First oil change
Discussion in '2nd Gen. Tacomas (2005-2015)' started by rpoint16, Jan 20, 2008.
  1. Jan 20, 2008 at 3:45 PM
    rpoint16
    rpoint16 [OP] Well-Known Member
    Tempe, AZ
    2022 TRD Off-Road, Super White.
    Bone Stock
    So I have 4K miles & do my first oil change. Drain the oil. I cannot hand loosen the oil filter, no big deal. Pull out my handy dandy "over the top" filter cap wrench, it will not come off. The 3/8 drive hole strips.
    Pulled out my handy dandy steel wrap around self tightening filter wrench, it will not come off. Strips the hole.
    Tried my giant channel locks at the base of the filter, only started to crush it.
    Tried my medium size strap wrench, could not break it loose,started to collapse the filter.
    Took it to the dealership. They changed it for free. Said it came right off...
    I said BS!!
    Weird
  2. Jan 20, 2008 at 3:59 PM
    gsm
    gsm Well-Known Member
    Raleigh, NC
    08 Tacoma Regular Cab, 2.7L, Impulse Red Pearl
    DIY OEM Fog Lights on anytime, DIY OEM Cruise Control, Removed 2ndary Air Filter, Rear Speakers Mod, Traction Bar/Helper Spring Mod, Red Brake Drums and Rotors, Stainless Steel Exhaust Tip, Door Sill Protectors, Taco Bed Mat, Custom Front Mud Flaps (Mudguards), TRD Bucket Seats (pending)
    Not the first complant I've heard about it being almost impossible to remove the factory installed oil filter.
    I almost took mine in just to be safe, but felt bold and did it myself. It was on extremely tight but I was lucky and got it off :eek:.
  3. Jan 20, 2008 at 4:24 PM
    TSUNAMI*22
    TSUNAMI*22 Obama can suck-it
    Stockton, CA
    '07 Standard Cab / White / 2.7 I4
    ScanGuage 2 equipped. Toyota DIY aftermarket Cruise Control mod
    Maybe the reason you had such a hard time was because you probably tried to remove the filter when the vehicle hadn't been run since the day before? Heat makes metal expand, which helps you break the filter loose much easier because the threads holding it on are looser than when they were cold.
    I understand that changing hot oil completely sucks (especially if you get it on your body). The dealer probably didn't have a hard time at all because you had just driven it there. Make sense?
    What I would do is get under your vehicle after you have driven it and break the filter loose while the truck is still warm. Then, wait 'till morning before you drain the oil and completely.
    Be careful, because there is a flip side to this technique. If you screw in a new filter into a cold engine block, you might need to re-tighten it after the truck has warmed up because it will be loosened up after the heat gets to it.
    We tell flying students about this problem all the time. They always tighten the crap out of the oil dipstick while its warm and then the first flight the following morning the poor bastard doing the first pre-flight check can't get the cap off the oil dipstick because the aircraft is cold.
    Lesson learned: Run the vehicle to normal operating temp. Let it cool down for a while (1/2 hour or so). Oil filter should be much easier to remove.
    It is also good practice to spread a thin layer of oil onto the rubber gasket before screwing it in. This will prevent the gasket from adhering to the metal base where you put it on.
    Hope this helps you in the future.
  4. Jan 20, 2008 at 4:50 PM
    concrete jedi
    concrete jedi Well-Known Member
    Rochester N.Y
    06 Tacoma 4 door indigo blue
    Broken and scratched tailgate, cracked rear tail light lens, coffee stain in driver seat.
    Righty tighty lefty loosey :eek:
  5. Jan 20, 2008 at 4:54 PM
    rpoint16
    Tempe, AZ
    Bone Stock
    I did.
    It was.
    I do.
