Finally a fix from Toyota for Stumble condition (TSB 0062-18)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by AWDDude, Jul 19, 2018.
  1. Sep 2, 2018 at 8:45 PM
    #1461
    pismo61
    pismo61 Well-Known Member
    Temecula,Ca.
    SR 4x2 auto.
    Im getting 19mpg around town before and after the tsb.So my mpg has not changed.Many trips I get 21-22.Truck is all stock.Funny freeway trips I can only get 22-24.
  2. Sep 2, 2018 at 8:46 PM
    #1462
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    Tonneau helping is a myth, unless it doesn't weigh anything. Mine doesn't.
    Do you keep the rpm's under 2k as much as possible? That's what helps me.
  3. Sep 2, 2018 at 8:46 PM
    #1463
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    I'm working on it :thumbsup:
  4. Sep 3, 2018 at 11:07 AM
    #1464
    cj4x2
    cj4x2 New Member
    2018 4x2 TRD Sport
    Is this update for auto transmission also?
  5. Sep 3, 2018 at 12:08 PM
    #1465
    mdb1grfe
    mdb1grfe Well-Known Member
    Butler County, PA
    2018 TRD OffRoad, Silver DC
    D-ring tie-downs.
    It cleared up the issues I had with my truck. Depending on your symptoms it may help you. My advisor cautioned me when I showed up for the appt that they would check first that there was not another issue causing my complaint then go from there. Good luck.
    RobP62 likes this.
  6. Sep 3, 2018 at 1:36 PM
    #1466
    Rodchester
    Rodchester Well-Known Member
    Baton Rouge
    2017 Quicksand SR5 DCSB V6
    Weather tech mats, LED interior lights and reverse lights, tube steps, bed extender, bed mat, folding bed cover, TRD Pro grill, blacked out badges and wheel center caps. Kicker speakers(all 6). Front bed rail header. Under hood LEDs. Tufskinz door and interior foam inserts. Chrome interior door handles. Fumoto drain valve. Aluminum oil filter canister. Rear view mirror with Homelink. Quick charge USB charging ports. TRD badge on grill. MESO fuse box cover. Redline Tuning hood struts. Ceramic coating. Pop & Lock auto tailgate lock. LED bed lights. Lower bumper LED light that bar. MESO coin holder. TRD cat back exhaust. Hikari Ultra LEDs high and low beams. 2020 TRD Sport wheels and TRD center caps. RSC Nano dashcam. DSM from the Taco Garage. Blue Sea dual USB outlet on back of center console. KDMax7.0
    Wow
    swimmer and RobP62 like this.
  7. Sep 3, 2018 at 3:48 PM
    #1467
    Double Phister
    Double Phister Punch it Chewie
    Sacramento, CA
    2017 DCSB TRD OR [SOLD]
    Sub $200 is the cost if it goes well.
    I bought the Tactrix cable
    overnight shipping from CA to VA
    Legit 2 day pro TIS subscription
    and a copy of OVtune as a thank you
    Still cheaper than a dealer replacing and ECU.
    PapaRee and RobP62[QUOTED] like this.
  8. Sep 3, 2018 at 3:51 PM
    #1468
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    Sounds like a better setup too! Nice!
  9. Sep 4, 2018 at 5:34 AM
    #1469
    junjo_pr
    junjo_pr Member
    I haven't found this thread...
  10. Sep 4, 2018 at 7:18 AM
    #1470
    Kysport
    Kysport Well-Known Member
    Louisville, Kentucky
    2020 Silver Sky Metallic Limited
    I have an appointment on Thursday. What should I tell the Service Writer so that I don't get the runaround? I have printed out the TSB to take with me. I really would like this update. Thanks.
  11. Sep 4, 2018 at 7:56 AM
    #1471
    CoastieRon
    CoastieRon Hammocking Fool
    Ron
    Nashua
    Lil' Silver
    Too much.
    I can't get Torque to hook up with the dongle. At all. I have the app set on wifi, I am connected to the dongle via wifi, and I have zero success. Using a Pixel 2.
    RobP62[QUOTED] likes this.
  12. Sep 4, 2018 at 8:29 AM
    #1472
    jmneill
    jmneill Well-Known Member
    SE
    2018 Tacoma Sport ACC CB Inferno
    I've only used Torque (pro) on several occasions, but it communicates, at least with Carista via Bluetooth. Do you have it enabled in the Torque adapter settings?
    CoastieRon[QUOTED] likes this.
  13. Sep 4, 2018 at 8:31 AM
    #1473
    CoastieRon
    Ron
    Nashua
    Lil' Silver
    Too much.
  14. Sep 4, 2018 at 8:43 AM
    #1474
    jmneill
    SE
  15. Sep 4, 2018 at 9:02 AM
    #1475
    ChrisSandstorm
    ChrisSandstorm Well-Known Member
    '01 Land Cruiser, '16 TRD OR DCSB
    Hey I just had this TSB done on Friday of last week. It is amazing! I have 295/75/16s and this TSB really allows the engine to perform well. I highly recommend and its free.
    remgu2000 likes this.
  16. Sep 4, 2018 at 9:21 AM
    #1476
    Rodchester
    Baton Rouge
    RobP62 likes this.
  17. Sep 4, 2018 at 9:26 AM
    #1477
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    I wonder if you tried setting it to Blue Tooth? I have my Tablet with me here today at work so I am going to do a factory reset and then download the Torque app and then hopefully get a chance to check it out this week.
    Shouldn't matter what device you are using. As long as it is either Apple or Android.
  18. Sep 4, 2018 at 9:27 AM
    #1478
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    Sorry, didn't see your post before I posted.
    I am going to go BT with my tablet.
  19. Sep 4, 2018 at 9:30 AM
    #1479
    Rodchester
    Baton Rouge
    :thumbsup:
  20. Sep 4, 2018 at 9:41 AM
    #1480
    CoastieRon
    Ron
    Nashua
    Lil' Silver
    Too much.
    got it connected however, I don't see anywhere in the app where it would show the updated software.
