specifically mentioned and adressed the hesitation from a stop. It never said anything about the surge. I find it very hard to believe Toyota released a TSB addressing all these issues covered by a single TSB. I know the calibration numbers are the same, but I just can't see one TSB fixing all the issues at once.
    Anyways, my truck is at the body shop getting rust fixed, so I have moved on to other issues lol.
  20. Oct 21, 2018 at 9:16 PM
    #2540
    NMTrailRider
    New Mexico
    Were you the one with rust on the door sill?
