Finally a fix from Toyota for Stumble condition (TSB 0062-18)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by AWDDude, Jul 19, 2018.
  1. Nov 2, 2018 at 6:17 AM
    #2661
    dangeroso
    dangeroso Just float along and fill your lungs
    Jon
    Dallas, TX
    2018 Tacoma TRD Sport 4x4
    I'm in for my 2nd try. First dealer wouldn't do it because they couldn't duplicate the problem. We will see.
  2. Nov 2, 2018 at 11:15 AM
    #2662
    lake tahoe skier
    lake tahoe skier Member
    Christian
    Reno, Eastern Sierras
    2017 DCSB TRD OFF ROAD 6SP MT
    None yet other than LED lights interior, BFG's.
    Nov 2, 2018 at 11:12 AM
    Took in my 2017 TRD OR MT for it's 15000 mile service today. Brought a copy of TSB--0125-18 which specifically mentions manual transmissions, and hoped to get the ECU flashed with the B1300 update at the same time. NO LUCK. Dolan Toyota of Reno said that would require leaving the truck all day with a tech, and it would only be done if they could recreate the idle surge with steering input. I couldn't leave the truck here all day, got sh#t to do. Does the dealership incur any cost when they reflash/update the ecu to them? Why do they have to be so difficult? Any advice when I go back in and try again?
  3. Nov 2, 2018 at 11:18 AM
    #2663
    Raistlen0
    Raistlen0 Well-Known Member
    PA
    2017 TRD Sport DCLB AT QS
    Try 62-18 or 58-18
  4. Nov 2, 2018 at 11:32 AM
    #2664
    Rodchester
    Rodchester Well-Known Member
    Baton Rouge
    2017 Quicksand SR5 DCSB V6
    Weather tech mats, LED interior lights and reverse lights, tube steps, bed extender, bed mat, folding bed cover, TRD Pro grill, blacked out badges and wheel center caps. Kicker speakers(all 6). Front bed rail header. Under hood LEDs. Tufskinz door and interior foam inserts. Chrome interior door handles. Fumoto drain valve. Aluminum oil filter canister. Rear view mirror with Homelink. Quick charge USB charging ports. TRD badge on grill. MESO fuse box cover. Redline Tuning hood struts. Ceramic coating. Pop & Lock auto tailgate lock. LED bed lights. Lower bumper LED light that bar. MESO coin holder. TRD cat back exhaust. Hikari Ultra LEDs high and low beams. 2020 TRD Sport wheels and TRD center caps. RSC Nano dashcam. DSM from the Taco Garage. Blue Sea dual USB outlet on back of center console. KDMax7.0
    Being in the mountains 62-18 should work for you
  5. Nov 2, 2018 at 11:37 AM
    #2665
    tcjacado
    tcjacado Well-Known Member
    He is a manual transmission. That update is for the automatic. He has the right one for the MT. Just like it's a different number for the Canada trucks.
    inksin likes this.
  6. Nov 2, 2018 at 11:37 AM
    #2666
    dangeroso
    Jon
    Dallas, TX
    Just got a call that it’s getting done now. Finally!
    runmc likes this.
  7. Nov 2, 2018 at 1:30 PM
    #2667
    Rodchester
    Baton Rouge
    True
  8. Nov 2, 2018 at 5:49 PM
    #2668
    dangeroso
    Jon
    Dallas, TX
    And the update was done successfully. Not the night and day difference for me that some describe but it’s definitely noticeable. I second the idea that it runs like it used to on ECT now.
    Haven’t spent much time on ECT yet to compare that.
    Tig3r_Bit likes this.
  9. Nov 2, 2018 at 8:38 PM
    #2669
    BROTACOATX69
    BROTACOATX69 Member
    My dealer did all tsb without any questions asked and I can’t tell any difference what so ever. Pedal commander will be in the mail soon!
