First oil change on used truck
Discussion in '2nd Gen. Tacomas (2005-2015)' started by chavab_1, Jul 3, 2018.
  1. Jul 3, 2018 at 2:38 PM
    chavab_1
    chavab_1 [OP] Member
    2015 Silver Tacoma TRD 4X4
    I bought my 2015 TRD used from a private vendor early this year. I want to do its first oil change but want to make sure I use the correct oil. The truck has about 28K miles on it.
    On the manual it says to use 'Toyota Genuine Motor Oil', but if I can't find that type of oil what other can I use? I did some research and I keep seeing Mobil Super being mentioned. I also see that some talk about going to Full Synthetic.
    I don't mind paying a little extra to get the oil that will help with performance and endurance. I just want to make sure it's the correct kind. This is the first truck that I've owned that is worth more than 15K so I'm trying to be very careful with everything I do.
    Thanx in advance
  2. Jul 3, 2018 at 2:40 PM
    eccracer104
    eccracer104 O.G. Member
    San Diego, CA
    2016 Tundra 4x4
    5W 30
    I typically use Mobil 1 synthetic myself, but the brand oil you use is up to you.
    smw62891 and chavab_1[OP] like this.
  3. Jul 3, 2018 at 2:45 PM
    TheFang
    TheFang No Big Deal
    SoCal
    Tacoma TRD Sport
    TRD Exhaust, URD Short Shift, TRD Supercharger, Hellwig rear sway bar, TWM shift knob, limo tint, URD Y-pipe, URD LT Headers, URD Rear O2 Sim, Custom tube front and rear bumpers, LED spot pods, K&N CAI
    I switched to Mobil 1 full synthetic as soon as I bought my truck. I’m a firm believer in full synthetic. Sure it’s more expensive, but I love my truck and I’m willing to pay a little more for better oil which will pay off in the long run.
  4. Jul 3, 2018 at 2:48 PM
    Blockhead
    Blockhead Well-Known Member
    Pittsburgh, Pa.
    2024 Silver SR5 DCLB
    An oil thread...wooohooo! :bananadance:
  5. Jul 3, 2018 at 2:48 PM
    Clearwater Bill
    Billy
    Largo Florida
    Wt is on oil fill cap.
    If you take advantage of extended OCIs that come with syn, or you work the truck in the 'severe duty' category, syn is worth the extra.
    If you are stuck in the 70s with a 5k OCI mindset, any conventional oil will be fine.
    No need for special order boutique stuff. If you can't find it at Walmart or Costco you don't need it. Regardless of what magazines, TV shows and pyramid product dealers claim. ;)
  6. Jul 3, 2018 at 2:49 PM
    scocar
    scocar hypotenoper
    5w 30 as mentioned, up to you on brand and type (syn or non-syn). I've been using the Pennzoil ultra full synthetic. It has been shown to retain viscosity better than some other brands, and my Blackstone analysis results with the Pennzoil have been better than Mobil 1. Walmart usually has the best deals on 5-qt jugs. You'll need 5.5 qts, so just buy several jugs while you are at it to save a bunch. The single quarts are too spendy.
    The OEM filters are highly recommended,90915-YZZD3. Economical, and good quality. No need to spend 2 or 3 times more for any aftermarket oil filter. You can get a case of 10 for $46 or so
    https://www.amazon.com/gp/product/B00A1X9IU4/ref=oh_aui_detailpage_o07_s00?ie=UTF8&psc=1
    ausfahrt, 2WD, outlawtacoma and 5 others like this.
  7. Jul 3, 2018 at 2:53 PM
    chavab_1
    Thanx guys!! Def getting some good info. I'm willing to spend a little more if it's worth it. I just don't want to spend it if it's not necessary. It sounds like good ole' Walmart might be all that I need.
  8. Jul 3, 2018 at 3:01 PM
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    You should follow the directions of your owners manual at this point. If you desire more knowledge and how to save some money, just come back to TW on a regular basis. You will be surprised on how much you will learn and spend from just logging in to this site.
  9. Jul 3, 2018 at 3:08 PM
    chavab_1
    Yeah, I would normally do that but since I bought it used and I'm not sure what the previous owner was using so I thought I'd check to see what others thought. As I said, I'm just trying to be careful and not overlook something. Maybe I'm just overthinking, haha.
    Oh, and I believe you on 'how much you will learn and spend' on this site. Just from this login session I'm looking at all the galleries of the badazz trucks thinking of what mods I can do to mine.
