Finally a fix from Toyota for Stumble condition (TSB 0062-18)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by AWDDude, Jul 19, 2018.
  1. Aug 27, 2018 at 9:51 AM
    #1161
    Chucky1953
    Chucky1953 Active Member
    2018 TRD Off-Road
    Pro-Grille
    58 is for "gear hunting"
    62 is for no throttle response when mashing the throttle taking off from dead stop
    NOTE: I'm not saying for anyone to start doing hole shots now. So don't sue me. I looked into it after giving it the boot from a dead stop on about an 80 degree incline hill to enter onto another road. It just missed completely before it found a gear. I've not gone back to that hill yet, but overall the truck seems to be driving great with these 2 updates.
    Of course I go on there today to check this thread as I've been busy and believe I have been experiencing the mysterious whine noise from the rear end. Sound like wind going through a flute.......... TSB-0013-18 ???
    RobP62 likes this.
  2. Aug 27, 2018 at 9:53 AM
    #1162
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    Hey Thanks!!!!! Sometimes I am so lazy and have been meaning to search for these PDFs but that's not necessary now thanks to you! :yay: :yes: :thumbsup:
    On the down side, I guess you know that it makes you an enabler. :devil:
    mlr69[QUOTED] likes this.
  3. Aug 27, 2018 at 9:56 AM
    #1163
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    Is this the one:
    https://imgur.com/a/fQAf3mc
    JRMiller likes this.
  4. Aug 27, 2018 at 10:00 AM
    #1164
    KevC
    KevC Well-Known Member
    Should I get done both at the same time? Or will they look at me like I'm crazy
    RobP62 likes this.
  5. Aug 27, 2018 at 10:05 AM
    #1165
    MrMccrackin
    MrMccrackin Well-Known Member
    Gilbert, AZ
    2004 TRDOR PreRunner, 2017 MGM TRDOR 4x4
    58 and 62 have the same CAL ID fix so it doesn't matter which one they do.
  6. Aug 27, 2018 at 10:10 AM
    #1166
    thelifeaquatic
    thelifeaquatic Well-Known Member
    2018 TRD OR DCSB
    MrMccrackin is correct. The TSB numbers are not the actual updates, they are the Toyota Service Bulletins that reference an issue with the vehicle.
    Either of the two TSB numbers 0058-18 and 0062-18 result in the same updates being applied if they are available for your truck. I have seen members say that sometimes a dealership will reference both in their solution and this just means they have gotten paid twice by Toyota to run the same updates that would have run from either TSB.
  7. Aug 27, 2018 at 10:15 AM
    #1167
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    I'm handing them all three printed out PDFs from the recent post by @mlr69, but not before I rehearse my lines.
  8. Aug 27, 2018 at 10:55 AM
    #1168
    swimmer
    swimmer Well-Known Member
    Tucson
    2016 TRDORAC4WD
    Fucking LOL. Eighty degrees is almost vertical There isn't a road anywhere that is at 80 degrees.
    1TonTomato and RobP62 like this.
  9. Aug 27, 2018 at 1:12 PM
    #1169
    inksin
    inksin Well-Known Member
    Hawaii
    2016 Off Road access cab
    actually all 3 TSBs will get you the same Aspirin for your different ailments
    77 is old, they will update to the new ECU 04B04
    58 is for surge between 40-50 you get ECU 04B04
    62 is for stumble at WOT at high altitude and you will get.....ECU 04B04
    you pick the one that you think will be most believable by the dealer. If you live in Florida don't pick 62 cause they will be less likely to give it to you since it says specifically for high altitude. If you have a MT then pick 58 cause it's the only one that has the MT ECU in it. If you have a newer '17 or '18 dont pick 77 cause it only applies to '16s and early '17s. you can't apply both TSBs cause the ECU won't allow the second update once the first one is done but Toyota will say that they did them both, they can't. just cause 62 is a bigger number does not mean it's a better update, again, it is exactly the same (unless your a MT)
    Loaded NightraiN, tcjacado and RobP62 like this.
  10. Aug 27, 2018 at 2:20 PM
    #1170
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    :thumbsup:
  11. Aug 27, 2018 at 2:51 PM
    #1171
    tater taco
    tater taco no it all
    Todd
    ground zero of the zombie apocalypse
    2016 ACLB TRD OR Quicksand OV Tuned 2.0 (91)
    OVTuned, decatted dump tubes
    are you prepared to repost this daily for the "what's the difference between these TSB's" posts?
    asking for a friend
    inksin[QUOTED] likes this.
  12. Aug 27, 2018 at 2:55 PM
    #1172
    Techsan
    Techsan Well-Known Member
    South Texas
    2017 BBPDC
    Using cc even in a light rain is dangerous as hell. Could be a lot more than two people dead.
    Kpatt9 and NMTrailRider[QUOTED] like this.