  10. Nov 2, 2018 at 8:53 PM
    #2670
    BROTACOATX69
    BROTACOATX69 Member
    I work In the dealer world so I can give you some insight. When claiming tsb related work through warranty it essentially boils down to how the customer words it to the advisor. If you go in and state you’re experiencing something verbatim to the TSB and the dealer denies doing it for some reason then honestly they are stupid for throwing money away. Every tsb has an OP code tied to it for claiming time under warranty. The dealer is getting paid for it. This also All depends on how the service department runs things. Some dealers are STICKLERS on “if we can’t reproduce it, were not going to attempt a repair” and some will just go with anything so they can get paid. There’s pros and cons to both. Pro is if you just go along with anything then you get paid. Con is if you say you repaired it and there’s still an issue, or a customer perceived issue still present, then you have an unhappy customer you have to deal with and may not be worth the .2 hours you were allowed to claim through warranty.
    Maxcustody likes this.
  11. Nov 3, 2018 at 6:51 AM
    #2671
    Rodchester
    Baton Rouge
    Check the calibration IDs with a OBDII scanner.
  12. Nov 3, 2018 at 9:20 AM
    #2672
    Powerprozeus
    Powerprozeus IG: @1987toyota4r
    Aaron
    Birmingham, AL
    2016 Quicksand TRD OR 4x4 / 1987 4Runner SR5
    Always hunting for gears especially in cruise got annoying so I turned in my truck and they were super welcoming on fixing the problem with no back lash. Serra Toyota for the win.
    Update: They updated to T-SB-0058-18 and T-SB-0062-18. What a difference! Very responsive shifts smoothly.
    Sheiweesh and Tig3r_Bit like this.
  13. Nov 3, 2018 at 5:44 PM
    #2673
    Tig3r_Bit
    Tig3r_Bit Well-Known Member
    2018 TRD OR 4x4
    I wonder if this update is good forever or will it go back to the same behavior?
    Powerprozeus likes this.
  14. Nov 3, 2018 at 7:41 PM
    #2674
    adrian_tsn
    adrian_tsn Well-Known Member
    Adrian
    Oak Harbor, WA
    17 4x4 DCSB V6
    Bilstein 5100 w/ OME 887 Springs HS AAL w/ Overload TRD Pro Grille w/ Raptor Lights TRD Pro Shift Knob TRD Pro Skid Plate Morimoto HID and Fogs 285/75/16 Nitto Ridge Grapplers Method NV’s Westin Automotive Running Boards
    Just got the TSB this morning and luckily didn’t have to fight to get it done.
    A very noticeable difference, holds gears longer and the gas pedal is finally responsive. Very well worth it.
    Powerprozeus and Tig3r_Bit like this.
  15. Nov 5, 2018 at 8:12 AM
    #2675
    Powerprozeus
    Aaron
    Birmingham, AL
    I'm sure how you drive and the capabilities of the learning computer will have an impact.
  16. Nov 5, 2018 at 8:38 AM
    #2676
    Beer:30
    Beer:30 There's always money in the banana stand
    Kevin
    Somewhere North of Denver
    2016 DCSB OR V6 4X4
    Ditto.
    If you got the update and can't tell a difference, I'd question whether it was actually updated. The difference with mine was night and day.
  17. Nov 5, 2018 at 9:06 AM
    #2677
    dangeroso
    Jon
    Dallas, TX
    After driving around with the new TSB for a few days, I'm very happy with the new gear mapping. Most noticeable is the quicker transitions to the low gears and less tendency to downshift at higher speeds.
  18. Nov 5, 2018 at 9:07 AM
    #2678
    dangeroso
    Jon
    Dallas, TX
    So does the learned driving habits reset when the ECM is reflashed?
  19. Nov 5, 2018 at 9:25 AM
    #2679
    Rodchester
    Baton Rouge
    Yes, but it does relearn. Drive it like you want it to shift for at least 1500 miles. If you can’t, use S.
  20. Nov 5, 2018 at 7:24 PM
    #2680
    Rodchester
    Baton Rouge
    Mine too