    Thanx
  10. Jul 3, 2018 at 3:24 PM
    djd1
    djd1 Well-Known Member
    Dave
    Winston-Salem, NC
    15 DCLB 4x4
    Just rolled 30k in mine, it uses 5W-30 and a standard Toyota filter. Inexpensive and Easy to do. Change your spark plugs as well - also easy to do and required to keep the emissions warranty intact. Standard copper plugs - no fancy iridiums required.
    b_r_o and chavab_1[OP] like this.
  11. Jul 3, 2018 at 3:35 PM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    Walmart has an excellent low cost full synthetic 5w30 called SUPER TECH in a blue 5 qt .bottle, costs about $16
  12. Jul 3, 2018 at 3:37 PM
    edm3rd
    edm3rd Well-Known Member
    Duke
    Memphis TN
    09 PreRunner AC 6sp
    hard tonneau,scangauge
    Check your truck's manual regarding the Maintenance Light. It is strictly a mileage counter. Reset when you change the oil, it will flash briefly starting at 4500 miles, and will stay lit when you reach 5000.
    chavab_1[OP] likes this.
  13. Jul 3, 2018 at 3:46 PM
    Monkeybutt2000
    Monkeybutt2000 Well-Known Member
    Big fan of the Supertech.
  14. Jul 3, 2018 at 4:04 PM
    Sprig
    Sprig Well-Known Member
    Ken
    N. Calif. The Twilight Zone
    Tacoma TRD double cab 4x4, Barcelona Red
    It doesn’t make any difference what brand you use. What matters is that you use the correct weight and you change oil at regular intervals. All modern oils are top notch lubricants. No one here can offer any proof that say Pennzoil is better than Castro or GTX is better than Walmart oil and so on.
    There is a difference between regular oil and synthetic but again no one can say if your engine will last longer using synthetic as opposed to non synthetic.
    There are a lot of expert opinions on oil brands but none of those giving the advice are experts. Marketing and word of mouth is what influences peoples choice of oil.
  15. Jul 4, 2018 at 6:12 AM
    Jlarso01
    Jlarso01 Well-Known Member
    Jim
    Clearwater, Florida
    2015 Tacoma double cab 5' bed
    None yet
    Could you elaborate on what readings are better and by how much?
    BillsSR5 likes this.
  16. Jul 4, 2018 at 7:19 AM
    Blockhead
    Pittsburgh, Pa.
    Uh oh...here we go...
    “Is that real fur...?”
    Plain Jane Taco and scottalot like this.
  17. Jul 4, 2018 at 7:23 AM
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
    This should be the default auto reply/response to any "what's the best oil" thread!
  18. Jul 4, 2018 at 7:30 AM
    Sprig
    Ken
    Even if he responds his results mean nothing. Black stone analysis results apply only to individual engines. The results only apply to his truck, his oil, his engine, his driving habits and a hundred other variables.
    You cannot make broad or meaningful statements based on an individuals results. Blackstone will tell you the same. Blackstone is a great company to tell you how your engine and oil are doing but again the results only apply for your engine, doesn’t mean anyone else will have the same results.
  19. Jul 4, 2018 at 7:38 AM
    Taylorbarton1
    Taylorbarton1 Well-Known Member
    Taylor
    Hotlanta
    2011 TRD off-road
    6 inch lift. 35's.
    5.5 to 5.7 quarts of oil with a filter change. Royal purple for me, I grab it on sale for the same price as mobile 1. I'll run either a royal purple filter or an oem Toyota filter.
  20. Jul 4, 2018 at 2:38 PM
    grubburg
    grubburg Well-Known Member
    2019 TRD OR MT
    K & N Intake, Gibson Catback (chopped), Weathertech floormats, 285/70/17 Ridge Grapplers, Black Rhino Glamis wheels, Kicker Key, Kicker Hideaway, Infiniti Speakers, OV Tune, 888's, 5100s X 4, HS 3-leaf, LR SPC UCAs, Diff Drop, Carrier Bearing Drop, OEM Bed Mat, Morimoto HID low beams, Morimoto LED 2 Stroke High Beams, KC 336 LED bar, KC C3 LED pods for rear, KC LED 6'' SlimLites ditch lights, N-Fab Steps, Auxbeam Interior Blue Lights, 7r41lbr34k3r Shift Knob, Wet Okole Seat Covers, Diode Dynamics SAE Pro Fogs, Cali Raised ditch light brackets, hidden light bar brackets, tailgate light brackets.
    how often do you change it?
