Finally pulled the trigger on a lift!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JW87, Mar 3, 2018.
  1. Mar 3, 2018 at 9:58 AM
    JW87
    JW87 [OP] Well-Known Member
    JW
    Richmond,VA
    2015 TRD Sport 4x4 DCLB
    American Racing black bajas with Cooper RTXs 265/70/17. Black Depo tail lights. LED interior, license plate and reverse lights.Debadged. OME 885 coils and Dakar leaf packs. OME Nitros front and back.
    After a couple years of BSing i finally decided on a lift. I’m going with ome 885s and 5100s up front and dakar leaf packs and 5100s in the rear. Anyone running this same thing I would appreciate your feedback.
    Hornedfrog53, henryp and m603holden like this.
  2. Mar 3, 2018 at 10:19 AM
    REDdawn6
    REDdawn6 Well-Known Member
    Redlands CA.
    2011 Tacoma TRD 4x4
    If you don't have a lot of heavy shit on your ass end. Remove the top overload leaf before installing.. Replace the Dakar eye bushing that is pre installed ,or come with, to a nice set or bushings . You need two sets, one front and rear .. Gl
  3. Mar 3, 2018 at 10:21 AM
    JW87
    JW
    Richmond,VA
    I have a tool box loaded down
  4. Mar 3, 2018 at 10:24 AM
    REDdawn6
    Redlands CA.
    2011 Tacoma TRD 4x4
    How much weight? You could always go back and remove later... I only have a spare, it's a tiny bit rough, not bad but had I known I would have removed before
  5. Mar 3, 2018 at 10:30 AM
    REDdawn6
    Redlands CA.
    2011 Tacoma TRD 4x4
    Congrats on the lift and post pictures after!!
  6. Mar 3, 2018 at 10:32 AM
    Ant1-Hero
    Ant1-Hero Well-Known Member
    2013 Tacoma TRD OFFROAD
    Can you post a link for the 885's and dakars that you are using for the 3 inch lift, i already have 5100's in the front and rear
  7. Mar 3, 2018 at 10:32 AM
    JW87
    JW
    Richmond,VA
    Thanks. Will do. The toolbox probably weighs 150 loaded.
  8. Mar 3, 2018 at 10:32 AM
    Bastek
    Bastek Average Member
    Seb
    SI NY
    '17 OR dcsb
    KDMaxP10, plastidip
    If we are not talking about Add a Leaf:
    The new Dakars come in two versions, Medium and Heavy. With Medium, there isn't a leaf to be removed anymore, and they are "good" up to 600 lbs constant weight. So I've researched thus far...
    Then there is an additional leaf you can buy to convert to heavier use.
    Make sure you speak to your vendor about what I've mentioned above. As far as I've looked into it, it were older Dakars that a 3rd leaf was removable.
    Good luck with your lift.
    REDdawn6[QUOTED] likes this.
  9. Mar 3, 2018 at 10:34 AM
    JW87
    JW
    Richmond,VA
    I believe when it settles it will be more of a 2” lift. Coil springs part number is 2885
    The dakars are EL095r
  10. Mar 3, 2018 at 10:35 AM
    JW87
    JW
    Richmond,VA
    I believe the dakars are the hd
  11. Mar 3, 2018 at 10:36 AM
    REDdawn6
    Redlands CA.
    2011 Tacoma TRD 4x4
    Shit, you are absolutely right. I forgot about the changes.. Op what leaf pack did you get? Old style HD, MD?
  12. Mar 3, 2018 at 10:36 AM
    Ant1-Hero
    My truck is Canadian so it comes with 4 leaf springs already, which is the same as the TSB in the states, would that be any higher?
  13. Mar 3, 2018 at 10:38 AM
    JW87
    JW
    Richmond,VA
    Mine has for leafs too
  14. Mar 3, 2018 at 10:39 AM
    JW87
    JW
    Richmond,VA
    They said it should settle to around 2” up front and 2.75” rear. So I will still be close to factory rake.
    REDdawn6 likes this.
  15. Mar 3, 2018 at 10:43 AM
    tacomabro69
    tacomabro69 Well-Known Member
    Lifting your tuck is the best part of owning one! I hear nothing but good things about the bilstein 5100s!
  16. Mar 3, 2018 at 10:44 AM
    Hornedfrog53
    Hornedfrog53 Well-Known Member
    2020 TRD PRO
    I have the same set up but with the new dealer recall packs and wheelers add a leaf. It sits perfectly even, even after the Demello bumper install. Combined with wheelers super bumps, it rides like a dream now.
    JW87[OP] likes this.
  17. Mar 3, 2018 at 10:58 AM
    JW87
    JW
    Richmond,VA
    That’s what I want to hear
    Hornedfrog53[QUOTED] likes this.
  18. Mar 3, 2018 at 11:35 AM
    REDdawn6
    Redlands CA.
    2011 Tacoma TRD 4x4
    Oh yeah OP. Wheelers superbumps!!!
    Hornedfrog53 likes this.
