First Tacoma 5 lug Front Brake Job
Discussion in '5 Lug' started by ajb6948, Jul 20, 2017.
  1. Jul 20, 2017 at 11:45 PM
    ajb6948
    ajb6948 [OP] Member
    AJ
    '13 White Tocoma Access Cap 2x4 4cyl
    none yet
    2013 Tacoma Access Cab, 4 cyl, 5 lug.
    Observations: Each of the 4 pads were identical. Each had the wear indicator.
    Dummy me: Didn't take pics or write down the position of the indicator/squeeker.
    Help: driver side/passenger side, inside (caliper piston) pad/outside pad,
    top or bottom. Where in the hey do them little squeekers go? Or just use one
    per wheel? Where?
    NEXT TIME I WILL TAKE PICTURES!!!!!!!!
    I now have a metal to metal squeal when I put on the brakes just before the truck
    stops (passenger side). Any ideas as to cause?
  2. Jul 27, 2017 at 6:58 PM
    ajb6948
    ajb6948 [OP] Member
    AJ
    none yet
    Finally found some answers. All 4 pads are the same. There is only 1 wear indicator per pad and it's at the bottom when sitting in the bracket. Once the caliper bracket inserts are in, the tabs need to be bent to hold the insert in place. Don't forget to put caliper lube on the pad contact points. BTW Torque specs are: Caliper slide pin bolt 65 ft/lb, caliper bracket bolts 80 ft/lb and lug nuts 80-85 ft/lb.
  3. Jul 28, 2017 at 10:30 AM
    SamGoingHam
    SamGoingHam IG: SamGoingHam
    Sam
    Phoenix, Arizona
    2014 TACO 5LUG LOCKED
    Dude waited so long, he started answering his own questions:argue:
    ajb6948 [OP] likes this.
  4. Jul 28, 2017 at 12:49 PM
    ajb6948
    ajb6948 [OP] Member
    AJ
    none yet
    YAHOO, at last somebody chimed in! ROFL! Thanks Sam!
  5. Sep 26, 2017 at 2:48 PM
    Railwayrog
    Railwayrog Well-Known Member
    Dammeron Valley, UT
    2019 DC 4x4 Off Road
    Must be quiet on the 5 lug side.
    reason i found this is I'm doing pads this week.
    What pads did you go with?
  6. Sep 26, 2017 at 3:25 PM
    Early B.
    Early B. Well-Known Member
    Brad
    metro Atlanta
    2014 2.7L, 5 lug Tacoma
    18" tires and rims, 2.75" Procomp lift, Fox shocks in rear.
    Railwayrog likes this.
  7. Sep 26, 2017 at 8:22 PM
    ajb6948
    ajb6948 [OP] Member
    AJ
    none yet
    Those are some really good pads. Mine were worn all the way down to the point of smelling the backing plate! LOL Used a set of o'reilly's pads. They seem to work real good but already saving up for Akebono Pads for the next change. I'll be changing the rotors at the same time so I'll be looking for a "kit".
