Finally a fix from Toyota for Stumble condition (TSB 0062-18)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by AWDDude, Jul 19, 2018.
  1. Jan 3, 2019 at 4:19 AM
    #2961
    Sheiweesh
    Sheiweesh Well-Known Member
    Massachusetts
    2017 Tacoma Double Cab 4X4 Off Road
    Chrome Step Rails and Foldable Tonneau
    100% in agreement
    Flash1034 and Slick Taco[QUOTED] like this.
  2. Jan 3, 2019 at 4:23 AM
    #2962
    Sheiweesh
    Massachusetts
    Hunting for gears, I had two issues, one at high speed around 40-50 mph that was fixed by 62-18 and one at low speed when taking off from a full stop and reaching 4th gear at 1100 rpm, which is not fixed. I hate this transmission. Most of my driving is in the city and towns, non-highway driving.
  3. Jan 3, 2019 at 4:24 AM
    #2963
    Sheiweesh
    Massachusetts
    I get a quicker response with ECT.
  4. Jan 3, 2019 at 9:18 AM
    #2964
    Slick Taco
    Slick Taco Id Rather Be Airborne
    Lost somewhere in the PNW
    Current vehicles: 2019 Rav4 Lunar Rock. 2018 TRD OR DCSB KD Max tuned. 2010 Tundra Limited Crew Max . 1991 4Runner Crawler. Ivan Stewart Edition
    KD Max Tune, King 2.5 coil overs T.C. UCA's, Deaver leafs, 17x9 Black Rhyno Warlords, 33" Toyo M/T's, Metal Tech rear bumper, Westin HDX drop steps with Bullet Liner coating, K&N CAI, Baja Designs fog pods, Rigid Midnight addition 3" pod ditch lights. Cali Raised brackets and 32" behind the grill mounted light bar, Southern Style Offroad Lopro Stage II front bumper, Warn winch, FACTOR 55 Ultra Hook, FACTOR 55 Hawes Fairleed, full debadge, Cosmetic goodies such as 15% carbon tint, matte black in channel rain guards, interior LED's, Teton Workshop shift knob, Inferno vinyl detailing on the interior, Cali Raised multi rocker switch cubby insert with Mc Tuning LED switches and a few other mods I've probably left out.
    The only real and permanent fix for this seems to be the OV Tune. Page after page of testimonials state how this fixes the issue along with a few of the other quirks displayed by the 3rd gen transmission. Personally, apon start up, I immediately push the ECT and thrown it is S mode. When I'm in town driving under 40 I'm in S3. When on the highway I'm in S4 and then S5 when cruzing close to 70 mph. 6th gear is absolutely worthless. Any slight movement of the gas pedal and it shifts from 6th to 4th hard then to fifth and back to 6th. It will do this all day if you let it. Needless to say drive mode is also usless. The only good thing to come from the TSB 0062-18 update is the stumble has been eliminated and has not returned. It may just be time to spring for the OV Tune.
    Rcyotaaa5 likes this.
  5. Jan 3, 2019 at 10:30 AM
    #2965
    Sheiweesh
    Massachusetts
    Agreed, my only worry is that someone specifically looks for it and finds it then renders my warranty void. They most likely are on this forum just like we are. That’s my only hesitation.
    dangeroso likes this.
  6. Jan 3, 2019 at 10:39 AM
    #2966
    Flash1034
    Flash1034 Well-Known Member
    N/W Montana
    2023 Toyota Tacoma TRD Pro, Solar Octane, Automatic
    MESO Stage 1.5 LED Taillights Falken Wildpeak AT3W Tires in 265/75-16
    The Tsb made my truck drive infinitely better. The stock tune sucked. The new tune is how it should have come from the factory.
    Sheiweesh likes this.
  7. Jan 4, 2019 at 4:33 PM
    #2967
    greytaco17
    greytaco17 Well-Known Member
    2017 trd sport
    Anybody near Whittier Ca know a dealer that will do the update without giving me shit. I went to Penske Toyota in Downey twice because they had the least crappy yelp reviews around me. First time I went they said if i needed an update they would know and there was none. Just went again this morning brought the tsb paperwork and said I make frequent trips to big bear and the truck struggles, hesitates, and hunts for gears going up the mountain. They just called and said they can’t duplicate and therefore won’t do the update. Fuck Penske Toyota!
    thelifeaquatic likes this.
  8. Jan 4, 2019 at 5:55 PM
    #2968
    Sheiweesh
    Massachusetts
    Shit! I would speak with the service manager or director of service and ask for contacts at the manufacturer. Go in with the purpose of escalation. If your truck has the issue and you can recreate it then they need to comply.
  9. Jan 5, 2019 at 10:32 AM
    #2969
    Gmetaco
    Gmetaco Well-Known Member
    Greg
    2017 OR
    Thanks for all the helpful info. I got the updated tune from the dealership and am happy with the results. I was getting pretty use to the stock tune and could make the truck do what I wanted. The tune definitely helps the truck shift more the way that I like. Not as agressive as ect, but just about right for me. It was very helpful walking in with the tbs in hand. Thanks again TW
  10. Jan 5, 2019 at 10:57 AM
    #2970
    407guy
    407guy Well-Known Member
    407 area code
    2018 TRD OR 4x4 DCSB Cement
    Just tried this too today. First oil change on Toyota's dime and had the TSB 62 printed out. Dealership said they could not replicate so they did not complete the TSB update. I was told that the tech did reset the "learning" methodology (my term, can't remember their wording) in the ECU so "drive it for a bit and see how it drives. We do have the stumble/hesitation documented in your file as a compliant."
