Finally a fix from Toyota for Stumble condition (TSB 0062-18)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by AWDDude, Jul 19, 2018.
  1. Aug 3, 2018 at 11:08 AM
    #341
    barcelona7568
    barcelona7568 Well-Known Member
    CO
    16 DCLB, Stock
    Maybe 6,561 FT; where above that elevation electronic devices need to be de-rated due to diminishing dielectric strength.
  2. Aug 3, 2018 at 11:19 AM
    #342
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    I swear this "coasting" issue was not there when I bought the car. I just recently noticed this development. My daily commute includes going up and down hills (steep grades at some locations) and I never seen/felt that until 2-3 month ago. I bet this is by-product of "learning". The other one that pisses me off is coasting down hill, stuck in 4th and RPMs are going over the roof.
  3. Aug 3, 2018 at 11:21 AM
    #343
    mlr69
    mlr69 I had a savings account before I joined TW
    South Carolina
    2018 TRD Sport 4x4 DCSB
    2" ToyTec/Eibach Pro Sport Lift Kit -SparksParts.com 3/4" ToyTec Front Top Plate Spacer Kit -SparksParts.com SPC Performance Upper Control Arms -SparksParts.com Nitto Ridge Grapplers 285/75/17 (34") -SparksParts.com 1.25" Spidertrax Wheel Spacers -SparksParts.com Hypertech Speedometer Calibrator -hypertech.com Predator Tube Steps -SparksParts.com BAKFlip G2 Tonneau -SparksParts.com OEM Rubber Bed Mat -SparksParts.com OEM All-weather Floor Liners -SparksParts.com Gentex Frameless Mirror with Homelink @RJP869 Subaru/Kicker Tweeters -amazon.com Kicker Door Speakers (x4) -crutchfield.com Radio Knobs @Tacowiede Vehicle OCD Glove Box Organizer -amazon.com ‎JoyTutus Center Console Tray -amazon.com FormulaOne Pinnacle Window Tint -SparksParts.com ACDF Horn Kit @BartMaster1234 Total Tail Light S1 Kit @MESO ECT Button Relocation Kit @Tacowiede Minimalist Key Fobs @MESO Ultimate Map & Dome Lights @MESO Fortin EVO-ALL Remote Start w/Cell Module @jmeitz Coin Bucket with Lid @MESO GermesLab Camera Control System @FreshMexicanTaco Natika Front View Camera -amazon.com VLEDS LP Reverse Light System -vleds.com LIFTd Customs Fuel Cap Cradle @JIMMEISTER OEM Power Tailgate Lock -SparksParts.com OEM 2022 Limited Grille -SparksParts.com OEM 2022 Limited LED Headlamps -SparksParts.com LED Headlight Conversion Harness @daveeasa Headlight Trim Plates @MESO OEM Door Sill Protectors -SparksParts.com Diode Dynamics Elite Fog Lights @memario1214 Fog Light Backlighting PNP Harness @daveeasa TacomaTime Dash Cubby Drawer -etsy.com FPE Fogs + High-Beam Module @memario1214
    Why do you think this?
    I had mine done yesterday, watched the tech do it on his Techstream laptop. He looked up both TSB's on TIS and we saw it the same file (calibration ID) for both, in my case, 8966304A6100, which replaced what was previously installed, 8966304A6000. If you look at the TSB's side by side, you'll see the calibrations ID's are the same for both TSB's.
    Volksparts, xxTacocaTxx and cruetes like this.
  4. Aug 3, 2018 at 11:37 AM
    #344
    montanacruiser
    montanacruiser Well-Known Member
    2017 DCLB Off Road
    Because in my paper work they show that they applied both. I wouldn't think they would do both if they were the same would they?
  5. Aug 3, 2018 at 12:33 PM
    #345
    mlr69
    South Carolina
    This was mentioned before - the thought was that if the dealership performs both repairs, they get reimbursed twice from Toyota. Each TSB states 0.4 hours to reprogram the ECM - so your dealership got credit for 0.8 hours when it really only took them 0.4 hours.
  6. Aug 3, 2018 at 12:40 PM
    #346
    brehew
    brehew Well-Known Member
    '17 DCLB
    Those of you getting the emails with the survey. Have you already had the TSB done? Did you contact Toyota about the transmission before?
    I've had crap luck with my dealer about the ~60mph whine. It's so damn loud but "normal noise" according to them. Since i'm a doublecab longbed i'm not on the list to fix it. I have a feeling when i go in with this TSB they'll do the same thing they did with the whining. But if i could take another email from Toyota corp about tranny issues maybe that would back me up enough.
  7. Aug 3, 2018 at 1:07 PM
    #347
    Connaghan
    Connaghan Well-Known Member
    Sean
    2016 trd
    Just had mine done at 3 feet below sea level... Super happy with the new flash but I'm only one day in.
