Finally a fix from Toyota for Stumble condition (TSB 0062-18)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by AWDDude, Jul 19, 2018.
  1. Nov 5, 2018 at 7:55 PM
    #2681
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    I would also question if you ever needed the update in the first place if you can't tell a difference.
    The Real Moondog likes this.
  2. Nov 5, 2018 at 8:31 PM
    #2682
    forestranger007
    forestranger007 Member
    Bill
    North Carolina
    16 MGM DC TRD Sport 4X4
    Apparently it only affects some 2016's. Found out mine is not part of the TSB or recall for this or any flash. Luckily I haven't had any problems with the shifting or any hesitation of the transmission since having this truck so I won't pursue this update..
  3. Nov 5, 2018 at 9:25 PM
    #2683
    Lt. Dangle
    Ohio
    I don't see how yours isnt listed for the tsb since your truck is a 16 and this update came out a couple of months ago. Pretty sure your dealer fibbed unless you have had it updated at another recent service.
    If you have a v6 and an automatic, this update almost certainly appies to you. Or the 58 one anyways. Actually for a 16 there are probably about 7 tsbs that apply to your truck.
    Mine is a 17 and it applied.
  4. Nov 6, 2018 at 9:14 AM
    #2684
    1sttimetacoowner
    1sttimetacoowner Member
    william
    Virginia
    2016 Black Tacoma TRD Sport Double Cab
    K&N 71 Blackhawk series cold air intake, Caliraised light bar behind grill
    Just had the tsb done to my truck i’ve Had this problem since I bought the truck new from Toyota. Over the last two years they’ve done a few tsb updates. I’ve disconnected the battery posts to clean them because of acid build up does that erase the updates from the ecu. Also because of the stutter I almost got into an accident because it stutter and back fired before taking off
  5. Nov 6, 2018 at 9:16 AM
    #2685
    oscolivar1
    oscolivar1 Well-Known Member
    Oliver
    VA
    2017 Tacoma Limited
    Bilstein 8112/8100, JBA UCAs, Icon RXT leaf pack, work wheels 17x8.5;-10os, 285/75/17 cooper LTX AT3, Mobtown HC rear bumper and Sliders, SSO front bumper, BAMF greceased grill.
    He must live on flat roads even on the ramp to merge and not put your foot down through the floor. If I had a 2016, that an automatic get the TSB done.
  6. Nov 6, 2018 at 9:20 AM
    #2686
    tcjacado
    tcjacado Well-Known Member
    No is does not lose the ecu updates. Only thing it may lose is what it learned in that period. Even that is questionable.
  7. Nov 6, 2018 at 9:24 AM
    #2687
    Tacoma2020
    Tacoma2020 Well-Known Member
    Seems like a small risk for something that takes less time than an oil change.
  8. Nov 6, 2018 at 9:47 AM
    #2688
    1sttimetacoowner
    william
    Virginia
    Thanks for the information JaCado, I thought it would retain the updates but just wanted to be certain
    tcjacado likes this.
  9. Nov 6, 2018 at 1:52 PM
    #2689
    dangeroso
    dangeroso Just float along and fill your lungs
    Jon
    Dallas, TX
    2018 Tacoma TRD Sport 4x4
    So after all of 5 days with the new flash, I am back to using ECT. I can definitely tell that there is a difference but not enough of one to perform the way I want it to.
    Any thoughts on Shift Sense vs Pedal Commander?
  10. Nov 6, 2018 at 1:58 PM
    #2690
    1sttimetacoowner
    william
    Virginia
    Okay got my taco back drove from dealer to home which is a short drive and it seems to be ok right now but To short of drive to tell and the update they did was t-sb-0125-18. Which is different code number from what I’ve been reading
  11. Nov 7, 2018 at 4:26 AM
    #2691
    1sttimetacoowner
    william
    Virginia
    What about these aftermarket tuner devices would they work to fix the stumble on acceleration problems and surge problems?
  12. Nov 7, 2018 at 5:45 AM
    #2692
    Tac0Tic0
    Tac0Tic0 новий член
    SLC, Utah
    17 TRDOR QS
    OVTune Volk TE37XT 17x8.5 295/70r17 G003 Yukon 5.29 differential gears Cab Mount Relocate Icon Coilovers Icon AAL Uptop Overland Bed Rack Maxtrax Baja Designs Squadron Pro Ditch Lamps Rough Country Speedometer Calibrator
    Are you talking about the ecu flash? Orange virus tuning?
  13. Nov 7, 2018 at 6:04 AM
    #2693
    1sttimetacoowner
    william
    Virginia
    Idk, I’ve seen these tuner modules didn’t know if it was work buying, they are use to change throttle settings,torque and other things, but didn’t know if they would work and if it would void factory warranty?
  14. Nov 7, 2018 at 6:09 AM
    #2694
    Lt. Dangle
    Ohio
    Pedal commander, shift sense pro, OVTune. Do yourself a favor and search those terms here and draw your own conclusions. I personally have none and no experience with any of them, but OVTune is the only one that appeals to me.
  15. Nov 7, 2018 at 6:10 AM
    #2695
    Tac0Tic0
    Tac0Tic0 новий член
    SLC, Utah
    17 TRDOR QS
    There’s only one true tuner. Orange Virus. It changes the maps inside the ecu and actually fixes problems. Nothing bolt on. No plug ins to keep on your truck. Hook your computer up to the truck computer, flash the ecu, then drive away!
    There’s things to make you think the problems are fixed. Shift sense is one, it basically shifts for you in S mode. Then there’s pedal commander. It just makes the pedal more sensitive to make you think you have more power.
    I’ve been running orange virus for over a year and never looked into fake alternatives.
    Lt. Dangle likes this.
  16. Nov 7, 2018 at 6:14 AM
    #2696
    Tac0Tic0
    Tac0Tic0 новий член
    SLC, Utah
    17 TRDOR QS
    And in the upcoming 1.05 update, the etc button will function as a shift lock button in S mode :eek:.
  17. Nov 7, 2018 at 6:18 AM
    #2697
    Lt. Dangle
    Ohio
    I'm gonna need to read up on that.
    Tac0Tic0[QUOTED] likes this.
  18. Nov 7, 2018 at 6:24 AM
    #2698
    1sttimetacoowner
    william
    Virginia
    Thanks guys I’ll look into orange virus, and this won’t void my warranty?
  19. Nov 7, 2018 at 6:25 AM
    #2699
    1911tex
    1911tex Well-Known Member
    2018 Silver Metallic Limited
    Another BINGO...hit the nail on the head!
  20. Nov 7, 2018 at 6:25 AM
    #2700
    Lt. Dangle
    Ohio
    Alledgedly Toyota can't tell it's there. Not that I doubt that, but there certainly is a "user beware" element to tuning.
    IF Toyota can tell and IF you have it with a motor problem, absolutely Toyota will void your warranty.
    Neither of those things appear to be an issue so far though.
