Firestone air bag kit
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tacoma12, Mar 1, 2016.
  1. Mar 4, 2016 at 5:00 AM
    Mattynokes
    Mattynokes Well-Known Member
    Madison, WI
    18' BLACK Off Road DCSB
    Prinsu Toprac TRD Beadlocks Century Shell
    Mine are on their way. I've heard nothing but good things.
    Tacoma12[OP] likes this.
  2. Mar 4, 2016 at 1:56 PM
    Siblue
    Siblue Well-Known Member
    So Cal
    25 Tundra TRD pro
    I think I was looking at that kit on eBay.
    Looked this morning and was gone.
  3. Mar 18, 2016 at 5:52 PM
    Tacoma12
    Tacoma12 [OP] Well-Known Member
    Clint
    Mid Michigan
    2012 Tacoma 4x4 dbl cab LB
    stock
    I've got my firestone kit all installed guys.
    Took about 4 hours, air tools help
    Driver side was a little more tough with less room cause of gas tank.
    I did install the additional bracket for my lift height and. Totally understand why they want them, being the bags sit offset to the inside the additional bracket carries the load down to the axel.
    So heavy loads will be more secure by resting on something solid while going down the road.
    Thanks for the insight and help.
  4. Mar 18, 2016 at 6:08 PM
    gmann1972
    gmann1972 Well-Known Member
    Greg
    Rhode Island
    2013 tacoma SR5 DCSB
    Can you give more detail on the additional brackets...I have a 2.5" lift, but I didn't install any additional brackets...
  5. Mar 18, 2016 at 6:50 PM
    jbrnigan
    jbrnigan Well-Known Member
    Midwest
    2015 TRD Sport, 4X4, 4.0L, Auto - Access Cab
    Be it water or air, a load shifting will not force air pressure to the side with less weight if you have a single line set up. It is simple physics! Yes, air will transfer from the loaded side to the side with less load, but the internal pressure will remain constant everywhere within the system. The actual air pressure in both the compressed bag and the extended bag will be exactly the same. The result is that you have a constant rate spring with each side having the same load carrying capacity. Not looking to get into a pissing contest, but if you are going load one side of your truck with 500 lbs more that the other, than separate fill valve will allow you to compensate. If you are towing a trailer where the weight is centered or equalized on the hitch or equally distributed in the bed of the truck, a tee or equalizing valve will suffice. Firestone and air ride sell tees for their systems.
  6. Mar 18, 2016 at 8:16 PM
    Tacoma12
    Clint
    Mid Michigan
    stock
    Look into ride rite bracket 2507. Because your inner bracket should be resting on the axel, if it's not the 2507 bracket extends down to the axel to create a more ridged set up.
    Honestly any plate steel 3/16 thick or thicker drilled to match kit bracket cut to length will work.
  7. Mar 18, 2016 at 9:28 PM
    EdinCincinnati
    EdinCincinnati Well-Known Member
    Ed
    Ohio
    2014 4x4 TRD OR
    rear axle airbags are awesome if you carry any decent weight. I've had mine for 70K miles - worthy investment.
  8. Mar 19, 2016 at 4:09 AM
    gmann1972
    Greg
    Rhode Island
    Do you mean bracket 2407...
  9. Mar 22, 2016 at 2:49 PM
    Tacoma12
    Clint
    Mid Michigan
    stock
    Nope I think 2507 is correct, there are a number of brackets depending on lift height. The 2507 was for my 2 in block added height.
  10. Mar 22, 2016 at 2:51 PM
    gmann1972
    Greg
    Rhode Island
    ok...I looked up the bracket you describe, but I could not find it anywhere. The set up I have is P/N 2407, I guess there is an additional bracket of 2507 that I may need?...I will need to look further into this
  11. Mar 22, 2016 at 2:54 PM
    Tacoma12
    Clint
    Mid Michigan
    stock
    yes it is, my airbag kit was the 2407, the brackets 2507 but I actually got a deal on the 2510 brackets for a much higher lift and cut them down to size and saved 25.00.
