first tank mpg 6spd 4x4.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Dsmooth87, Sep 6, 2011.
  1. Sep 6, 2011 at 4:24 PM
    Dsmooth87
    Dsmooth87 [OP] Well-Known Member
    11' doublecab 6spd 4x4 trd offroad
    Satoshi Grille. 245/75r16 hercules terra trac a/t. Afe pro dry s. ome 884s toytec 1.5 AAL for TSB. Twm shift knob
    drove to san diego this weekend on my very first vehicle fill up. average speed was 77 mph. i calculated 17.4 mpg. will these #'s get better when the truck breaks in?
  2. Sep 6, 2011 at 4:26 PM
    Goober
    Goober Earthlings are fun to watch!
    Utah - Why just have only one?
    '11 TRD Off-Planet AccessCab
  3. Sep 6, 2011 at 4:30 PM
    MJonaGS32
    MJonaGS32 MJ on a GS
    MJ
    SF Bay Area (East)
    07 LT 4x4 DCSB 6spd Vagabond
    Drifter wedge camper, Dual battery, OBA, ARB locker, 4.56 gears
    not necessarily. 17.4 is actually pretty good for that speed
  4. Sep 6, 2011 at 4:34 PM
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    09 Access Cab Prerunner
    Rear Leaf spring TSB, Bilstein 5100's all around w/ front set at 1.75", 265/75R/16 Mickey Thompson Baja STZ's, Trailer hitch w/custom wiring, AFE drop in dry filter, Rear Diff breather mod, Debadged truck, customized stock TRD wheel center caps, added factory fog lights, bed mat, door sills, tinted windows
    I do not know where you came from as you traveled to get to SD, but it seems you were breaking the speed limit law? :confused:
  5. Sep 6, 2011 at 5:03 PM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    Coming back from Portland right now. Last tank was 21.7. Going 70 w AC on high.
  6. Sep 6, 2011 at 5:04 PM
    Dsmooth87
    innocent till proven guilty. thanks for the responses
  7. Sep 6, 2011 at 5:05 PM
    aficianado
    back to bone stock.
    Now my wife is driving. I'll probably get 19.
  8. Sep 6, 2011 at 5:08 PM
    tinker_troy
    tinker_troy Well-Known Member
    T R O Y
    WY/SD
    #3, 2015 SR AC 4x4 V6 6 speed
    shackle brace, rear sway bar, 3 gen seats, Coupe Shifter, 3rd gen OR front springs + shocks, 17" TuRD PRO replica wheels
    x2
    What octane were you running?
  9. Sep 6, 2011 at 5:19 PM
    Dsmooth87
    87 octane . the cheap stuff. is there a difference in mpg?
  10. Sep 6, 2011 at 5:23 PM
    Uncle Cliffy
    Uncle Cliffy Never tell me the odds.
    Clifford
    So. Oregon
    06 DCSB 4x4
    https://www.tacomaworld.com/threads/uncle-cliffys-build.327590/
    My DC off-road 4X4 6 speed can't seem to crack 15.5... Lots of city driving and fireroads though. First road trip on the freeway might get it over 16. ;)
  11. Sep 6, 2011 at 5:25 PM
    tinker_troy
    T R O Y
    WY/SD
    according to some you get better with 91
    I have tried it and noticed very minimal gains
    usually with a 6 speed the best way to get good gas mileage is by slowing down and doing 60-65.
    Maybe they changed the gearing in the 2011s
  12. Sep 6, 2011 at 5:34 PM
    Dsmooth87
    nah i think its still the same...i was at like 2800rpm @ 77ish.
  13. Sep 6, 2011 at 5:39 PM
    MJonaGS32
    MJ
    SF Bay Area (East)
    octane doesn't matter with these trucks. Same mpg regardless
  14. Sep 6, 2011 at 5:42 PM
    Chris(NJ)
    Chris(NJ) Well-Known Member
    Usually in Central Jersey
    08 Indigo 4x4 DC OR
    Mods are currently being changed .....
    x2.
    I was getting about 18 prior to the upsize in tires. So imo, your #s are just about right on w/ what I was getting. (mine was also a solid city/hwy mix.
  15. Sep 6, 2011 at 7:17 PM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    Gas containing ethynol has seemed to reduce mileage, so avoid Costco and ARCO gas if you think so, too.
    Highway mileage on my automatic DC Off Road 4WD is typically 17-18 mpg... with the very best ever at 19.5 mpg (on Mexican 87 octane gasolina, no eco junk in it).
  16. Sep 6, 2011 at 10:26 PM
    supralight
    supralight Well-Known Member
    Dan
    Earth
    2013 4Runner limited
    and your point is???? What are you confused about?
    And this is a pretty good mileage for a manual at 77MPH highway. I bet you did some lower speed driving on backroads...
  17. Sep 6, 2011 at 10:33 PM
    Unknown
    Unknown He who angers you conquers you
    Brian
    Los Angeles
    Unknown
    Unknown
    nah
  18. Jun 2, 2012 at 8:31 PM
    Dsmooth87
    i made this same trip again @ same speed. and am averaging 19mpg. 9000 miles on the truck
  19. Jun 2, 2012 at 8:48 PM
    Rupp1
    Rupp1 "If you can dodge a wrench, you can dodge a ball."
    NC
    2015 DCSB OR Auto Silver Sky 4x4 / 2017 4Runner Premium
    Just finished my first tank in my "new" 2010 DCSB Off Road 6-Speed. Just didn't care about how I drove. Came out right at 17 even. Not that it matters. I'd just like to get to know what it will and won't do.
    Rowing gears and loving it!
  20. Jun 3, 2012 at 7:28 AM
    Priddle
    Priddle And now for something completely different....
    St. John's, NL Canada
    2014 Tacoma 4x4 TRD Sport DCSB
    Current: Pelfreybilt front and rear bumpers, winch, icon front coils/shocks, Icon rear shocks, Dakar leafs, Camberg UCAs, Pumpkin Android stereo, custom sub box w/ 2x10" RF subs and Kicker amp, short shifter kit, Fuel Beast 18" wheels w/ 1mm offset, BFG AT2 285/65/18
    I don't understand why the 6 speeds rev at 2200 rpm at 100kph, 60-65mph. Sounds like nothing has changed with the newer models. Sometimes I'm in 6th and don't realize it and try to shift higher.
    Doing 77mph and 2800rpm is going to guzzle gas.
    I have bigger tires and calculated my speedo is out by 10% (it was out by 3% from the factory). I'll do 90-95kph on the speedo on the highway which keeps my rpm down to about 2000 which helps the gas mileage. I'm actually doing 100-105kph.
