First "Off-Road" adventure
Discussion in '2nd Gen. Tacomas (2005-2015)' started by fadippides, Jan 1, 2012.
  1. Jan 1, 2012 at 4:05 PM
    fadippides
    fadippides [OP] Well-Known Member
    NEPA
    12 TRD Off Road
  2. Jan 1, 2012 at 4:40 PM
    jackrules
    jackrules Well-Known Member
    Jack
    San Diego
    10 PreRunner Double Cab SR5 TRD Sport LB
    idk where you are.. but it looks disgusting
  3. Jan 1, 2012 at 4:47 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    I guess you don't have to tread lightly in a landfill... [​IMG]
  4. Jan 1, 2012 at 5:18 PM
    brett1586
    brett1586 Well-Known Member
    Brett
    Athens, Ohio
    Ummmm....?
  5. Jan 1, 2012 at 5:22 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    what the hell is this? its you backing up in a garbage dump...did you upload the wrong video or something.
  6. Jan 1, 2012 at 5:25 PM
    brett1586
    Brett
    Athens, Ohio
    This is just disgusting. Is this for real?
  7. Jan 1, 2012 at 5:27 PM
    derekabraham
    derekabraham Living vicariously through everybody
    TW'S Hippy Liberal
    Portland, OR
    2002 4x4 4Runner
    Stick on hood scoop from Autozone.
    I don't know what just happened.
  8. Jan 1, 2012 at 5:40 PM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
  9. Jan 1, 2012 at 6:02 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    good idea!:devil:
  10. Jan 1, 2012 at 6:10 PM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    That'd be some fun target shooting...
  11. Jan 1, 2012 at 6:17 PM
    blackhawke88
    blackhawke88 wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
    Why did you post that?
  12. Jan 1, 2012 at 6:27 PM
    sparkystaco
    sparkystaco Well-Known Member
    Sparky
    SE Wi
    06 4x4 dc trd ofrd
    3" lift? A.R.E cap 285/70/17 moto metal 955 17x9
    I want that minute of my life back
  13. Jan 1, 2012 at 6:30 PM
    outxider
    outxider Never stop exploring. Rest in Paradise Big Bro.
    Sang
    East Bay, CA
    06 DCSB 4x4
    A few mods here and there and counting....
    noobs.
  14. Jan 1, 2012 at 6:42 PM
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    09 Access Cab Prerunner
    Rear Leaf spring TSB, Bilstein 5100's all around w/ front set at 1.75", 265/75R/16 Mickey Thompson Baja STZ's, Trailer hitch w/custom wiring, AFE drop in dry filter, Rear Diff breather mod, Debadged truck, customized stock TRD wheel center caps, added factory fog lights, bed mat, door sills, tinted windows
    Wow is that LA, CA?
  15. Jan 1, 2012 at 6:47 PM
    fadippides
    NEPA
    12 TRD Off Road
    Its actually in PA, although a lot of NY garbage. Had to haul a load of construction debris. The truck is a few weeks old and I would like to find a place to take it off road. Paragon used to be open until they were forced to close in a boondogle. Perhaps I will go to centrailia one day.
  16. Jan 1, 2012 at 6:48 PM
    BMOC
    BMOC Well-Known Member
    Paden
    Phoenix, AZ
  17. Jan 1, 2012 at 6:56 PM
    fadippides
    NEPA
    12 TRD Off Road
    And yes, my sense of humor is odd ;-) Just be glad you didnt have to be there for the stench
  18. Jan 1, 2012 at 7:02 PM
    fadippides
    NEPA
    12 TRD Off Road
    Its my first PU and I actually was able to haul a load of construction debris from working on flooring (300 lbs worth). Had to climb a fairly steep muddy road to the top of the mountain to dump it (not that diff since all the trucks have to make it up).
    I was able to hit some of the bigger ruts to see how it would handle and was fairly impressed. I do up to wheel somewhere but it has to be mild as I cant really put lifts on due to putting 30-35k on a year.
  19. Jan 1, 2012 at 7:10 PM
    jw1983
    jw1983 Well-Known Member
    Alberta
    13' Tacoma Access 4x4 OR
    Well this was the first bad video of 2012 lol.
  20. Jan 1, 2012 at 7:15 PM
    fadippides
    NEPA
    12 TRD Off Road
    The only place to go is now up
