First post first lift need help.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Dcshoe559, Aug 8, 2013.
  1. Aug 8, 2013 at 7:10 AM
    Dcshoe559
    Dcshoe559 [OP] Member
    Grand junction co
    2002 3.4l 4x4 Magnuson Supercharger
    Nitro Gear 4.88, arb front locker, Marlin Crawler 12k#, Toytec BOSS Front Coilovers, SPC Upper Control Arms, Toytec front differential Drop Kit Custom Rear Leaf Springs, Bilstein 5125 series Rear Shocks, Powerstop Front Brake Kit, 8.4" Toyota 3rd member rear axle, ARB On-Board Air Compressor, URD 7th Injector Kit and Fuel/Spark Calibrator
    Need help lifting my soon to be truck.
    On order from Texas thanks to dealership sold it while I was doing paper work
    2013 tacoma trd automatic v6 4x4 crew cab
    This is my first lift and have been reading a lot of forums but still need to do research. My budget is somewhat tight I can pick up extra days at work to cover cost. Lift hoping to spend 1500 i will be taking on this project myself with help from forums and Youtube. wheels and tires I haven't researched enough to know the cost
    I'm looking into getting the
    3" lift kit with bilstein 5100 height adj. coil overs
    Rear lift options- cs047r Dakar complete leaf springs
    Front diff drop kit: add 4x4 ?
    Rear shock options 5100 rear shocks
    Do I need uca? Not 100 % on tire size yet. But wheels most likely 16
    Any help is appreciated.
  2. Aug 8, 2013 at 7:14 AM
    SeacoastTacoma
    SeacoastTacoma Well-Known Member
    Eliot, ME
    '11 Base
    Husky liner floor mats, Vent Visors
    Just install the full OME package and walk away from the truck. 885s up front, Dakars out back, nitrochargers all around. You probably wont need UCA's, but if you do you've spent all of your budget and then some.
    Front diff drop is pointless.
    Save up some coin and then go out looking for wheels and tires.
  3. Aug 8, 2013 at 7:15 AM
    Dcshoe559
    Grand junction co
    Quick update.
    Use truck for moderate off road
    -Virgin Utah down hill mountain biking
    -Camping where only a few can get :)
    - riding dirtbikes in the sand dunes
    - on road for stay at home mom with 2 year old son since I have a company vehicle
  4. Aug 8, 2013 at 7:16 AM
    Large
    Large Red
    This is pretty accurate but I'd still get the UCAs. The $1500 doesn't include wheels and tires I hope.
  5. Aug 8, 2013 at 7:18 AM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    This ^^, except I would recommend UCA's. LR UCAs can be picked up fairly cheap from FatBobs or MetalTech as well as group buys. You can get by without them for a while, but I don't recommend it for long.
    Check around on downsouthmotorsports.com and other sites. Grab a buddy and do the work yourself, saves a ton of money on labor.
  6. Aug 8, 2013 at 7:18 AM
    Dcshoe559
    Grand junction co
    Ok ill do some research on that now.
    Definitely no diff drop heard a lot of pointless reviews on that.
  7. Aug 8, 2013 at 7:19 AM
    medic2230
    Murph
    Bama! Roll Tide
    If he goes 3" he will most likely need UCA's. There can be a big difference in drivability with within spec and dead on. Agree with diff drop on a 2nd gen it's useless. Also agree with OME kit with 885's.
  8. Aug 8, 2013 at 7:20 AM
    Dcshoe559
    Grand junction co
    No just the lift. Wheels and tires will be separate
    If I need the uca that will be separate also
  9. Aug 8, 2013 at 7:21 AM
    medic2230
    Murph
    Bama! Roll Tide
    Mine was about $2700 with full OME kit with Dakars assembled, LR UCA's and tires on stock off road wheels.
  10. Aug 8, 2013 at 7:23 AM
    SeacoastTacoma
    Eliot, ME
    '11 Base
    I would agree with both of you 100% if he were to try and go any higher, for example: 885x w/ 1/4" top plate spacer. Each truck is different, some need the UCA to get a good alignment, while others don't. Most people don't get coil-on-UCA rub, while others do. That said, it sounded like OP is on a budget and if he can get away without UCAs for a couple months and then install them as he is able that's ok too so long as the alignment is good.
    Edit:
    Well, with that said, go right ahead ind install the OME heavy kit and the UCAs at the same time :)
  11. Aug 8, 2013 at 7:29 AM
    jtav2002
    jtav2002 Kenny Fuckin Powers
    Josh
    Reading, PA
    2013 Tundra DBL Cab TRD OR
    I'd get UCAs. Also your original option would work just fine as well I had that setup with no complaints. Cant go wrong with either setup.
  12. Aug 8, 2013 at 7:34 AM
    Dcshoe559
    Grand junction co
    Thank you for the replies. I guess I should have have a more accurate budget
    After researching more I will have a better understanding on what I can spend
    To do this lift
    What size tires and wheels should I research on for the 885s up front, Dakars out back, nitrochargers all around
  13. Aug 8, 2013 at 7:46 AM
    SeacoastTacoma
    Eliot, ME
    '11 Base
    You can get away with a true 33" tire (with a properly backspaced wheel) if you don't get too crazy on the width. If you want to go wide you'll have to do some trimming on a new truck you probably don't want to do. I can tell you from experience on an OME setup that I got a 32.6" tire in there at 275 width, minor rubbing on the flimsy plastic fender liner.
    Check out the tire size calculator under the "mods & tutorials above". If you run a true 32" A/T or M/T tire it'll look pretty agressive and you'll be able to fully stuff the tires offroad without any trouble.