    :confused:
  6. Jan 20, 2008 at 5:16 PM
    concrete jedi
    Rochester N.Y
    The dealer lies ! :eek:
  7. Jan 20, 2008 at 5:54 PM
    maverick491
    maverick491 Towing Guru
    South Jersey
    07 4x4 Access Cab, TRD off road, 6 cyl, 6 spd
    Activator III brake controller, Extang Fulltilt toneau, Factory bed mat, Extra D-rings in the bed, 2ndary air filter removed, Garmin Ique GPS, Eco-2, AFE Pro Dry-s filter, USASPEC PA12-toy, Pioneer 3-way speakers, SG II on Blendmount, Gulf States Alarm added.
    I have rad about this many times on here, but about a month ago I did the first on change on my truck and got the filter off by hand. I guess it was a Friday when my truck was built and the robot was tired and slacking off. *shrug*
  8. Jan 20, 2008 at 5:56 PM
    concrete jedi
    Rochester N.Y
    Damn robots ! :(
  9. Jan 20, 2008 at 6:00 PM
    WilsonTheDog
    WilsonTheDog Kylie's dad
    Eric
    Myrtle Beach SC
    07 Prerunner SR5 DC/SB V6
    Magnaflow 12576 muffler & chrome tip, Westin step bars, 27% tint, Pop N Lock, AFE ProdryS, bed mat, Husky liners, D-rings added, Access Literider tonneau, Pioneer 4-ways all around, GY Wrangler Duratracs 265/75/16, 5100's @ 1.75", 1.5" AAL
    Honestly, I just crushed the damn thing with channel locks and finally got enough leverage to get it off.
    Hey, maybe you should call Balco. I'm sure Barry Bonds has the number.
  10. Jan 20, 2008 at 7:45 PM
    ZonKs
    ZonKs Can speak french in Russian.
    Ted
    Glendale, CA
    2018 Sport DCSB 4x4
    =p
    Same here.
  11. Jan 21, 2008 at 7:17 PM
    GratefulPred
    GratefulPred Member
    FAR Western Kentucky
    08 Access Cab 4x4 SR5 Black 5 Speed 4 cyl
    Hardwired Sirius satellite radio & ipod adaptor, weathertech floor liners, more to come...
    But what kind of oil did you put back in? Synthetic or conventional? I just refilled with conventional but am thinking of synthetic next time.
  12. Jan 22, 2008 at 5:03 AM
    Viper-2
    Viper-2 Secret Agent
    Keith
    Charleston, SC
    Prerunner with many mods
    Yeah mine was on extremely tight the first time. I bent the crap out of a Craftsman oil filter wrench trying to get that sucker off.
  13. Jan 22, 2008 at 8:50 AM
    TRD Larry
    TRD Larry trd larry
    Larry
    South Park, PA
    2019 Tacoma Black,Sport,Premium and Tech Package
    Sport pedals,, Magnaflow cat back exhaust system,Kuhmo 275x55x20, Platinum #220 Abyss wheels 20x9.5. Under hood lights, OEM LED cargo bed lights, extra D-rings installed in bed, AC mod, diff. breather mod, OEM LED puddle lights and footwell lights, Homelink mirror, oil catch can, raptor grille lights, replaced chrome grille molding with black molding, tailgate lock/unlock and tailgate opener, console organizer, glove compartment organizer, Caliraised stealth LED light bar, TRD Cold Air Intake, Lighted cup holders, Meso extended fuse cover, Meso stage 1 tail lights, Meso switch panel, Door bowl lights. Anytime front and rear backup camera mod. TRD Pro Rigid fog lights.Door edge guards. TRD Pro shift knob with Boomer's TRD LED light (Red for security, blue for interior), Glass Break Sensor, sensor with LED light tied into the security LED light, OEM LED Headlights, Sequential LED Turn Signals.
    I always let the dealer change the filter the first time. I know from experience for the first time it was usually a bitch. The problem is at the factory they do not put a thin coat of oil on the gasket. When the dealer or you change the filter you put a coat of oil on the gasket and that is what makes the filter easy to change. The combination of no oil on the gasket and probably over tightening at the factory is a combination hard to beat.
  14. Jan 22, 2008 at 9:40 AM
    dirthawker1313
    dirthawker1313 Well-Known Member
    mine was on so tight i ended up stabbing it with a very large philips head screw driver to use as leverage.
