Firestik cable too short.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Salt, Jul 4, 2015.
  1. Jul 4, 2015 at 8:50 AM
    Salt
    Salt [OP] ...
    Lyons, Colorado
    12' DCORSB TRD
    SnugTop XV with yakima rack. Factory Cab roof rack. Full bedrug. Debadged. Full OME suspention kit, 866's & Dakars. SPC UCA's. Slee Sliders. ARB front bumper w/ M8000 Warn winch. FJ TRD Wheels. Cooper ST Maxx, 255/85r16
    My 18" firestik coax is too short. Do they make a 25" version?
    If I splice the cable to extend it will that cause issues?
    Thoughts?
    Salt
  2. Jul 4, 2015 at 8:54 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Lengthening really isn't an option as it introduces a point for interference. I would find a 25' cable.
  3. Jul 4, 2015 at 10:28 AM
    TXPROMAN
    TXPROMAN Well-Known Member
    Martin
    NY
    2012 TX PRO TACOMA
    18 feet is required to keep wavelength. For 11 meter radios. It will change your SWR If you make it longer. You might have to trim your antenna.
  4. Jul 4, 2015 at 11:02 AM
    Salt
    Salt [OP] ...
    Lyons, Colorado
    12' DCORSB TRD
    Hmmm...so what cables are you guys running for a Tacoma with a rear bumper mounted antenna.
    Thanks TXproman.
    Salt
  5. Jul 4, 2015 at 11:03 AM
    Salt
    Salt [OP] ...
    Lyons, Colorado
    12' DCORSB TRD
    I have a 18" firestik cable but upon first look it's way too short based on my routing plan.
  6. Jul 4, 2015 at 12:53 PM
    potstech
    potstech Well-Known Member
    Midlothian, Va
    2013 DCLB
    Do not splice but find a cable that is made to extend the current one. They are available or a good technician can make you one. That way you do not get one longer than what you need. Test it before using it for long conversations. Have done this many of times while employed as a communications technician. Or get someone to just put a longer cable on the antenna for you. Again not hard.
  7. Jul 4, 2015 at 2:22 PM
    bubbabud
    bubbabud Well-Known Member
    Bob
    Tonopah AZ
    13 tacoma TRD Off road.ARE shell no rust anywhere period.
    2 in spacer lift front 2, in AAL rear [tundra leaf] , flip up tow mirrors, ARE shell electric brake controller and cooper ATP 265/r70x16 tires on stock TRD wheels
  8. Jul 4, 2015 at 3:40 PM
    Salt
    Salt [OP] ...
    Lyons, Colorado
    12' DCORSB TRD
    Yes, but I'm sure there are several different ways I haven't considered. I was planning to go from the rear passenger mount on my CBI bushmaster bumper, under the truck up the passenger side to the engine bay, then across the bay to main electrical boot located near the drivers front wheel. Is there another access into the cab or alternate route that I should consider?
    This is new to me...obviously. :) I've been to every single auto parts store and Radio shack in the area...nothing.
    I know that Firestik makes a coupler called the "Barrel Connector" but I haven't found it online yet. Yes, I believe PL259 is what I need, plus the extension cable.
    (EDIT) I think I found it on Amazon.
    Suggestions welcome. I'm clearly grasping and need to complete this next week, as the week after we are headed to the FJ Summit.
    Cheers.
    Salt
  9. Jul 4, 2015 at 6:10 PM
    Canoehead
    Canoehead Well-Known Member
    Duncan
    Dartmouth, NS Canada
    2007 DCSB, lots of scratches
    Rearview mirror upside down mod
    A few things:
    I have been researching this question on these forums in anticipation of my first radio install later this month.
    I think it is best to avoid the engine bay when routing the antenna coax, to avoid interference.
    There is a hole in the floor of your doublecab. Driver's side, behind the front seat. You can see it from underneath, inside from the frame. There is a round rubber grommet filling the hole. Others report that this is an ideal point of entry to the cab for the coax, make a hole in the rubber for the coax and run it under the carpet to your radio.
  10. Jul 4, 2015 at 7:29 PM
    potstech
    Midlothian, Va
    2013 DCLB
    Just input CB coaxial cable and look for the barrel or a cable with a male on one end and a female connector on the other. No need for the barrel connector. Or go to a big commercial truck stop and they may have one. Radio Shack is going out of business and has very little left.
  11. Jul 5, 2015 at 4:46 PM
    Salt
    Salt [OP] ...
    Lyons, Colorado
    12' DCORSB TRD
    Thank you Canoehead! I found the hole, not sure how I missed that yesterday. That should solve all my woes. Cheers!
    Salt
  12. Jul 5, 2015 at 7:02 PM
    Canoehead
    Duncan
    Let us know how it works out.
  13. Jul 5, 2015 at 8:17 PM
    Salt
    Salt [OP] ...
    Lyons, Colorado
    12' DCORSB TRD
    Worked like a charm. 18' coax was more than enough. I still need to mount the antenna and thread the connection on the in-cab end but otherwise i'm good to go. SWR meter should arrive Tuesday. Thanks again.
