Finally had time to install my budget system today!
Discussion in 'Audio & Video' started by creedler, Mar 30, 2011.
  1. Mar 30, 2011 at 8:10 PM
    creedler
    creedler [OP] Well-Known Member
    Max
    Eugene, Oregon
    Stock for now
    Old build in sig
    I've had the system laying around for a month or so and finally had time for installation with some help from TW and my friend Grant!
    Parts used:
    Pioneer 3200BT with bluetooth no navi.
    Scosche double din dash kit and Metra wire harness
    Axxess steering wheel control interface
    Kicker 10ZX750.1 and Kicker Z series Amp Kit
    10in. Solo Baric L7 Sub
    Custom built sealed box
    Overall I'm very happy with the installation it was somewhat of a budget build. As you can see the box is a little bit to high in the rear for the seat to fold all the way down (originally designed to hide the sub to deter theft).In the future I'm hoping to put aftermarket speakers powered by another amp and rebuild the box. Thanks TW for showing me how to tap into my factory backup camera to get it on both screens! Let me know what you guys think...
  2. Mar 30, 2011 at 8:13 PM
    creedler
    Max
    Eugene, Oregon
    Stock for now
    Old build in sig
    sorry pics didn't work first time
  3. Mar 30, 2011 at 8:37 PM
    amthree
    amthree Active Member
    Washington State
    2007 PreRunner TRD
    nice job man:D
  4. Mar 31, 2011 at 1:08 PM
    478DblSport
    478DblSport Thermonuclear Protection
    Byron, GA
    07 Silver Streak Mica PreRunner DC TRD Sport
    | EXTERIOR | DiamondBack SE Tonneau Cover, Havoc HS2 Hoop Steps, Tailgate Hose Clamp Mod, Shortened OEM Antenna, DeeZee Bed Mat | INTERIOR | Flyzeye V2W (Amber/White/Amber), RAM Mt A-Pillar Mod, Audio: Pioneer AVH-X5700, PDX-5 (119Wx4+410W), Polk Audio MM6501 (F) & MM651 (R), JL Audio CP108LG-W3v3 (Sub), w/Monster, Rockford, & Streetwire cabling, Metra Dash Kit.
    Nice set up man. Like your wallpaper.
  5. Mar 31, 2011 at 5:08 PM
    2chains
    2chains Well-Known Member
    Calgary, Alberta
    2010 Tacoma DC LB 3" Revtek lift
    3" Revtek lift, k&n 63-9025 intake, tailgate debadge, OEM Bed mat, decals gone. helo black max 6 bs 4.5 os-12,duratrac 285 70 17,smittybilt light bar, kc slimlites, pioneer pb3300 bt, window tint, weathertech digfits, raider lorider elite tonneau, at2525xl,
    Nice job! Hard to tell... does unit have USB in front? How hot does the amp run? Looking for similar amp and same install location under seat...
  6. Apr 2, 2011 at 12:13 PM
    creedler
    Max
    Eugene, Oregon
    Stock for now
    Old build in sig
    unfortunately the unit only has a front usb. I wanted it to look as clean as possible so I'm using an 32gb SD card to play my music. The SD card is right next to the usb slot. I would have likeed to put small risers under the amp to improve air flow but I already had to trim the metal bar to move your seat back and forth for the amp to fit. It probably has only 1/8in. clearance from bottom of the seat. Anyways to answer your question the amp has not gotten abnormally hot, then again I've only had it in there for a few days ;)
  7. Apr 2, 2011 at 12:14 PM
    THXEY
    THXEY Panda Jerk
    Jacob
    San Diego
    2013 Subaru WRX
    STi Short Shifter.OEM floor illumination kit. Rally Armor Mud Flaps. BC BR Coilovers. Invidia N1 Exhaust
    Nice L7! i have a 12" L5! they hit so hard!
    BUT i definitely wouldnt rest the face of the sub against the seat. especially when it starts wobblin! :D
  8. Apr 3, 2011 at 7:28 AM
    2chains
    Calgary, Alberta
    the more i look the more i like this unit!! I see you can also change back light colors and import your own wallpaper, does it match factory amber well?...not sure about the power handling works. says 50w max rms so any idea on max size front speakers?
  9. Apr 4, 2011 at 1:25 PM
    creedler
    Max
    Eugene, Oregon
    Stock for now
    Old build in sig
    the amber matches up pretty well. Most all aftermarket stereos put out 50w a channel with 4 channels but yeah that is peak power not rms.