  15. Jan 22, 2008 at 12:32 PM
    pdxyota
    pdxyota Well-Known Member
    Greg
    Newberg, OR
    2005 4x4 5M 2TR-FE SR5 Access Cab Indigo Ink Pearl
    TSB x 2 because first TSB leaf springs broke
    I had to hammer a screw driver into mine & turn it like a friggin Ship's wheel. BS is right, those fcking A$$es do that on purpose at the factory. Another thing you'll love is the first time you try to loosen any of your differential plugs, get your Xanax ready.
    Go AMSOIL or MOBIL1 asap.
  16. Jan 23, 2008 at 2:28 PM
    ph16drive
    ph16drive \m/.....\m/
    Paul
    Clevelandish
    08 DC, V6, 4x4, 5-Speed Auto
    Shorty antenna, Pop-&-Lock tailgate lock, Undercover bed cover, Aeroforce Interceptor gauge (custom mount), bed mat, AFE Pro Dry S air filter, map light mod, suspension TSB, Billy 5100's all around, Eibach springs, custom fuel tank armor plate, custom cat armor plate, painted front brake calipers, Grillcraft MX upper grill & Hella 500s, ipod adapter, dash pushbutton garage door opener, aux reverse lights, custom ipod nano 4G mount, seatbelt chime mod, custom bull bar w/ (3) Lightforce 140 Lance lights, POR-15 Chassis Coat Black drivetrain, illum 4x4 switch, xtra bed D-rings mod, locker anytime mod, diff breather relocation mod, ABS disable switch mod, Heated seats
    Since I have a new Taco, I thought I'd see how tight my oil filter is at 120 miles on the odo. I got out three tools (photo attached) and was going to use at least two of them simultaneously. Luckily, it loosened with just the metal band wrench. I can only guess that since the truck is still new, not enough heat/cool cycles elapsed for the gasket to make a tighter grip. I loosened it enough so that just a tiny bit of oil leaked past the gasket and then I retightened it so that a film of oil was all along the gasket. I hope this will make the oil filter easy to remove at the first oil change. The engine was cold when I did this.
  17. Jan 23, 2008 at 2:40 PM
    gsm
    Raleigh, NC
    Great tip! If only we could get this out to the masses prior to them driving their first 5k miles. I'm sure there will be some to read this prior and will help them out.
  18. Jan 23, 2008 at 4:19 PM
    45longcolt
    45longcolt Well-Known Member
    DFW Area
    2020 Off Road
    Phofener, That middle one works very well. I got my strap wrench at Harbor Freight like that one.
    Another cheap tip: I now use and have for many years to remove oil filters and tighten them back on; an old leather belt. Gets in everywhere and you can slide the entire belt to get as much of a "hold" on it as you can. Takes up very little space in the tool box and if it get some oil on it, good! Makes it last longer and not dry out. :)
  19. Jan 25, 2008 at 2:49 AM
    vivafire
    vivafire Well-Known Member
    Galveston,Texas
    2024 TRD 4X4 OFF ROAD
    Just Amber LED turn signal lights for now
    Man , you guys are making me worry when I do my first oil change. I guess if I have any trouble I can go to my friend from highschool cause he owns his own shop, so I can borrow his tools if i need them.
  20. Aug 16, 2008 at 6:37 AM
    BillCarl
    BillCarl Enjoying my Tacoma
    Bluffton, SC
    2018 TRD Sport Double Cab Long Bed Blazing Pearl Blue
    Access Roll-up Tonneau Cover Toyota Stainless Steel Step Bars
    Yep, that was my experience at 5,000 miles too. Took persistence to get it off.
    I bought a case of Toyota Oil Filters and notice that the gaskets have a plastic film over them and they are pre-lubricated with what looks like a silicone lubricant. So, I didn't bother putting a film of oil over the gasket. Based on this thread, that may mean I'll find it hard to get the filter off at 10,000 miles too.