  12. Mar 22, 2016 at 2:56 PM
    gmann1972
    Greg
    Rhode Island
    If you don't mind me asking, but where did you get the brackets from...any particular web site?
  13. Mar 22, 2016 at 3:05 PM
    Tacoma12
    Clint
    Mid Michigan
    stock
    it was ebay for me, a local Michigan dealer "madcheetah" always has deals but you have to catch him at the right time. I'm patient and cheap so I watch him like a hawk for deals.
  14. Mar 22, 2016 at 3:07 PM
    gmann1972
    Greg
    Rhode Island
    And these are Firestone Brackets...I will look them up now
    Tacoma12[QUOTED][OP] likes this.
  15. Mar 22, 2016 at 3:14 PM
    #35
    gmann1972
    Greg
    Rhode Island
    Found them...now it all makes sense...Thanks a bunch...now I feel much better...thought I was going crazy
    #35
  16. Mar 22, 2016 at 3:27 PM
    #36
    alvinfromhawaii
    alvinfromhawaii Well-Known Member
    Northern California
    2015 MGM Tacoma DCSB V6 TRD Offroad
    Supercharged, Magnaflow, Volant,
    Could you post a pic of how this bracket is used. I'm wondering it I could use this for a ubolt flip w a daystar cradle.
    Thanks,
    Alvin
  17. Mar 22, 2016 at 3:38 PM
    #37
    Leggo
    Leggo slow is smooth, and smooth is fast.
    Newton,Ma.
    10 TRD Sport AC 4x4 MGM
    Kenwood HU,Infinity Kappa speakers (x4), Infinity reference tweeters(x2),10" Kicker sub, Box by Subthump, Infinty Five channel amp,DVD anytime bypass, DTRL Mod, Xtang trifecta, Fogs anytime Mod, Bed Mat,Westin running boards, Console vault, Maglite mod, Weathertechs,Autopage remote starter, Power tailgate lock, HID Bi Zenon, Hella Supertones,Rain guards,Rear leaf TSB,Steering shaft TSB, Fisher Homesteader plow, 886 reverse lights mod, Redline Hood struts, Hankook Dynapro ATM LT265/70R17, power sliding rear window, Auto dimming/on anytime Bed lights, Blue Sea fuse panel & 100amp Breaker, de- badged,Rear headrest's removed, imMrYo mirror relocation,Homeroshi grill
    but it's the volume of air that is the problem, when you let all the volume of air shift to the other side. simple enough?
  18. Mar 22, 2016 at 5:36 PM
    #38
    pudge151
    pudge151 Well-Known Member
    Sean
    Connecticut
    2015 Tundra Platinum
    Not really. Fill 2 balloons half with air and connect them with a straw, squeeze one balloon flat, the other one will fill fully. Then let off the other one and the pressure in each will equalize. It's best to isolate the bags air lines.
  19. Mar 22, 2016 at 5:43 PM
    #39
    neverstuck
    neverstuck Well-Known Member
    Guido
    Lebanon
    13 DCLB sport
    slide-in camper, OME Nitros w 884's and Dakars, Michelin A/T2, Pro EFX heated towing mirrors, Timbren HD bumpstops, KB VooDoo bed rails and tailgate cap, ImMrYo rvm bracket, G-Tek Fab door sill protectors, Ultragauge, window visors, hood deflector, Wet Okole seatcovers, in-vehicle safe.
    Daystar cradles work well with lifts (longer shocks than stock). Your downward axle travel is not limited by the bag being stretched to its limit and acting like an axle limit strap.
    pudge151 likes this.
  20. Mar 26, 2016 at 8:38 AM
    #40
    Tacoma12
    Clint
    Mid Michigan
    stock
    Hey Alvin no pics but you bolt the brackets to the inside mount bracket that the airbag sits.
    Then the brackets you are adding reach down to the axel and rest on it so when you ad air and load to the system the bracket rest on the axel for strength.
    Without that bracket and any rear lift the actual air bag bracket will not reach the a El for strength.
