Finally a fix from Toyota for Stumble condition (TSB 0062-18)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by AWDDude, Jul 19, 2018.
  1. Sep 1, 2018 at 1:16 PM
    #1421
    mdb1grfe
    mdb1grfe Well-Known Member
    Butler County, PA
    2018 TRD OffRoad, Silver DC
    D-ring tie-downs.
    Ford will re-engineer things that don't need re-engineering. Of the minor shortcomings complained about Toyotas, why would Ford put the turn signal indicators in the bottom of the gauge cluster and have the turn signal stalk activate different from every one before or since from other mfgs. Just saying. Regardless the infinite individuality afforded by trim pkgs, IMO i couldn't drive something I would MF overtime i interacted with it.
  2. Sep 1, 2018 at 1:30 PM
    #1422
    Wsteven
    Wsteven Well-Known Member
    2018 Tacoma TRD Pro
    Working on them
    Looking for that thread then because My Truck is the Manual Transmission and Today I did Experience stumble what a horrible feeling that is.. RRRRrrrrrrrrrrrrRRRRR! shift ... rrrrrrrRRRRRR!
    tcjacado[QUOTED] likes this.
  3. Sep 1, 2018 at 1:36 PM
    #1423
    tcjacado
    tcjacado Well-Known Member
  4. Sep 1, 2018 at 1:53 PM
    #1424
    Khakiman
    Khakiman Well-Known Member
    2017 Black Tacoma 4X4 Double Cab TRD Sport
    Front Grille, Step Bars, Tinted Windows, Tonneau Cover, Wheels, Tires, Roof Racks, Mud Flaps, Led Fog Lights, Mob Armor Phone Mount, Console Organizer, Pioneer AVIC 8200 NEX Radio/GPS,
    I had same thing happen but turns out the paperwork showed old TSB but actually the newest was performed. The tech said the system only uses the latest version of software and the correct one was applied. My service advisor just typed in the old one.
    VangaSTL[QUOTED] and gurneyeagle like this.
  5. Sep 1, 2018 at 2:10 PM
    #1425
    The Real Moondog
    The Real Moondog Well-Known Member
    Moondog
    Somewhere in the SE USA
    2017 Quicksand Tacoma TRD Off-Road (Sold :()
    Update: 4 hours later and a lot of eye twitches later (read, I have no patience) I had the TSB done, although they called it TSB0058-18 (same reflash). I also had the front side window moldings replaced (goodbye cross wind noises). The truck finally drives like it should have from day 1. Very noticeable difference for me. I’m happy. If you haven’t had this done just get it done.
    RobP62, bulalo, gurneyeagle and 2 others like this.
  6. Sep 1, 2018 at 3:20 PM
    #1426
    NMTrailRider
    NMTrailRider Well-Known Member
    New Mexico
    Can you tell if it was the outter hard black piece around the window visible from outside the truck or was it the softer flexible EPDM inner seal?
  7. Sep 1, 2018 at 3:28 PM
    #1427
    The Real Moondog
    Moondog
    Inside. But, I think they were supposed to have done the outside. Honestly, I’m just happy to be out of there. It’s clear that the service advisor did not communicate well (read, at all) with the tech and that the tech did not read the TSBs that I printed out and carefully placed in the seat for him. 3 hours in I was finally able to get him to actually “double check” to make sure I had the ECU reflash. I didn’t. I knew that. But, I finally got it. Now I’ll worry about the window seal for the outside. But, overall I’m happy because my truck drives the way it should. My whine is mostly better too. But, I’m going to go ahead and get a couple more repair attempts just to have in my hip pocket in case things go south.
    Edit: You can do most of the work for them by spoon feeding what is wrong to them and they still may or may not do the work. When they do the work they may or may not do it right.
    Edit 2: Replacement of the inside seal was correct.
  8. Sep 1, 2018 at 4:12 PM
    #1428
    The Real Moondog
    Moondog
    I would add that the dealer reminded me of the AC fan recall. I’ll add that to the list.
    RobP62 likes this.
  9. Sep 1, 2018 at 4:27 PM
    #1429
    The Real Moondog
    Moondog
    FWIW, I didn’t get a sticker either. But, for added piece of mind the tech did show me the update. I still want my sticker. @RobP62 any sticker suggestions? LOL
    RobP62 likes this.
  10. Sep 1, 2018 at 4:29 PM
    #1430
    NMTrailRider
    New Mexico
    Does that include 18's?
  11. Sep 1, 2018 at 4:30 PM
    #1431
    jmneill
    jmneill Well-Known Member
    SE
    2018 Tacoma Sport ACC CB Inferno
    Nope, thankfully.
  12. Sep 1, 2018 at 4:32 PM
    #1432
    NMTrailRider
    New Mexico
    I can't seem to find the thread with all the 3rd gen TSB's compiled. Anyone have the link handy?
    Kpatt9 likes this.
  13. Sep 1, 2018 at 4:33 PM
    #1433
    tcjacado
  14. Sep 1, 2018 at 4:34 PM
    #1434
    The Real Moondog
    Moondog
  15. Sep 1, 2018 at 4:36 PM
    #1435
    jmneill
    SE
  16. Sep 1, 2018 at 5:10 PM
    #1436
    NMTrailRider
    New Mexico
  17. Sep 1, 2018 at 5:22 PM
    #1437
    Jukeboxx13
    Jukeboxx13 Well-Known Member
    California
    2017 TRD OR DCSB 4x4
    Just got it done and no more stumble or hunting. True test will be when I go on a road trip in 2 weeks which involves a steep 6% grade, and might sell my shift sense pro if it does well enough.
  18. Sep 1, 2018 at 5:39 PM
    #1438
    mjsiniard
    mjsiniard Lucky Dog
    2017 Tacoma MGM access cab
    Had my 2017 done today along with the recall on the blower fan. Noticible difference in the 12 mile run home from the dealer. Key word for the dealer to write it up was “stumble”. Thanks for all the info folks.
    remgu2000 likes this.
  19. Sep 2, 2018 at 5:10 AM
    #1439
    Loaded NightraiN
    Loaded NightraiN Well-Known Member
    17 TRD Off Road
    Who here has put the most miles on this TSB? Just wondering if this is just going to revert back after the learning period
    Kilokato likes this.
  20. Sep 2, 2018 at 5:44 AM
    #1440
    WZ00R2
    WZ00R2 Well-Known Member
    TN
    2020 Cement OR
    6112/5160, Deaver U402, 255/80r17, SCS BR6
    The ECM will not revert. This is a permanent software update for the controller. I have about 1200 miles on the new calibration and have no issues.
