Firestick antenna won't stay screwed in
Discussion in '1st Gen. Tacomas (1995-2004)' started by BrotherBudro, Jun 29, 2012.
  1. Jun 29, 2012 at 7:37 PM
    BrotherBudro
    BrotherBudro [OP] Well-Known Member
    David
    Nashville
    2017 SR5 Access Cab, V6 4X4
    Leer 100XR, Dual Battery, Dog Platform, Sleeping Platform, Ham, CB, Light Bar, Rear Lights,
    Hey guys,
    This really isn't a question super related to a 1st gen taco, but that's what I drive so here goes...
    I have my firestick cb antenna mounted in the back where the tailgate latch is. I also have a heavy duty firestick spring so that the antenna doesn't break off. But I have noticed after driving (even fairly short distances) the antenna becomes unscrewed from the spring. It hasn't fallen off (yet) but I fell like that is a real danger. Do you guys have any ideas how to fix this?
    I feel like there has gotta be something for this, like loctite or something.
    Thanks for your help
  2. Jun 29, 2012 at 7:46 PM
    BrotherBudro
    David
    Nashville
    I google'd nylock bolt but i don't see how that would fit into my situation
  3. Jun 29, 2012 at 7:47 PM
    CayucosTacoma
    CayucosTacoma Just think outside the Yota
    San Luis Obispo/San Jose
    2004 Double Cab 4x4
    Specs in the Build Thread
    Lock washer?
  4. Jun 29, 2012 at 7:48 PM
    pippen
    pippen that was'nt a vitamin!!
    Pippen
    Eastern NC
    04 PreRunner Ext.
    Yea I was gonna say loctite, or even maybe some teflon tape to make it tighter. And like whippersnapper02 said if theres a nut you could try a nylon type one.
  5. Jun 29, 2012 at 7:49 PM
    H Bomb
    H Bomb Well-Known Member
    SAS'd 92 Pickup/08 SR5 Tacoma
    I tightened mine down with a wrench... Seems to work for me.
  6. Jun 29, 2012 at 7:53 PM
    BrotherBudro
    David
    Nashville
    Would that work though? Because the antenna is the male end, and the spring is the female.
    But I like that idea
  7. Jun 29, 2012 at 7:55 PM
    Supra TT
    Supra TT Supercharged Lifter
    Eric
    Indiana
    2000 SAS D60 F/R Supercharged
    Supercharged on One Tons
  8. Jun 29, 2012 at 8:02 PM
    CayucosTacoma
    2004 Double Cab 4x4
    I don't see why it wouldnt. Just get a big enough washer to fit around the male and tighten it a lot
  9. Jun 29, 2012 at 8:03 PM
    BrotherBudro
    David
    Nashville
    Only thing i'm worried about with loctite is what do i use to get it off, if for some reason I needed to take the antenna off (car washes etc.)
  10. Jun 29, 2012 at 8:04 PM
    H Bomb
    Get a quick disconnect. Then you can permanently screw the antenna into the quick disconnect. It will be removable that way.
  11. Jun 29, 2012 at 8:11 PM
    Supra TT
    Eric
    Indiana
    Locktite is removable. It's designed that way. Though the locktite I posted is designed for permanent use. Just get Blue locktite.
  12. Jun 30, 2012 at 7:46 AM
    BrotherBudro
    David
    Nashville
    I'm an idiot, i don't know what i was thinking. That will work. I'm heading off to lowes today to pickup some lockwashers and maybe some loctite.
    Thanks everybody
  13. Jun 30, 2012 at 8:23 AM
    CayucosTacoma
    2004 Double Cab 4x4
    Let us know how it works out
  14. Jun 30, 2012 at 8:59 AM
    Ridgerunner
    Ridgerunner Well-Known Member
    Frank
    Rocklin, Ca.
    2001 prerunner doublecab limited
    2001 with; cat-back side-swept twin exhaust, elbow mod, Westin bullbar with Hella 450 driving lights, Snugtop XTR camper shell, TRD off-road 2x4-black beauty.
    locktite on an antenna? no. it will block the electrical connection between the base and antenna.
    Just torque it down over a lockwasher then 4-5 tight turns of electrical tape (preferably super-88) over the seam.
  15. Jun 30, 2012 at 9:05 AM
    H Bomb
    Do this. And, if you want to be able to easily remove it from your truck, put it on a firestik quick disconnect. I remove mine every time I park in my garage and it works perfectly.
  16. Jun 30, 2012 at 9:59 AM
    CayucosTacoma
    2004 Double Cab 4x4
    Also consider the fold over mount from fire stick
  17. Jul 1, 2012 at 10:44 AM
    BrotherBudro
    David
    Nashville
    So i got 2 lockwashers, one on either side of the spring, got out the ole wrench. and 150 miles later, still tight as ever. Thanks for your help guys
