Finally a fix from Toyota for Stumble condition (TSB 0062-18)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by AWDDude, Jul 19, 2018.
  1. Aug 29, 2018 at 2:00 PM
    #1241
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    10-4, #learningisgood ! :thumbsup:
  2. Aug 29, 2018 at 2:07 PM
    #1242
    Mazz20
    Mazz20 Member
    In my service document they said they test drove it and "Confirmed Customers Concern". So far it seems to have worked, and because of this, I will be back for another Tacoma in 2 years and my wife a RAV4. They can't be mad about that. I also asked if it would be ok to do this.
    RobP62 likes this.
  3. Aug 29, 2018 at 2:47 PM
    #1243
    ej_
    ej_ Well-Known Member
    I'll be driving in high elevations this week over 8000 ft what exactly is the troubleshooting procedure here find out if the problem exists. I'm busy with work and I don't want to bring the truck to any of the dealerships around here. I had to jump through hoops and drive out of my way snag this truck and the only dealership I want touching it is Bakersfield now.
    RobP62 likes this.
  4. Aug 29, 2018 at 3:33 PM
    #1244
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    You should experience a variety of things. For one, there is a stall like feeling if you dump the throttle. Then while accelerating through the gears it will surge at around 40 mph like you are racing the guy next to you. Almost like you hit a switch, but it was a much more tame version of nitrous. Finally, while driving up and down what are seemingly mild inclines the tranny will downshift into 4th or sometimes even 3rd and hold it even after you start to level out to the point you will have to take your foot off the pedal or manually shift it into 6th again.
    There is another "rumble" issue to but I am not experiencing this so I will let those that are answer. The above are my observations.
    Loaded NightraiN and ej_[QUOTED] like this.
  5. Aug 29, 2018 at 4:05 PM
    #1245
    SpeySquatch
    2016 TRD OR DCSB
    Crank Position Sensor
    RobP62[QUOTED] likes this.
  6. Aug 29, 2018 at 4:06 PM
    #1246
    SpeySquatch
    2016 TRD OR DCSB
    OK my bad for trying to help.
  7. Aug 29, 2018 at 4:09 PM
    #1247
    ChickoSM1808
    ChickoSM1808 Well-Known Member
    Michael
    2018 dcsb TRD Sport (OVTuned)
    OVTuned, TRD Pro grille, 32's and many more
    I had both tsb's done about a month ago. Everything was fine till this week. Now the jerkiness on the highway while pulling a slight incline is back even worse than before. And it seems to be losing more power every day. Getting pretty pissed at this point. I've had the truck for 4 months and it's been in the shop twice. Second time for almost a week.
  8. Aug 29, 2018 at 4:11 PM
    #1248
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    Thank you. I am older and not a mechanic so I have a hard time with all these acronyms.
    SpeySquatch[QUOTED] likes this.
  9. Aug 29, 2018 at 5:36 PM
    #1249
    CTF
    CTF Well-Known Member
    2017 TRD OR
    It seems I’ve read that same response from other 2018 owners. Any 16-17’s have the same remissive behavior?
    RobP62 likes this.
  10. Aug 29, 2018 at 5:49 PM
    #1250
    TFly
    TFly Well-Known Member
    Travis
    Richmond, VA
    2018 Cement DCSB OR
    I've noticed some increasingly funky behavior recently with mine as well. Just feels more...lethargic. That, and when accelerating from a stop or near stop at a not quite moderate pace (ie, I'm not in a rush and no traffic coming up behind me), there are 3-4 "pauses" in acceleration up to about 30 mph. It's not a stumble; ie, it doesn't throw my head forward. It just stagnates...almost like coasting.
