FINALLY!! Got my truck setup perfectly...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by sincitytaco, Feb 9, 2010.
  1. Feb 9, 2010 at 9:10 PM
    sincitytaco
    sincitytaco [OP] Well-Known Member
    Las Vegas
    Icons, Bilstein 5100, Rear Leaf TSB, 17x9 American Racing Chamber Teflon, 275/70/17 Goodyear
    I have had my VVME HIDs and Fogs for about a year now and they work great, but tonight it was a monsoon here in Vegas and they dominated in the down pour, hats off to them for making a cheap HID kit that works very well.
    I also installed a set of Bilstein 5100s front and rear. I set the fronts to 0 and installed a fatbobs garage polyurethane spring isolator with them. This gave me about 1 inch of lift. I also installed a 3/8 inch top plate spacer on the driver side to compensate for the taco lean.
    The truck soaks up every little bump and big ones as well. Expansion joints are sooooo smooth and big bumps it take slow and smooth. I am so happy I went with these and used the isolator as well, it provides for the perfect preload on the coil to give a great ride and a perfect lift. I am sitting dead level at all 4 corners and it rides fantastic.
    I will take pics tomorrow when it isn't raining. Oh yeah I also got a new set of pro comp 7089 installed as well.
  2. Feb 9, 2010 at 9:12 PM
    91Toyotabogger
    91Toyotabogger "Loud Tires Can Save Lives"
    North Carolina
    91 4wd 5sp manual Pickup Standard cab white
    Mud Tires, CD player, CB radio with PA speaker, De-badged, window decals, Flow Master 40 series
    sounds good looking forward to the pic..damn rain
  3. Feb 9, 2010 at 11:08 PM
    sincitytaco
    Las Vegas
    LOL, well I kinda like it since it almost never rains here in Vegas. It rains so little that people look forward to it, its funny. I think it is going to rain tomorrow though as well. Ill take some pics regardless.
  4. Feb 9, 2010 at 11:48 PM
    john32
    john32 Well-Known Member
    Seaside, Ca
    4x4 Reg cab 2.7L SR5 Manual
    diff breather
    what are spring isolators? and what do they usually run price wise? how come you set you billies at 0 and not a lil higher?
  5. Feb 9, 2010 at 11:49 PM
    john32
    Seaside, Ca
    diff breather
    sorry for drilling you with questions, im just curious because im starting to look for a lift for my 01 taco
  6. Feb 10, 2010 at 12:00 AM
    JohnnyGato
    JohnnyGato God of Thunder ...and Rock N' Roll!
    Vegas Island
    04 TRD SR5 V6 4x4 Off Road
    Limo tint, Sirius/XM radio, Wet Okole's, Weathertech's, Rhino Lining, blacked out badges, shorty antenna, painted speaker (tweeter) covers, blue LED running lights, Icon 3" lift, Pro Comp 17" 7005's, 33" (285/70/17) Good Year MT/R's with kevlar.
    I wanna 3" lift for my 04. I'm in Vegas too. I'm having a ball driving through the puddles!!!
  7. Feb 10, 2010 at 8:51 AM
    sincitytaco
    Las Vegas
    These are spring isolators http://www.tacomaworld.com/forum/2n...ly-got-my-truck-setup-perfectly-new-post.html
    they give approx 1 inch of lift. I did not set the billies higher because I did not want a full 1.75 inches of lift from preloading my spring. I wanted to maintain a smoother ride. My truck seems to net more lift from lifts than most other tacomas so I really got like 1.6-1.75 inches from just the isolator, but it is only supposed to give 1 inch of lift.
    I will take pics today so you guys can see specifically, but the ride is amazing and smooth as butter, it took me a year screwing with my truck and I finally found a great ride.
    The OME setup I had with 885s and OME struts was too stiff, then I put on Icons and they were too stiff, then eibachs and they were a alright but not soft enough, and now the setup I have is perfect no harsh at all and is able to soak up everything.
