First day modding truck.... and weirdness ensued...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by emtlibby, Feb 21, 2010.
  1. Feb 21, 2010 at 2:06 PM
    emtlibby
    emtlibby [OP] Slaughtering goats
    Boston, MA
    2010 4x4 DBLCAB
    Its rare I get a day off, so I spent the day making some mod's to my 2010 Tacoma.
    1. I did the foglight anytime mod, great write up, works great.:D
    2. Did an oil change. Got a toyota filter from the dealer, and it appears substantially different from the filter I pulled off the truck. Same size. But the filter on the truck appeared better made. Heavier metal, welded seam, and more substantial gasket. The one on the truck says made in Japan, the one from the dealer says made in Thailand?:confused:
    3. Manual says 5.7 qts w/ filter change. It took 6, and still doesn't read full?:confused:
    4. Switched all the bulbs, in and out to LED, looks way cool!:cool:
    Finally, I put a new hu in- which went easy - these things are super easy to run wires in! But while pulling off the a pillar, my hand slipped and i hit the dash with a screwdriver scraping it. Its a black dash, but the mark looks like the tan of the rest of the dash... Is it tan underneath? Any ideas on repair?:eek:
  2. Feb 21, 2010 at 2:16 PM
    fletch aka
    fletch aka www.BeLikeBrit.org
    Gary
    Left Coast
    09 Magnetic Gray TRD OffRoad
    TRD cat back exhaust, TRD Cold Air Intake, differential breather mod' Hellwig rear sway bar, 16x8 TRD Ivan Stewart's, Michelin LTX A/T2, DTRL Stealth Mode Mod, custom "Texas Edition" shift knob, Sock's "Classic" bedside decals, MetalMiller custom grill emblem, 20% front tinted windows, tinted taillights, Viper alarm, ScanGauge II, Flyzeye Designs V2W Tacoma Interior LED lighting, de-mud flapped, de-badged, extra D-rings under bed bolts, WeatherTech ED floor mats, G4 Elite Fold a Cover ,Toyota bed mat, tailgate theft deterrent device and absolutely no plasti-dip!
    Are you on a slope of any kind for the dip stick not to read correctly? You don't want to over fill the crankcase. The dipstick on these are a little tricky to read. Some members scuff the dipstick with sand paper, seems to help.
    As for the dash :notsure: and :facepalm:
  3. Feb 21, 2010 at 2:18 PM
    emtlibby
    Boston, MA
    2010 4x4 DBLCAB
    Fair question. Yeah, perfectly level, and let it sit overnight. I got 6 quarts in, and it reads about 2cm below the full mark. Im not gonna add anymore, but it seemed odd that it was off...:anonymous:
  4. Feb 21, 2010 at 2:23 PM
    emtlibby
    Boston, MA
    2010 4x4 DBLCAB
    Is there any market for the factory radio I pulled out?
  5. Feb 21, 2010 at 2:45 PM
    emtlibby
    Boston, MA
    2010 4x4 DBLCAB
    Here is the dash mark...
  6. Feb 21, 2010 at 2:48 PM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    Other than trying to find some matching paint... not sure what else you could do to fix that.
    The 4.0 should only take about 5.5 quarts (I've never put more than that in.. always perfect every time). I also use K&N oil filters, always consistent quality and I've never had a problem in many years of running them.
  7. Feb 21, 2010 at 2:49 PM
    emtlibby
    Boston, MA
    2010 4x4 DBLCAB
    Here is the new head unit. Its a no-name brand - Valor. But for $129.00 its got a DVD player with outputs - which ill hook to a rear screen, IPOD interface, and bluetooth. So far it works!
  8. Feb 21, 2010 at 2:49 PM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    Throw it on the buy/sell/trade here. There's plenty of faulty stock radios that I'm sure someone would bite on it...
  9. Feb 21, 2010 at 2:51 PM
    emtlibby
    Boston, MA
    2010 4x4 DBLCAB
    And finally here is the LED mod. Did all the exterior, except turn signals, since I want to do the DTRL relay mod - and not sure how that will work.
