first gen hid install rubber boot
Discussion in 'Lighting' started by rab89, Jan 9, 2011.
  1. Jan 9, 2011 at 7:34 PM
    rab89
    rab89 [OP] Well-Known Member
    Ross
    Kelowna b.c canada
    2012 DCLB
    Grillcraft mx black upper and lower BHLM with Gloss black 265 70 17 bfg a/t center console light mini mag mounted in center console debadged bed lights 35W 5000k HID's
    So, I put my hid's in last night, from ddm.
    I'm not happy that the rubber boot doesn't fit over them to keep the dust and dirt out of the light housing, any suggestions?
    Also, there is that little metal shield on them, it seems to be giving me a cut-off on the bottom of my lights with the high beams on, can i take it off? has anyone ever taken one off? and it is supposed to be shield on the bottom right?
  2. Jan 9, 2011 at 7:42 PM
    BrokenTusk
    BrokenTusk I support a velociraptor free workplace.
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Check Build Thread!!
    I actually just installed mine today, You install the rubber boot by taking the shield off and then slidding the boot over the bulb. as for running without the shield on i really have no idea what that would do. I left mine on and they're super bright with it
  3. Jan 9, 2011 at 7:48 PM
    rab89
    Ross
    Kelowna b.c canada
    2012 DCLB
    ok cool, I just didnt want to accidentally touch the bulb, I'll give it a shot tomorrow.
    maybe I'll try them with the shield off while I'm at it
  4. Jan 9, 2011 at 8:00 PM
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Just do it slowly and you should be good, I never touched the sides of the bulb when I did it. Worked awesome for me though :D
  5. Jan 9, 2011 at 8:01 PM
    rab89
    Ross
    Kelowna b.c canada
    2012 DCLB
    oh, and you guys with 2nd gen's use the h4 bulbs too right?
  6. Jan 9, 2011 at 8:02 PM
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    yup yup!
  7. Jan 9, 2011 at 8:07 PM
    rab89
    Ross
    Kelowna b.c canada
    2012 DCLB
    cool. I've made a pot of coffee and heading out to the garage, be back in bit with answers!
  8. Jan 9, 2011 at 9:42 PM
    rab89
    Ross
    Kelowna b.c canada
    2012 DCLB
    I don't know if the 2nd gen boot is different than the first gen boot, but there's no way I can get it on there. I took off the shield, but still nothing.
    as far as light output with the shield off, the cutoff on the top is pretty much gone with low beams, but no one was flashing me, if they do I'll have to fix it.
    The high beams actually work now, and don't have a weird cutoff on the bottom, I'll leave it for now.
    I really wanna get the boots on there somehow though.
  9. Jan 9, 2011 at 9:59 PM
    01tacoprerunner
    01tacoprerunner 16 TRD OR Inferno/01 4WD Prerunner
    Brian
    Raleigh, NC
    Lets see Pics man!! And what intensity did you get??
    I have got to order some!
  10. Jan 9, 2011 at 10:03 PM
    rab89
    Ross
    Kelowna b.c canada
    2012 DCLB
    35 watt 5000k, I'm not overly impressed though, my silverstars were pretty good, but they are nice on the eyes on the highway.
    pics, we'll see if I feel like it in a bit...
  11. Jan 9, 2011 at 10:07 PM
    Tacomanator
    Tacomanator Boiling denim and bangin whores
    Clam Slammer
    Southern Cali
    King 2.5" extended travel coilovers with compression adjusters, Camburg UCA's, King 2.5" rear shocks, TRD 1st gen CAI.
    just cut a slice to the middle opening of the boot, pull apart and wrap around the bulb. thats what i did and so far so good.
    the shield on the bulb helps prevent blinding on comming traffic.
  12. Jan 9, 2011 at 10:15 PM
    rab89
    Ross
    Kelowna b.c canada
    2012 DCLB
    that should work!
  13. Jan 9, 2011 at 10:17 PM
    Tacomanator
    Clam Slammer
    Southern Cali
    its worked great for me so far!
  14. Jan 9, 2011 at 10:18 PM
    rab89
    Ross
    Kelowna b.c canada
    2012 DCLB
    oh and as far as blinding other people, my buddy got hid's at the same time as me, for his f-150, and his don't have the shield, and neither do normal bulbs, thats what confuses me!
  15. Jan 9, 2011 at 10:21 PM
    01tacoprerunner
    Brian
    Raleigh, NC
    Are you saying you dont think they were worth it?
    Or should i get 55 watt?
  16. Jan 9, 2011 at 10:22 PM
    rab89
    Ross
    Kelowna b.c canada
    2012 DCLB
    If you have some cash to spend, sure go for it, but there are other thing's i'd do first!
  17. Jan 9, 2011 at 10:29 PM
    Tacomanator
    Clam Slammer
    Southern Cali
    the bulbs with a shield are called "bi-xenon" which give you both hi/lo HID beams. the bulbs w/o the sheild uses HID for the low beams but halogen for the high beams.
  18. Jan 9, 2011 at 10:40 PM
    rab89
    Ross
    Kelowna b.c canada
    2012 DCLB
    nope, his are bi-xenon and don't have the shield...
  19. Jan 9, 2011 at 10:57 PM
    Tacomanator
    Clam Slammer
    Southern Cali
    so his hi-beams use xenon light and not halogen?
  20. Jan 9, 2011 at 11:08 PM
    WhatThePho?
    WhatThePho? Greg Graffin 2016
    Andre
    HCMC, VN
    2006 STi
    The things required to pull bitches
    The 5000 k bulb from ddm are different then the rest. I had the 6k before, and now the 5k. The 5k are a bit bigger than the 6k.
