Finally finished LEDS - cupholders, console, and bed lights
Discussion in 'Lighting' started by Oregon TRD, Jan 27, 2012.
  1. Feb 10, 2015 at 3:01 PM
    #661
    o0oSHADOWo0o
    o0oSHADOWo0o Just lurking in the darkness
    Shadow
    Va Beach
    2012 Double Cab Short Bed 4x4 TRD Sport
    Just a few LEDs...
    We used the Jedi mind trick on you...
    These aren't the posts you're looking for...:rolleyes:
  2. Feb 10, 2015 at 3:16 PM
    #662
    Oregon TRD
    Oregon TRD [OP] "GO DUCKS" Edition
    Ross
    Steel Panthers bathroom floor!
    2005 Mall Krawler
    6" Fabtech Lift, 35" Fierce M/T 17" Eagle Alloy Sim bead locks Naked girls in the bed 10.1" DVD head unit Two 7" Headrest Monitors PS2 in glove box
    :D
  3. Feb 11, 2015 at 8:05 AM
    #663
    MTopp
    MTopp Professional bear handler
    05 SR5 4x4
    trifecta tonneau, pop n' lock, Depo black bezel headlights, mb 352 wheels, 265/75r16 cooper at3s, visors, colormatched 2011 grille with raptor LEDs, much LEDs in and out Future/wanted: black valence, hood scoop, catback, CAI, 285/75r16s, OMD leaf pack mod
    Those work OK, but not great. Use:http://www.amazon.com/3M-03614-Scot...3442304&sr=8-13&keywords=3m+double+sided+tape
    Or similar 3M double sided mounting tape. That's what I used and they have been stuck on for about a year and are definitely not coming off unless I forcibly pull them off. I have to redo mine as the strips aren't as waterproof as they say
    Then use the things you linked to hold up the wires you ran under the truck.
  4. Feb 11, 2015 at 8:11 AM
    #664
    MTopp
    05 SR5 4x4
    Where do I get the pole thing to make a whip? Basically like a PVC pipe/stick piece?
    Gotta decide on RGB or blue...hmmmm
    But I also have a tonneau cover...hmmm. Bracket building time!
  5. Feb 11, 2015 at 9:14 AM
    #665
    Oregon TRD
    Ross
    2005 Mall Krawler
    Good tip :thumbsup:
  6. Feb 11, 2015 at 9:15 AM
    #666
    Oregon TRD
    Ross
    2005 Mall Krawler
  7. Feb 11, 2015 at 9:27 AM
    #667
    Aw9d
    Aw9d That one guy
    You can use a CB antenna if you have CB installed. While LED's are on it will screw with the Antenna but I've been told while they are off it doesn't mess with it. I honestly haven't tested and just repeating what I was told.
  8. Feb 11, 2015 at 10:09 AM
    #668
    Oregon TRD
    Ross
    2005 Mall Krawler
    Yep. These would work awesome also.
    Make a bed rail mount that these can screw into and you are set.
    http://www.ebay.com/itm/DUAL-SET-OF...2095&clkid=4007432939175053526&_qi=RTM1963930
  9. Feb 11, 2015 at 11:41 AM
    #669
    MTopp
    05 SR5 4x4
  10. Feb 11, 2015 at 11:49 AM
    #670
    Oregon TRD
    Ross
    2005 Mall Krawler
    Mine are about 4 foot
  11. Feb 11, 2015 at 12:28 PM
    #671
    MTopp
    05 SR5 4x4
    Alright, thanks, I'll search the eBay
  12. Feb 11, 2015 at 1:04 PM
    #672
    Aw9d
    Aw9d That one guy
    I got a 4 foot whip and I'm bashing the shit out of it in my parking garage at work. You may want to look into a quick release or a spring so you can pull it down and latch it to something.
  13. Feb 11, 2015 at 1:37 PM
    #673
    Oregon TRD
    Ross
    2005 Mall Krawler
  14. Feb 11, 2015 at 2:56 PM
    #674
    o0oSHADOWo0o
    Shadow
    Va Beach
    Just a few LEDs...
    I'm not an expert but...:rolleyes:
    If you wrap any kind of conductor (wires, circuit traces in LED strips) around an antenna, you are essentially putting a shield around it, especially if these wires are connected to the vehicle ground (-12V). I suspect you will definitely affect your ability to transmit and receive. If you know someone with a SWR (Standing Wave Ratio) meter or have one yourself, you can hook it up and see just how bad this will affect your antenna.
    They sure look cool though !!! :D
  15. Feb 11, 2015 at 3:16 PM
    #675
    Aw9d
    Aw9d That one guy
    I would think the same as well, and I do have a SWR meter. Just never out to test it yet. Hell I've had my CB for over a year and still haven't tuned it.
  16. Feb 11, 2015 at 3:21 PM
    #676
    Oregon TRD
    Ross
    2005 Mall Krawler
    Oh yeah it will def fuck with the signal. I just like using the firestik/or whatever cb antenna to make a light up antenna. *not for use with actual CB* :D
  17. Feb 11, 2015 at 3:24 PM
    #677
    o0oSHADOWo0o
    Shadow
    Va Beach
    Just a few LEDs...
    Did you ever hold a fluorescent light tube up to or near the antenna and key up the mic? :D
  18. Feb 11, 2015 at 3:25 PM
    #678
    Oregon TRD
    Ross
    2005 Mall Krawler
    No. Squeallllch
  19. Feb 11, 2015 at 3:29 PM
    #679
    o0oSHADOWo0o
    Shadow
    Va Beach
    Just a few LEDs...
    You know it'll light the bulb up right? Some guys I know used to take little neon bulbs and put them on the tip of their antennas. They would light up when transmitting.
  20. Feb 11, 2015 at 3:32 PM
    #680
    Oregon TRD
    Ross
    2005 Mall Krawler
    Nice. Look like ET's finger