  13. Aug 27, 2018 at 2:56 PM
    #1173
    mlr69
    mlr69 I had a savings account before I joined TW
    South Carolina
    2018 TRD Sport 4x4 DCSB
    2" ToyTec/Eibach Pro Sport Lift Kit -SparksParts.com 3/4" ToyTec Front Top Plate Spacer Kit -SparksParts.com SPC Performance Upper Control Arms -SparksParts.com Nitto Ridge Grapplers 285/75/17 (34") -SparksParts.com 1.25" Spidertrax Wheel Spacers -SparksParts.com Hypertech Speedometer Calibrator -hypertech.com Predator Tube Steps -SparksParts.com BAKFlip G2 Tonneau -SparksParts.com OEM Rubber Bed Mat -SparksParts.com OEM All-weather Floor Liners -SparksParts.com Gentex Frameless Mirror with Homelink @RJP869 Subaru/Kicker Tweeters -amazon.com Kicker Door Speakers (x4) -crutchfield.com Radio Knobs @Tacowiede Vehicle OCD Glove Box Organizer -amazon.com ‎JoyTutus Center Console Tray -amazon.com FormulaOne Pinnacle Window Tint -SparksParts.com ACDF Horn Kit @BartMaster1234 Total Tail Light S1 Kit @MESO ECT Button Relocation Kit @Tacowiede Minimalist Key Fobs @MESO Ultimate Map & Dome Lights @MESO Fortin EVO-ALL Remote Start w/Cell Module @jmeitz Coin Bucket with Lid @MESO GermesLab Camera Control System @FreshMexicanTaco Natika Front View Camera -amazon.com VLEDS LP Reverse Light System -vleds.com LIFTd Customs Fuel Cap Cradle @JIMMEISTER OEM Power Tailgate Lock -SparksParts.com OEM 2022 Limited Grille -SparksParts.com OEM 2022 Limited LED Headlamps -SparksParts.com LED Headlight Conversion Harness @daveeasa Headlight Trim Plates @MESO OEM Door Sill Protectors -SparksParts.com Diode Dynamics Elite Fog Lights @memario1214 Fog Light Backlighting PNP Harness @daveeasa TacomaTime Dash Cubby Drawer -etsy.com FPE Fogs + High-Beam Module @memario1214
    Yea, too bad there's no way to have that post pinned to top of each page.
    inksin and RobP62 like this.
  14. Aug 27, 2018 at 3:57 PM
    #1174
    Tig3r_Bit
    Tig3r_Bit Well-Known Member
    2018 TRD OR 4x4
    Just by reading everyones post. I'm getting jealous.
  15. Aug 27, 2018 at 4:11 PM
    #1175
    krupnation
    krupnation Active Member
    100 series Land Cruiser
    Update: Had my service done last Wed but was on vacation the rest of the week so didn't get a chance to drive it until today. Drive into work was nice, I'd say it's a 75% improvement so far. I still think it shifts too soon, I wish it would hold 3rd gear a little longer, but it has vastly improved over the factory tune. It doesn't search for 6th immediately and holds 5th way longer. I haven't tried WOT yet but plan on doing so on my way home. As many have said, worth the update.
  16. Aug 27, 2018 at 5:04 PM
    #1176
    Mazz20
    Mazz20 Member
    **Update** I just returned from the Dealership with my new ECM update. The manager asked if after a few days or so would I get back to him on my findings. He along with Toyota was interested in the feedback. Sales Mgr. said, He and Toyota were aware of the problems (and knew of this website) and complaints from the people driving the Tacoma's and want to make it better. I'll give you my first impressions in the first 15 minutes, hardly a good indicator of an evaluation especially since I only had a few instances where I had that dead spot on acceleration in the past six months. 1). The transmission does not quickly look for the higher gear. 2). it seems to downshift a little sooner and therefore upon acceleration is in a better gear and RPM. 3). From stop lights. the gas pedal movement to the truck actually moving is more responsive. Ok that's about it for now. It did say in my invoice that the truck will need to be driven for the" ECM to relearn itself to the customers driving habits. " I told the sales Mgr. I would put a good word in to this site for the no hassle service I was given. Valenti Toyota Westerly R.I. Sales Mgr. Rocky Sposato. Advisor Michael Williams. 2018 TRD Sport
    RobP62, gthupman and Toms 17 like this.
  17. Aug 27, 2018 at 5:24 PM
    #1177
    mweidl
    mweidl Well-Known Member
    Mikey
    Southern California
    2017 Tacoma SR 4x4 Auto
    I looked through the TSB's and it appears this is only for the 6cyl. Has anyone had an luck getting the same issues resolved in a 4cyl SR??
  18. Aug 27, 2018 at 5:31 PM
    #1178
    IPNPULZ
    IPNPULZ Well-Known Member
    Deeper in the South…….
    2023 TRD Off Road Premium 4R
    going to be fun!
    :rofl::rofl::rofl:
    RobP62[QUOTED] likes this.
  19. Aug 28, 2018 at 7:22 AM
    #1179
    DHerrm
    DHerrm Well-Known Member
    Daniel
    2018 SR5
    Is this right? My engine is 6100 and tran 4100. I watched them hooked up to my OBD and no updates beyond that were available. Nor for anything else....
  20. Aug 28, 2018 at 7:32 AM
    #1180
    mlr69
    South Carolina
    I don't know what 4100 is but if you have a 2016/2017, the newest Calibration ID is 0400 or 1300, if you have a 2018, the newest Cal ID is 6100 or 7100. If that's what you have then you have the latest.
