First Post / Ready to Lift
Discussion in 'Suspension' started by tkbolts21, Jan 27, 2014.
  1. Jan 27, 2014 at 3:25 PM
    tkbolts21
    tkbolts21 [OP] Member
    TK
    TRD Sport
    Firstly, I have consulted multiple members about their builds and opinions and I thank you for your help!
    I'm only posting to help verify my choices..
    Looking to do the following to a 2014 DCSB TRD Sport
    - this is my daily driver
    - only off road on trails for hunting purposes
    - only looking to pull small boats and trailers
    - getting rims and tires from local shop (discounted)
    - all installation is going through local shop
    - I do prefer a slight rake (1/2 inch or so)
    - do not want to spend more than necessary (no UCAs etc)
    - goal is to trim as little as possible if not at all to get 285/70/17s (most likely Goodyear DuraTracs) and
    - ProComp 5001s 17s
    http://www.4wheelparts.com/Wheels/S...?t_c=11&t_s=210&t_pt=100073&t_pn=PXA5001-7983
    Bilsteins 5100 front and rear
    - front with stock coils
    http://www.autoanything.com/suspension-systems/61A5660A0A0.aspx
    ReadyLift 2" Block lift in back
    - any issues with the stock 4 leaf?
    http://www.autoanything.com/suspension-systems/61A4141A0A0.aspx
    Most likely getting Bilstein & Blocks from AutoAnything for about $320 shipped
    Looking to make the purchase soon.
    Any concerns?
    Don't hesitate to correct anything that is wrong / wont work!
    Thanks a lot for any input/recommendations,
    TK
  2. Jan 27, 2014 at 3:33 PM
    Large
    Large Red
    1/2" of rake and you have a 4 leaf pack I'd get an 1.5" AAL or 1.5" block, the alignment is hit or miss really, the only way to know is if you can't get the caster in spec after the front is done.
  3. Jan 28, 2014 at 5:40 AM
    tkbolts21
    TK
    TRD Sport
    Any other comments?
  4. Jan 28, 2014 at 5:47 AM
    headhunter247
    headhunter247 Well-Known Member
    St. Louis, MO area
    18 Taco Double Cab TRD
    5100's all around, OME 888 and Dakars. ProComp Series 05. Cooper SST Maxx 275s.
    Good choice on the wheels! I have 5100's all around, front set at 2.5", and stock coils. No block. I dont recommend a block lift. I tow a trailer periodically and it does just fine with a 2" AAL in the back.
  5. Jan 28, 2014 at 7:14 AM
    doubletaco
    doubletaco Well-Known Member
    Magnolia
    16 Quicksand TRD O/R 4x4
    TRD FJ Wheels, LED Fog lights
    Go with 5100's set at 1.75 and Icon progressive leaf pack.
  6. Jan 28, 2014 at 8:03 PM
    tkbolts21
    TK
    TRD Sport
  7. Jan 29, 2014 at 11:07 AM
    doubletaco
    Magnolia
    It's a little more for a leaf pack but the leaf pack has a better ride.
  8. Jan 29, 2014 at 4:16 PM
    tkbolts21
    TK
    TRD Sport
    Thanks. Probably going with the Icon after the advice and further research.
    I am now between 2 versions of the same wheel.
    Which is less likely to cause rubbing?
    Wheel Size: 17x8
    6 on 5.5 Bolt Pattern
    Offset: 0
    Backspace: 4.5
    Wheel Size: 17x9
    Offset: 6.6
    Backspace: 4.75
    Thanks again fellas!
  9. Jan 29, 2014 at 5:12 PM
    Houston-76
    Houston-76 Well-Known Member
    Montgomery Co Tx
    08 trd pr dcsb
    Tinted windows - weathertech floor mats - removed front mudflaps - no seatbelt chime mod - fogs on anytime mod - Borla catback exhaust - afe throttle body spacer - K&n filter - Kmc Xd hoss wheels 17X9 4.5 backspace - rubbers are 275/65 17 yokahama geolander a/t's - Maxtrac 4" lift spindles - allpro standard leafsprings - 1.25 rear wheel spacers - arctic white headlights and fogs - kings coming soon - supercharger coming later
  10. Jan 29, 2014 at 5:30 PM
    Houston-76
    Montgomery Co Tx
    08 trd pr dcsb
    The wheel with the 4.5 will position the inside of the tire and the wheel further away from the spindle and upper control arm, so it would be less likely to rub. backspacing is kinda tricky because it's backward from what you would expect. as an example, if you have two rims of the same size with different backspace, the wheel with less backspace will stick out of the fender well more. welcome to TW ! :wave:
    check this out, pretty cool
    http://www.tacomaworld.com/forum/wheels-tires/102992-wheel-backspacing-offset-info.html
  11. Jan 29, 2014 at 5:33 PM
    Houston-76
    Montgomery Co Tx
    08 trd pr dcsb
    X 2 Good setup here bud :)
