Finally, my $400 system is installed and running
Discussion in 'Audio & Video' started by ratcityrain, Sep 20, 2015.
  1. Sep 20, 2015 at 10:27 AM
    ratcityrain
    ratcityrain [OP] Well-Known Member
    Seattle, WA
    2017 Double Cab Off Road
    OEM Running boards |oemassive headlights | winjet tail lights | led lighting | hid headlight & fogs | oem tri-fold Bed cover | Custom dual JL Audio 10tw3-d4 sub box and custom amp rack | black off road wheels | painted oem grille | jbl door speakers |
    Finally made my sub box for my '15 access cab. It isn't anything special, but it was a nice way for me to have a single 10 and an amp in such a limited space. Now that it is in, i'll probably take time to make a new one later that is more appealing to look at, but for now this works.
    Total investment into my system is $400 (for wiring, sub, amp, door speakers, loc's and harnesses). Not too shabby and it sounds good.
    I have the amp ch 1 & 2 bridged to left door and ch 3 & 4 bridged to right door and ch 5 to the sub. Sounds amazing for what it is.
    Door speakers are Kenwood KFC-P709Ps 6.5" components. I paired these with a set of Scosche SAT69 speaker adapters to take the 6x9 to 6.5". This door kit is made for a 4 runner, but they worked without any issues or modifications in my tacoma
    Subwoofer is a PowerBass S-1004D. Amazing sub for only $55. Sounds great and no need for more than 1 in a access cab
    Amp is a Rockford Fosgate R600X5. This was the 3rd amp I got 'cause I was trying to be cheap. First amp was a SSL amp, but went into protection when the bass hit even though the manufacture claimed it was a 2 ohm stable amp. Then I purchased a PowerBass 5 ch amp, but that overheated and went into protection even when nothing was connected to it so I think this was just a bad amp so I just spent the extra money to get this Rockford and I am so glad I did.
    To connect the amp I used a Best Kits BHO1761 and Best kits BHA1761 to connect to the factory head unit. I connected 2 PAC SNI-35 Line Out Converter. One to the front speakers for the doors and one to the rear speakers for the sub.
    All in all, not a bad system for a small budget. I am happy with what I got so far. The sub box has a lot of angles 'cause I wanted to keep the back bottom area open to be able to access the seat belts when someone is in the back. Also, box size is .75 cu ft
  2. Sep 20, 2015 at 3:26 PM
    azsean
    azsean Well-Known Member
    sean
    HELL ... aka mesa,arizona
    2013 black prerunner trd sport
    gosh.. where do I start, 18x9’s on 275-65 ridge grapplers. Bilsteins, clazzio leather, audio consists of stereo integrity,fosgate power amps,sundown audio, hybrid audio. Plus more...
    looks great !!!! love the amp idea. easy access to tweak on the settings too :)
  3. Sep 20, 2015 at 3:42 PM
    GreeGunc
    GreeGunc Full of regret
    Jacob
    North GA
    1st gen 3rz+18' inferno OR 6spd
    2lo mod. PIAA 510s. Green Floor Lights. Green dash swap. Axle dump exhaust. Husky floor mats. Moto metal mo970's. Shrockworks. Sundown sa-8. 9.5xrc. Kings
    Looks sweet bud, made my own to. Just a option, but instead of screws I used finish nailer and glue.
  4. Sep 20, 2015 at 5:06 PM
    Revelations
    Revelations Well-Known Member
    2014 MGM DCSB
    why didn't you carpet it?
  5. Sep 21, 2015 at 12:21 PM
    Chopper678
    Chopper678 Professional Threadjacker
    Devin
    Texas
    '07 SR5 PreRunner V6 DCSB
    5100s@0.85"+Eibachs, Toytec 2" AAL, Weathertech floor liners, WO seat covers, UltraGauge, ammo box mod
    That's cheap for an audio setup. Subd
  6. Sep 21, 2015 at 1:39 PM
    azsean
    sean
    Right !!! I'm into mine for thousands and still sounds like crap !!!
  7. Sep 21, 2015 at 1:39 PM
    azsean
    sean
    Nice job on the box btw
  8. Sep 21, 2015 at 4:59 PM
    manethon
    manethon TTAS
    Toronto
    Many
    nice work man! What i have been telling people for years, you don't have to go spend thousands of $$$ to get a great sounding system. In the end sound matters, not the name of the brand .... now if it was BOSE or BOSS or any of those id sing a different tune
  9. Sep 23, 2015 at 6:38 AM
    timothom
    timothom Well-Known Member
    2014 Tacoma Access cab sr5
    Kenwood DMX7705S PrecisionPower Phantom 900.4 Alpine type-r 8" Image Dyanmics CXS64.2
    nice job
  10. Sep 24, 2015 at 10:23 AM
    ratcityrain
    Seattle, WA
    I did use glue, but ended up using screws to make it stronger and by habbit. Finish nails would have been easier to fill the holes before painting though
    I didn't carpet because I had the black paint and primer already sitting around so I just used that.
    Thanks everyone. I don't built many sub boxes so I didn't want to get to tricky with this one so I think in the end it turned out pretty decent for what it is and only used half a sheet of mdf so that was nice. I'll probably get fancier later, but I just wanted to get a system in there. I want to play with fiberglass next, but just need to pull the trigger and do it
  11. Sep 24, 2015 at 12:17 PM
    manethon
    manethon TTAS
    Toronto
    Many
    very nice work man,
    How is the amp vented?
  12. Sep 29, 2015 at 11:46 AM
    ratcityrain
    Seattle, WA
    Through the top where the amp is exposed and what you can't see is that the there is 2-3 inches of space between the amp and the sides of the box. There is also no bottom. I have been monitoring it to see if it gets too hot and if it does I will install some mini fans to blow the air out through the bottom where it is open
