Finally an all alluminum radiator for the first gen Tacos
Discussion in '1st Gen. Tacomas (1995-2004)' started by CHEF JEFF, Feb 18, 2018.
  1. Feb 19, 2018 at 5:22 AM
    Clearwater Bill
    Billy
    Largo Florida
    What was the reason for that failure rate?
    Physical damage to the tanks of some type?
  2. Feb 19, 2018 at 5:28 AM
    Sirmeeps
    Sirmeeps Well-Known Member
    Topsail Island Nc
    2000 Tacoma
    Tdi swap,LT
    I've never liked how low the radiator hung on my first gen in the stock configuration. Does this help with that at all?
  3. Feb 19, 2018 at 5:57 AM
    COMAtized99
    COMAtized99 Well-Known Member
    North Carolina
    99 DCLB v8
    The Bed is stock...ish
    Probably not.
  4. Feb 19, 2018 at 7:20 AM
    boostedka
    boostedka Well-Known Member
    James
    NM
    2013 DCSB 6MT, 2004 4runner
    I just read somewhere on here the other day that som guys use a 2wd radiator in the 4wd Tacoma’s because they do not hang down so far
  5. Feb 19, 2018 at 7:54 AM
    1997tacomav6
    Denver
    The top of the radiator is made of plastic and they crack for whatever reason, I've had 3 crack on me over the years, it's just a bad design by Toyota probably to cut on costs
  6. Feb 19, 2018 at 8:11 AM
    Dirty Pool
    Dirty Pool FLIES ON THE FRIES, KETCHUPS WATERED DOWN
    59.4 Miles, 56.67° NE Of Moab
    99 XCAB V6 MT TRD
    Dirty Pool rear bumper/air tank with integrated spare CV shaft storage, DP customized TJM front bumper, 8000 lb Ramsey/Technora rope, E-locked, Extended breathers with front diff catch can, PCV catch can, SAWs with DP heim joint seals, DP custom 6 leaf rear springs/Billies, DP custom skids, 2lo, Gray wire, Cap, Bed Rug, Black steelies, 01 Center console, Map lights, Disraeli gears
    And @License2Ill it's 4".
    https://www.tacomaworld.com/threads/aluminum-radiator.383062/page-4#post-17097736
    https://www.tacomaworld.com/threads/aluminum-radiator.383062/page-5#post-17098230
    License2Ill likes this.
  7. Feb 19, 2018 at 8:49 AM
    Clearwater Bill
    Billy
    Largo Florida
    Question was to OP who said he had to replace every 6 months. That's not normal.
    I'm not a particular fan of plastic tanks, but they've been around for decades and under normal use, most last at least 90-100k.
  8. Feb 19, 2018 at 9:53 AM
    COMAtized99
    North Carolina
    99 DCLB v8
  9. Feb 19, 2018 at 10:03 AM
    Dirty Pool
    99 XCAB V6 MT TRD
    Got that, to that end the Champion "hangs down" 4" less than the PR/4wd auto trans app and around 2" less than the man trans version. Am I missing something?
  10. Feb 19, 2018 at 10:05 AM
    COMAtized99
    North Carolina
    99 DCLB v8
    No, I think I'm the one that's confused... My B
  11. Feb 19, 2018 at 2:21 PM
    License2Ill
    License2Ill Woke like a Coma Toyota Tacoma
    Ian
    It's a dry heat thou, AZ
    2004 SC'd 5VZ DC 5spd 4x4 TRD.GOV
    Bailing wire & Duct tape
    @Dirty Pool
    What's your thoughts on a smaller 3 Row vs larger 1 Row (oem?) regarding cooling efficiency?.
    Seems the webz is in a pissing match over it... Understandably.
  12. Feb 19, 2018 at 4:09 PM
    1997tacomav6
    Denver
    I don't think there is a comparison if you look at the math. The stock radiator is only 1" thick with one core row and the champion is 2" thick I believe with 3 cores. Even though it's a bit smaller it covers
    probably 70 percent more surface area roughly because of its 2" depth not adding the 2 additional core surface area.
    OEM Large version 22x25x1= 550. One row
    CHAMPION. 18.8x25x2= 940. Three row
    I think this math is correct
    ToyRyd04 and License2Ill[QUOTED] like this.
  13. Feb 19, 2018 at 4:23 PM
    License2Ill
    Ian
    Yeah, I realize that it'll be beneficial being larger. But is also may hinder cooling (say crawling,) when the clutch fan is trying to pull decent air through while it's seeing increased air resistance through a thicker rad when going such a slow speed like 1 MPH while hitting 3000 RPM's. That's what I'm curious about...
    COMAtized99 likes this.
  14. Feb 19, 2018 at 5:18 PM
    Dirty Pool
    99 XCAB V6 MT TRD
    I would have no concerns what so ever.
    License2Ill[QUOTED] likes this.
  15. Feb 19, 2018 at 5:26 PM
    #35
    COMAtized99
    North Carolina
    99 DCLB v8
    This, to me is a concern. However, I feel like the stock fan, with shroud would be able to handle it. Myself, I would prefer a "2 row core".
  16. Jun 9, 2018 at 11:50 PM
    #36
    1997tacomav6
    Denver
    Haaaa, so the CC1998 4runner Radiator will not fit into the Tacoma even if you remove the hood rod support?
    You still need to have the inlet and outlet and filler sections moved??
    The inlet and outlet look like they line up but the filler is in a different area.
  17. Jun 10, 2018 at 9:39 AM
    #37
    COMAtized99
    North Carolina
    99 DCLB v8
    The hood support rod is not the issue. The hood supports on the bottom of the hoods are what contact the top of the radiator cap.
    1997tacomav6[QUOTED] likes this.
  18. Jun 10, 2018 at 9:54 AM
    #38
    1997tacomav6
    Denver
    Ok, so then the hood will not close at all or just rubs against it?
  19. Jun 10, 2018 at 9:58 AM
    #39
    COMAtized99
    North Carolina
    99 DCLB v8
    It would close, but you could tell there was pressure on the cap. Also, the inside edge of the hood rubbed the top, front edge of the radiator. In the year or so I had it, it was not an issue. However, I'm sure it's not something you want over the long haul.
  20. Oct 1, 2019 at 1:28 PM
    #40
    GreeGunc
    GreeGunc Full of regret
    Jacob
    North GA
    1st gen 3rz+18' inferno OR 6spd
    2lo mod. PIAA 510s. Green Floor Lights. Green dash swap. Axle dump exhaust. Husky floor mats. Moto metal mo970's. Shrockworks. Sundown sa-8. 9.5xrc. Kings
    Has anyone come to the conclusion of needing rubber mounts so the new aluminum rad can flex?
    Not exactly wanting to drop over $200 and break it after a couple wheeling trips
    GQ7227 likes this.
