First oil change at 1250 miles
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Tacowin1013, May 12, 2017.
  1. May 12, 2017 at 8:40 PM
    Tacowin1013
    Tacowin1013 [OP] Well-Known Member
    2017 OR DCSB 6MT MGM
    did the first oil change today and when I took off the oil drain bolt, I had my oil drain pan underneath but it rushed out with so much force and so quickly that it splattered at least a quart of oil all over the place. What are you guys doing to prevent this? I might try to use a funnel next time and have it ready to catch it into the drain pan. Any other suggestions?
    Also, the oil looked pretty good. Upon inspection I didn't really see many shavings in the filter or much in the oil. If you're on the fence about changing it, I personally think you could get away with waiting until 10k or if you're like me and would rather have a little piece of mind, then go ahead and change it.
  2. May 12, 2017 at 8:53 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    I just hit 1500 Miles today on mine and am planning a change in the next day or so, that 0-20 is so thin it probably will rush out, taking the Oil Cap off will make it come out even faster but may eliminate any gurgling out which is what I will try.
    GPsevinSixx likes this.
  3. May 12, 2017 at 8:55 PM
    Tacowin1013
    yeah it was definitely a mess! Took me longer to clean up the oil that splattered then the change itself.
    shakerhood[QUOTED] likes this.
  4. May 12, 2017 at 9:14 PM
    1bad2k
    1bad2k Well-Known Member
    Lone Star State
    2017 Tacoma TRD PRO
    Maybe look into the fumoto valve with drain hose..?
    over60, Tacowin1013[OP] and BlakeM like this.
  5. May 12, 2017 at 11:13 PM
    DrVonEvilSatan
    DrVonEvilSatan Well-Known Member
    Toyota Truck
    I've sent my oil off to be analyzed. I changed mine around the same time for breakin and again at 5k. There was plenty of wear metals detected. The base structure was still perfect. The additives package on stock oil is still very good after 5,000 a change, probably good up to 7,500 or even 10,000 if you aren't hard on it.
    GPsevinSixx, shakerhood and splitbolt like this.
  6. May 12, 2017 at 11:36 PM
    Sledgehammer
    Sledgehammer The Walkenator
    Colorado - Western Slope
    2017 Blazing Blue Pearl
    What kind of oil are you guys using. I am at 5k miles and ready to change it.
  7. May 12, 2017 at 11:40 PM
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz, CA
    99’ Bro-Coma’s Revenge 3RZ 345k+
    Stock
    Anything I care about I run Amsoil Signature Series. Tacoma I run Mobil 1 when its on sale. I change it every 5k. I don't trust the 0-20 to go 10k, just me, plus I run my shit pretty hard.
    1bad2k likes this.
  8. May 13, 2017 at 4:48 AM
    1bad2k
    Lone Star State
    2017 Tacoma TRD PRO
    Amsoil signature for me as well.
    JoeT4R likes this.
  9. May 13, 2017 at 6:11 AM
    shakerhood
    Southern Ohio
    I just bought Mobil 1 because they have a $12 rebate on a jug till the end of May.
    Tacowin1013[OP] and Vbpiper like this.
  10. May 13, 2017 at 6:21 AM
    tibadoe
    tibadoe Well-Known Member
    Joe
    Gladys, VA
    17 Tacoma SR 4X4
    I have a Fumoto F103N ready to install at my first oil change when I hit the 1k mark. I like how how easy they make draining the oil on my other vehicles - no mess.
  11. May 13, 2017 at 6:37 AM
    The hammer
    The hammer Who’s the Wrench?
    '16 Tacoma SR5 4X4 DCLB TSS Pkg 17X8" BSW-Cooper DIscoverer AT3 4s P265/65/17
    Underworld Flex trifold, tinted, TRDPRO grill, TRDPRO shift knob, etc,etc
    Just one, get a bigger pan a "wide" one
    Cheers!
  12. May 13, 2017 at 9:10 AM
    Tacowin1013
  13. May 13, 2017 at 9:13 AM
    Tacowin1013
    Mobil 1 0w20 and Toyota filter from Amazon. Mobil has always worked well for all my cars so I have no reason to question otherwise.
  14. May 13, 2017 at 12:55 PM
    LS14ME2
    LS14ME2 Kind of a big deal
    In hiding, CA
    2017 SSM Sport DCSB 4x4
    Center console divider thingy, rubber bed mat and side steps for the wife.
    M1 is good enough for my Vette so good enough for my Taco... FWIW, Toyota brand 0w20 is a very good oil as well..
  15. May 13, 2017 at 4:40 PM
    1Shifter
    1Shifter Well-Known Member
    Jeff
    Outta the black and into the blue
    09 PreRunner
    Same as everybody else...
    over60 likes this.
  16. May 14, 2017 at 8:46 PM
    shakerhood
    Southern Ohio
    I did mine today at 1590, thin oil does splash a little more but I lay paper under my drain pan so was good to go. Oil was a little dirty and there was a bit of glitter in the bottom of the drain pan but no large shavings.
  17. May 14, 2017 at 9:34 PM
    Metonymy
    Metonymy Well-Known Member
    2017 White Tacoma TRD PRO
    None (yet)
    Did mine today at 1437 miles. Man, I wish I had thought to get a fumoto valve to install. Needless to say, I just ordered one and it'll go in on the next change at 5k. Went with F-103N since I have the skid plate and the nipple won't be an issue at all.
    Oil was a little dark (not surprising for a new engine) but there were only a few tiny sparkles in the oil, no shavings or anything of concern.
    1Shifter and shakerhood like this.
  18. May 15, 2017 at 6:47 AM
    Tacowin1013
    haha I'm def considering a fumoto valve in 2 years when I start to do my own changes...or a tarp...
  19. May 15, 2017 at 6:50 AM
    gpb
    gpb Well-Known Member
    Atlanta
    2017 White DCSB TRDOR 4x4
    I use an oil drain pan like this one: https://www.amazon.com/dp/B0160B4G0M
    Something about the shape and the grate seems to do a decent job at preventing splashback.
  20. May 15, 2017 at 7:01 AM
    Sand_taco
    Sand_taco Well-Known Member
    2016 quicksand Trd off road
    its mobil 1