  11. Aug 29, 2018 at 6:29 PM
    #1251
    Rodchester
    Rodchester Well-Known Member
    Baton Rouge
    2017 Quicksand SR5 DCSB V6
    Weather tech mats, LED interior lights and reverse lights, tube steps, bed extender, bed mat, folding bed cover, TRD Pro grill, blacked out badges and wheel center caps. Kicker speakers(all 6). Front bed rail header. Under hood LEDs. Tufskinz door and interior foam inserts. Chrome interior door handles. Fumoto drain valve. Aluminum oil filter canister. Rear view mirror with Homelink. Quick charge USB charging ports. TRD badge on grill. MESO fuse box cover. Redline Tuning hood struts. Ceramic coating. Pop & Lock auto tailgate lock. LED bed lights. Lower bumper LED light that bar. MESO coin holder. TRD cat back exhaust. Hikari Ultra LEDs high and low beams. 2020 TRD Sport wheels and TRD center caps. RSC Nano dashcam. DSM from the Taco Garage. Blue Sea dual USB outlet on back of center console. KDMax7.0
    Maybe try disconnecting your battery for a few minutes to reset the “learned driving behavior” and see if it goes back to like it was right after the update. Go from there.
  12. Aug 29, 2018 at 10:41 PM
    #1252
    Howanic
    Howanic Well-Known Member
    Utah
    2016 TRD OR Double Cab 4X4 A/T Inferno
    If you can I would get the Cal ID checked to see if they didnt just reflash your ECU without the new update. Just a thought.
  13. Aug 29, 2018 at 11:14 PM
    #1253
    NMTrailRider
    NMTrailRider Well-Known Member
    New Mexico
    I got TSB 58 and I'm still holding 3rd gear for like a quarter mile after cresting a hill. Whether flat at the top or even when going back downhill it will still hold 3rd and 3500rpm for a quarter mile. Really strange. It's not every time. But maybe 50% of the time.
  14. Aug 30, 2018 at 9:48 AM
    #1254
    mdb1grfe
    mdb1grfe Well-Known Member
    Butler County, PA
    2018 TRD OffRoad, Silver DC
    D-ring tie-downs.
    Showed up at Preston Toyota of New Castle Service dept. on time. The rep asked me my concern. After explaining the symptoms he said there was a number of trucks that have come in for the TSB. He said none have come back and told me they would check out my truck to make sure of the issue, not something else, and go from there. Told me it would take about 45 minutes to run the program. Sure enough, in just over a half hour later the young fella looked me up and gave me a copy of their service order. TSB 0062-18 was done. No more hunting/nudging and the throttle response is better and more linear.
  15. Aug 30, 2018 at 1:16 PM
    #1255
    a400ryan
    a400ryan Well-Known Member
    Garson Manitoba Canada
    2015 SR5 DCLB
    CANADIAN fix is now
    T-TCI-5143
    As of Aug 28
    RobP62 likes this.
  16. Aug 30, 2018 at 1:17 PM
    #1256
    Thompson486
    Thompson486 Well-Known Member
    Sherwood Park, AB
    2022 AC Off-Road Blue Crush
    Does that one include the 2018s?
    RobP62 likes this.
  17. Aug 30, 2018 at 2:41 PM
    #1257
    a400ryan
    2015 SR5 DCLB
    States 16-18 and auto
    Thompson486 likes this.
  18. Aug 30, 2018 at 3:09 PM
    #1258
    Captspaulding1000
    Captspaulding1000 Well-Known Member
    Any chance for a pdf copy?
    Matusik1, Thompson486 and RobP62 like this.
  19. Aug 30, 2018 at 3:39 PM
    #1259
    CoastieRon
    CoastieRon Hammocking Fool
    Ron
    Nashua
    Lil' Silver
    Too much.
    Had mine done today, but they did not put sticker on...FB_IMG_1535666843126.jpg
    RobP62 likes this.
  20. Aug 30, 2018 at 4:24 PM
    #1260
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    Hmmm. wonder why these dealers can't get their shit together on this...........
    IPNPULZ and CoastieRon[QUOTED] like this.