  8. Aug 3, 2018 at 1:24 PM
    #348
    petr321
    petr321 Well-Known Member
    Petr
    San Diego
    2018 DCSB OR
    Just dropped my 18 off at the dealer to do the update. Told them not to go out and hot rod my truck around just to find out it didn’t do it because we are at sea leave. They said cool. I also installed a hidden camera so I know what happened
    payrow and Connaghan like this.
  9. Aug 3, 2018 at 3:35 PM
    #349
    NMTrailRider
    NMTrailRider Well-Known Member
    New Mexico
    The "stuck in 4th downhill RPM thing" is an automatic engine breaking thing-- so you don't have to ride the brakes going downhill. Usually if you tap the brake you can get it to downshift and release.
    xxTacocaTxx and bshammer0 like this.
  10. Aug 3, 2018 at 3:47 PM
    #350
    NMTrailRider
    New Mexico
    To be honest, I've never liked the way this works. Sometimes it turns on, sometimes it doesn't. Sometimes it doesn't turn off when it should. Sometimes it doesn't turn on when it should. No rhyme or reason in my experience.
    I'd rather simply downshift manually when necessary than have the truck do it automatically and incorrectly. Another one of those modern technology things not working as intended and yet they continue to implement it.
  11. Aug 3, 2018 at 4:25 PM
    #351
    TFly
    TFly Well-Known Member
    Travis
    Richmond, VA
    2018 Cement DCSB OR
    I haven’t had the TSB (and won’t; I have the Orange Virus tune). I beat them up with the customer satisfaction survey a few months after I purchased it.
  12. Aug 3, 2018 at 4:43 PM
    #352
    Judd2112
    Judd2112 Well-Known Member
    2016 Tacoma SR
    Does anyone know if this applies to 2016 4 cylinder automatics? What is the process to get the tsb done at the dealer? Just tell them you want it done due to a lag in the throttle?
  13. Aug 3, 2018 at 4:49 PM
    #353
    ToyotaRacingDevelopment
    ToyotaRacingDevelopment Well-Known Member
    Florida Native in Colorado
    '18 Tacoma TRD Off Road (Quicksand-Premium/Tech)
    Magnaflow Exhuast TRD PRO Grille w/ TSS Garnish
    Why are dealerships hesitant to do this? Why do they have to replicate first? How hard is it just to update?
    I dont get the pushback...
    junjo_pr and 2016Tacoman like this.
  14. Aug 3, 2018 at 5:07 PM
    #354
    sorgon82
    sorgon82 wanna go for a rip bud
    Ont. Canada
    2016 Grey Tacoma sport dc long bed
    New one joe. Came out for us july 25th
    Feels a bit better then the old one in 2016
    Joe23[QUOTED] likes this.
  15. Aug 3, 2018 at 5:24 PM
    #355
    fdbyrne
    fdbyrne Well-Known Member
    Missouri
    2016 Tacoma TRD Off Road (Manual), 2004 4RUNNER V6 4x4
    Don't spend much time pushing for them to fix your differential whine. That TSB didn't help much at all.
  16. Aug 3, 2018 at 5:33 PM
    #356
    pskidmore22
    pskidmore22 2018 DCLB 4X4 TRD SPORT UPGRADE - INFERNO
    2018 Inferno TACOMA 4X4 TRD SPORT UPGRADE
    Any chance on PM'ing me or posting the "Take the Survey" link/url I see in the image in your post? I'd like to contribute to the survey.:cheers:
    treimche and Frito like this.
  17. Aug 3, 2018 at 6:21 PM
    #357
    Vanderjdm
    Vanderjdm Well-Known Member
    2018 Off Road
    5% Tint, ARE V-Series w/ Yack Rack, Ebay Grill, Emblem Black Out Kit, Bumpershellz, Predator Tube Steps, Radioknobs by Tacowiede, Kicker Speaker Upgrade
  18. Aug 3, 2018 at 7:00 PM
    #358
    2016Tacoman
    2016Tacoman Well-Known Member
    J
    2016 Tacoma 4x4 V6 Metallic
    Sounds like they know there is an issue.
    Having to ask people is what amazes me.
    Don't they know ?
  19. Aug 3, 2018 at 7:13 PM
    #359
    68injunhed
    68injunhed Well-Known Member
    Jeff
    SE Kansas
    2018 SCrew F150
    A couple things
    I’m pretty sure it’s tied to his email, probably wouldn’t work even if you had the link.
  20. Aug 3, 2018 at 7:44 PM
    #360
    tomz3rdtoy
    tomz3rdtoy Well-Known Member
    Tucson
    '16 White DBL Cab ORSB 6MT
    Icon f/r, add-a-leaf, SR8 w/285/75-16 BFG KO2
    Well, mention (in case more are needed) us MT buddies of yours need this stumble business taken care of too!
    Thanks!
    MOC221_ likes this.