    The 2010 already has LED tail/brake, and I added LED 3rd brake light. Also did the dome lights, awesome. Got everything from superbrightleds.com
  10. Feb 21, 2010 at 2:53 PM
    emtlibby
    Boston, MA
    2010 4x4 DBLCAB
    Yeah Ill grab some. Its the 2010 non-jbl, looks a little different than the older ones, but appears same size. I have that for sale, and a 200W Bass Canon that came out of my old Jeep - won't fit in the new Tacoma...
  11. Feb 21, 2010 at 2:57 PM
    Project.paradigm
    Project.paradigm Well-Known Member
    Oil Country,Alberta, Canada
    04 TRD 4X4 Dub cab
    Airlift rear air bags. Hood struts. sockmonkey bedside decal. TRD supercharger(not installed). Deckplate. Grey wire mod. Extended rear diff breather. 6000k HIDS. 18"Magnaflow. Truxxx 3" level kit. (Temporary) Wet Okole seat covers. BoxRocket bed rack. Bora 0.75 wheel spacers All pro sliders. BAMF BPV. B&M trans cooler.
    I'd say you're ok with the oil level. The oil doesn't have to hit the max mark. As long as it's over the min mark.
  12. Feb 21, 2010 at 3:05 PM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren bump stops, Crown braided/extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Sherpa Grand Teton/Crows nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights
    Was this by any chance your trucks first oil change... the filter from the factory is usually a bit different and on pretty tight.
  13. Feb 21, 2010 at 3:06 PM
    emtlibby
    Boston, MA
    2010 4x4 DBLCAB
    Yes it was the first change.
  14. Feb 21, 2010 at 3:12 PM
    OffroadToy
    Well, that explains it. As far as your oil level... Your ok as long as your not below the low mark, or over the high mark. These dip sticks are hard to read and take some getting used to. Like already mentioned, scuff it up to make it easier to read.
  15. Feb 21, 2010 at 3:51 PM
    emtlibby
    Boston, MA
    2010 4x4 DBLCAB
    Anyone got a source for the Japanese filter. Appears way more substantial than the one I got from dealer. Ill probably disect it soon. Will post.
  16. Feb 21, 2010 at 4:09 PM
    mws4ua
    mws4ua I'll try being nicer if you try being smarter.
    Birmingham
    2018 GMC Sierra SLT Z71 4x4... Yeah yeah, I know.
    The filter that comes on new tacomas is from Japan. It's hard as hell to find them after that. The ones you get from the dealer (or from Ebay, where I buy mine) are all made in Thailand. I haven't heard of anybody having a problem with the Thialand-made filters.
    If you do a little searching you'll find a few threads about the merits of the two filters. You can probably find the Japan filters if you REALLY set your mind to it, but you'd be better of buying a high-quality after market filter.
  17. Feb 22, 2010 at 6:33 AM
    emtlibby
    Boston, MA
    2010 4x4 DBLCAB
    So when people on here say they are running an OEM filter, they are all getting Thailand filters...? Just wanted to make sure dealer wasn't screwing me.
  18. Feb 22, 2010 at 6:41 AM
    mws4ua
    Birmingham
    Dealer's not scewing you. I run the OEM filter, and mine say "made in Thailand" on them. I never saw a "made in Japan" filter on my truck, b/c I bought it well after its first oil change.
    I get mine on ebay for $40/case of 10.
  19. Feb 22, 2010 at 6:51 AM
    emtlibby
    Boston, MA
    2010 4x4 DBLCAB
    Cool, thanks man. Wow, thats a deal on filters. Ill have to go check Ebay.
  20. Feb 22, 2010 at 6:53 AM
    hillbillynwv
    hillbillynwv Well-Known Member
    Fairmont, WV
    2017 Tacoma 6MT TRD Pro
    Falken Wildpeak MT 285's
    I was running the Mobil 1 Extended Performance oil filter but have now switched to the Purolator Pure One filter. It's half the price of the Mobil 1 filter and the oil seems to be filtering better in the Purolator.