    I will add that I have been driving mostly in S4 and the truck is liveable -- hugely better than D. I'm going to drive in D like a madman to see if this reset actually will do anything.
  11. Jan 5, 2019 at 11:30 AM
    #2971
    TacORyan4x4
    TacORyan4x4 Well-Known Member
    2018 Cement Tacoma TRD OR
    I want to get the tsb done at my 10k mile service appointment in hopes of improving the drivability of my tacoma.
    My question is will I need to remove my pedal commander before getting this done? Or should I just keep it out of sight and everything will be fine? Thanks in advance.
  12. Jan 5, 2019 at 11:40 AM
    #2972
    407guy
    407 area code
    Without a doubt, remove it. Don't give the dealership any reason to say the PC is causing the issue.
  13. Jan 6, 2019 at 5:14 PM
    #2973
    dangeroso
    dangeroso Just float along and fill your lungs
    Jon
    Dallas, TX
    2018 Tacoma TRD Sport 4x4
    That and OVTune’s website specifically states that the tune is only to be used for off road driving.
    Yes, it’s a blanket CYA statement but it’s also crap. Especially since they know that everyone is using it on highways. And posting about in their thread.
    Sheiweesh[QUOTED] likes this.
  14. Jan 6, 2019 at 7:23 PM
    #2974
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    I'm getting from 3 to 9 misfires on TSB on 17 mile commute daily. I'm getting OV just to help the engine out. I've driven almost 5K on TSB. It did help, but some days it just does not go.
  15. Jan 7, 2019 at 10:46 PM
    #2975
    TRDPro75
    TRDPro75 Well-Known Member
    Victor
    North Seattle
    2017 TRD Pro Cement Auto
    NitroGear 5.29 Regear OVTune 2.O Tune TRD Cold Air Intake TRD Pro Stock Exhaust 285 75X65 Gladiator X Compe 2020 OEM TRD Pro LED Headlights SnugTop GB Sport Canopy RIGID 30” Radiance Light Bar RIGID 40” Radiance Light Bar Custom Avente Roof Rails on Snugtop Icon RXT Spring Stage 3 Fox 2.5 Tundra Rear Shocks CBI Covert Bumper RCI Full Aluminum Skids RCI Rear Diff Skid RCI 20° Sliders ExperiMental Designs Anytime Locker Wilco Offroad Hitchgate Offset to Passenger Spare Carrier
    Dangeroso is right. You’ll be fine with the OVtune. I have the 1.02 OV tune and took my truck in at my 15K service demanding the current TSB and took it in hand with me. They did the flash without any problems and no clue of my OV Tune. The truck doesn’t stumble at all for me now and shifts are way more predictable.
    The 1.02 Tune was definitely better and now this current TSB improves on even that. The truck will drop only one gear when I use medium throttle now and 90% of the time while drop down two when I’m looking for power.
    I moved recently and can’t find my OV Tune hardware and dongle so I have to keep looking but I’m eager to do the 1.05 for the updated TSB. I hear that is night and day better from what I’m currently running. I’m really happy with how the truck runs right now so I can’t wait to try the next flash when I find it.
  16. Jan 7, 2019 at 11:41 PM
    #2976
    Tacoma2020
    Tacoma2020 Well-Known Member
    Sounds like you should be fixed under warranty. This doesn’t sound good.
  17. Jan 7, 2019 at 11:51 PM
    #2977
    thelifeaquatic
    thelifeaquatic Well-Known Member
    2018 TRD OR DCSB
    Agree with @Sheiweesh speak to the service manager. Tell the SM, I don’t care if your guys can’t reproduce the stumble in a 10, 30, or 60 minute test drive, I drive it all the time and the issue is there. Let them know that you know there is an update for the ECU and you are covered under warranty. I would even tell them to show you the printout saying there are no updates available after they hook up techstream to your truck.
    If you don’t want to go that route, I had mine handled at Ventura Toyota, but that may be further than you want to drive. They showed me the printout with the update available, and then after with no updates available once the update had been installed. I did also speak with the sales guy I bought the truck from in advance. He sent a message to the service guy I was coming in and to do the update if it’s there. Maybe try that, so you ensure it before you even arrive.
  18. Jan 8, 2019 at 6:13 AM
    #2978
    St0rm-Tr00per
    St0rm-Tr00per Well-Known Member
    SoCal
    2018 TRD OR 4X4 DCLB - Super White
    “Semi-Pro”/“PrOff-Road”
    Longo Toyota did mine a few weeks ago. I brought my truck in for it’s first service with a list of several minor issues and we Test drove together to verify each one. Th Service tech said it might not help so I replied not doing the TSB will definitely not help so ... they ended up doing it
    greytaco17[QUOTED] likes this.
  19. Jan 8, 2019 at 11:14 AM
    #2979
    dangeroso
    Jon
    Dallas, TX
    I’m not sure how my post relates to yours. I will never buy a tune from OVTune. I refuse to support a business that shifts ALL liability to the consumer.
  20. Jan 8, 2019 at 11:27 AM
    #2980
    TRDPro75
    Victor
    North Seattle
    Sorry I was trying to respond to #2975 and reading through the chain again, I mistakenly quoted you as the wrong person. My apologies. I didn’t mean to tether you something you disagree with.
    dangeroso[QUOTED] likes this.
