finicky start... starting small
Discussion in '1st Gen. Tacomas (1995-2004)' started by Micherie, Aug 17, 2008.
  1. Aug 17, 2008 at 6:56 PM
    Micherie
    Micherie [OP] Active Member
    Eugene, Or
    Taco Negro
    Tested battery cells today... two good, three fair and one bad. sometimes it takes forever to catch on the turn over. this is intermittent but frustrating and somewhat embarrassing... 'aw, poor sap's car wont start'.
    could it still be the battery? would adding acid or water to the bad cell revive it? (i've got some lying around) or... should i move on to plugs, alternator or ingnition? i have a fairly decent grasp on how an engine runs but I'm flat broke and cant take it to a shop. seems ridiculous anyway for something so simple.
    side note: threw a P0420 code recently but dont have the funds for a new exhaust just yet. i dont think this is related but maybe there's an exhaust back up that is interfering with combustion? i dunno. this is where the 'fairly' comes in. just throwing ideas out there.
  2. Aug 17, 2008 at 7:03 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Your battery has a bad cell. Replace it.
    Your code could be triggered from a bad O2 sensor. Do you have any exhaust leaks?
  3. Aug 17, 2008 at 7:08 PM
    Micherie
    Eugene, Or
    Taco Negro
    i have always thought that i could hear a leak but i'm not positive. i suppose starting with the sensor would be starting small eh? lol
  4. Aug 17, 2008 at 7:10 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Look around your exhaust for black soot around the joints. Check the exhaust manifold area, use a mirror to look under it. Most of the time its a bad O2 sensor. :) Just noticed you have an 1995. What motor? The 2.7?
  5. Aug 17, 2008 at 7:19 PM
    Micherie
    Eugene, Or
    Taco Negro
    not sure. i know i have the newer motor... not the ones used in the previous type pickups. 16 valve. i dont have an owners manual. might wanna get one of those.
    ps. thanks for the advice ;)
  6. Aug 17, 2008 at 7:45 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    I've seen bad and/or low batteries do weird things to electronics in cars before. Get the battery replaced & that'll reset the computer ...and go from there.
    If you have a problem elsewhere - the CEL & code will be back.