  8. Feb 17, 2010 at 11:07 PM
    sincitytaco
    Las Vegas
    Sorry it took so long for me to post the pics, I have been hella busy lately with work:
  9. Feb 18, 2010 at 12:19 AM
    eight3one_offroad
    eight3one_offroad Honey your two French Fries short of a Happy Meal.
    Richard
    Santa Cruz, California
    TRD Sport 4x4 with a few things.
    Optima Red Top 34R, OME 885 / N140S + 5100 rear, TSB leaf pack, Camburg Ball Joint UCA, Wheelers Diff drop, AEM Brute Force Intake with filter wrap, Summit Super Turbo muffler, Llumar 5% tint, Pioneer single din head unit, PIAA 510 Ion Crystal Fogs in stock location, Sonar LED tails. Sway Bar removal. Charcoal filter delete. Stant 11509 Locking Gas Cap.
    Isn't it 1/4" top plate spacer to fix the taco lean? why did you pick 3/8's? Just wondering...
  10. Feb 18, 2010 at 12:46 AM
    TRDsport253
    TRDsport253 Well-Known Member
    Fife, Wa
    05 PreRunner TRDsport
    TRD Cold air TRD Cat-back
    Nice. What are the specs?
  11. Feb 18, 2010 at 1:03 AM
    Dellosa89
    Dellosa89 Love peace and Taco Grease
    Brian
    Murrieta CA
    07 Prerunner TRD Off Road
    Fox 2.5 Coilovers, Camburg 1.25" UCA's, Icon RR, Icon aal,EVS foam bump stops, Borla Catback, HID Headlights and fogs, Defiant light bar, 3 hella 700 hid, Satellite Radio, Sony hu with 10'' sub, custom jetski rack, TRD seat covers, secondary air filter removed.
    Nice man, looks sick, keep up the good work.
  12. Feb 18, 2010 at 1:06 AM
    Dellosa89
    Brian
    Murrieta CA
    Also are those 265 tires they look bigger.
  13. Feb 18, 2010 at 2:22 AM
    saf023
    saf023 Well-Known Member
    East Coast
    2nd Gen TRD Sport DCSB 4X4
    The above link takes you back to this thread.
    How difficult is it to install "spring isolators"? Do you have to compress the spring?
  14. Feb 18, 2010 at 8:34 AM
    sincitytaco
    Las Vegas
    Because my truck leaned BAD. It actually still sits lower on the driver side by about 1/8 inch even with the bigger spacer. I thought it might be because the I switched up the front coils, but from the research I have done on here both the left and right coil are the same regards of the color markings.
  15. Mar 9, 2010 at 11:29 PM
    sincitytaco
    Las Vegas
    Sorry it took so long to reply, but they are 285/70/17 tires. That is why they look so big, lol.
  16. Mar 26, 2010 at 8:19 AM
    Zac808
    Zac808 Custom User Title
    Zac
    Viva Las Vegas
    08 TRD DC SB 4x4
    In my sig
    Hardest part is getting the strut assembly off the truck. Yes, you do need a spring compressor.
  17. Mar 26, 2010 at 11:18 AM
    T0LLPHR33
    T0LLPHR33 Well-Known Member
    S1N C1TY...(from Hilo, HI)...
    BSP TRD Off-Road
    APR X-1 | TRD CAI w/Clear Cover | TRD Short Shifter w/ TRD "RED" Shift Knob | SGII w/Blendmount| Snugtop SL w/KeyLess Entry | 5% Tint | Pop-n-Lock | Bosch Icon WB | S2K Antenna | HRM | LS 8K Projectors w/BSP HLM & 8K Fogs w/FLM | Debadged |Tinted Tails | Black Weathertechs | MX RGM & RBM | Optima Red Top 35 | Gatorback Belt |
    looking really good bro...keep up the hard work cause its paying off...
    btw were you driving down st. rose heading towards pecos about 2 days ago...if so truck looked sick as it past me...:)
