Finally an all alluminum radiator for the first gen Tacos
Discussion in '1st Gen. Tacomas (1995-2004)' started by CHEF JEFF, Feb 18, 2018.
  1. Feb 18, 2018 at 5:20 PM
    CHEF JEFF
    CHEF JEFF [OP] New Member
    Im not sure if I am alone on this but I was sick of replacing my plastic rad every 6- months. Champion makes an all aluminum direct replacement and I thought I should share it in case anyone else felt the same way about those plastic ones. My buddies fit right in and mine is on its way! Heres a link http://www.championradiators.com/product/CC1778
  2. Feb 18, 2018 at 5:25 PM
    Duty Bootie
    Duty Bootie Well-Known Member
    Richard
    Vancouver Island
    96 Taco Bush Truck - Now in Restoration
    Thanks for posting......I'd go this next time 4 sure......just replaced my plastic one at 375,000KM !!
  3. Feb 18, 2018 at 5:30 PM
    mwrohde
    mwrohde Well-Known Member
    Sugar Hill, GA
    2003 Tacoma 4x4 5-speed 3.4 TRD SR5
    Thanks. I may do this, too.
  4. Feb 18, 2018 at 5:36 PM
    MikeWH
    MikeWH Well-Known Member
    Colfax, CA
    1999 TRD 4x4 (x2)
    For 4-bangers only? Or have you tried with the 3.4L V6?
  5. Feb 18, 2018 at 5:43 PM
    Tjk031
    Tjk031 Active Member
    Tommy
    2003 double cab 4x4 trd
    Nice! Any pics you can share? No modifications needed..direct bolt on?
  6. Feb 18, 2018 at 5:44 PM
    CHEF JEFF
    Verify your height before you buy, but if the core is 18-3/4 your good to go compatible with both, they had a 20" core version as well. should still work may just have to drill new holes in rad brackets.
  7. Feb 18, 2018 at 5:52 PM
    neegdogdig
    neegdogdig Untrained with bad experiences go go go!
    3rd Gen DC V6
    How it sits under the hood? Any pics to share?
  8. Feb 18, 2018 at 5:59 PM
    MattJakobs
    MattJakobs Everything but a Tacoma
    Matthew
    NorCal
    1985 4Runner w/ FlipPac
    I’m running the CC1998 on my 01 4runner and it’s a direct replacement but it does take more coolant than stock.
    It fit fine in my 4runner but I read somewhere that it does make contact with the Tacoma’s hood however
  9. Feb 18, 2018 at 7:39 PM
    Phessor
    Phessor Well-Known Member
    Are you running the stock fan or an electric?
  10. Feb 18, 2018 at 7:43 PM
    Oside7even6ixty
    Oside7even6ixty Well-Known Member
    I’d be interested in more info on this as well a pics
  11. Feb 18, 2018 at 7:48 PM
    MattJakobs
    Matthew
    NorCal
    Stock fan. Still running a b&m trans cooler too.
    I don’t notice significantly cooler temperatures, but knowing I’ll never have to replace my radiator is really nice
  12. Feb 18, 2018 at 8:05 PM
    1997tacomav6
    Denver
    The cc1778 is the Tacoma model and the cc1998 is the 4Runner model. If you put the 4 runner model
    in the Tacoma I'm guessing it will hit the hood.
    Ebay sells them for 207.00 free shipping,
    I'm probably going to get one!!
    There should be a group buy on these somewhere
    https://www.tacomaworld.com/threads/aluminum-radiator.383062/page-5#post-17171107
  13. Feb 18, 2018 at 8:25 PM
    License2Ill
    License2Ill Woke like a Coma Toyota Tacoma
    Ian
    It's a dry heat thou, AZ
    2004 SC'd 5VZ DC 5spd 4x4 TRD.GOV
    Bailing wire & Duct tape
    Where's the pics?
    Me and Tacoma World just got off the phone...
    And. Well.
    We don't think you have any friends with this radiator. And we've started to recently develop the opinion you may not have any friends.
    Kindest Regards.
    -Tacoma World
  14. Feb 19, 2018 at 3:15 AM
    COMAtized99
    COMAtized99 Well-Known Member
    North Carolina
    99 DCLB v8
    The Bed is stock...ish
    That was me. I was running the cc1998 4runner radiator in my 99 Tacoma. The cap hits the hood support, and the front top edge of the radiator does rub the front edge of the hood. I hit deer the other week and the radiator got the worst of it. I'm going a different route now.
    MattJakobs[QUOTED] likes this.
  15. Feb 19, 2018 at 3:49 AM
    1997tacomav6
    Denver
    Ok, I'm curious, why would you use the 4 runner model instead of the Tacoma model cc1778 in your tacoma? Your going a different route because?
  16. Feb 19, 2018 at 4:06 AM
    COMAtized99
    North Carolina
    99 DCLB v8
    Well, at the time, there was no tacoma radiator. For my application, I had to have the inlet and outlet moved and the filler neck.
    I decided that I wanted to find a better option that didn't require modifications.
    License2Ill likes this.
  17. Feb 19, 2018 at 4:11 AM
    1997tacomav6
    Denver
    Ok, so I'm thinking of getting the Tacoma model cc1778 radiator,, do you have an down sides about these Champion Aluminum radiators?? Or should I look for a different company
  18. Feb 19, 2018 at 4:11 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
  19. Feb 19, 2018 at 4:26 AM
    Taco Addiction
    Taco Addiction We found Jimmy
    Houston, TX
    2004 Black TRD Offroad
    Kings, SCS Wheels and other mall crawling crap
  20. Feb 19, 2018 at 5:14 AM
    COMAtized99
    North Carolina
    99 DCLB v8
    I've run two of their radiators, a 280zx that was too small and the 4runnet one. Neither one showed any signs up giving up. Infact, the 4runner radiators lower tank took a direct impact from.a deer I hit. Bent the radiator back and struck the oil filter on my 2uz. The radiator is all kinds of twisted, but never leaked a drop. I don't have any complaints..
    As far as "extra cooling", once the engine is up to temp, your coolant temp should never go below the thermostat temp.
