First time 4WD, question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by nighthawk87, Aug 20, 2008.
  1. Aug 20, 2008 at 11:14 PM
    nighthawk87
    nighthawk87 [OP] Well-Known Member
    I put my new truck into 4WD tonight while driving down the road (pavement) which I know now is not a good idea and won't do again. I drove in 4WD for about 1/2 miles and made one left turn on a 2 lane intersection (wide turn, not sharp). Total driving with 4WD on was about 1/2 mile if that.
    After I put it back into 2WD it felt fine, just like it did in 4 HI. Does anyone think I did any damage on that short run? I am worried now.
  2. Aug 20, 2008 at 11:23 PM
    derekabraham
    derekabraham Living vicariously through everybody
    TW'S Hippy Liberal
    Portland, OR
    2002 4x4 4Runner
    Stick on hood scoop from Autozone.
    How fast were you going when you threw it into 4WD?
  3. Aug 20, 2008 at 11:23 PM
    Justin626
    Justin626 Well-Known Member
    Palmer, Alaska
    2007 4x4 TRD Sport DC Super White
    Toytec 3" w/ AAL, N-Fab Nerf Bars, Lightforce 170mm Strikers, N-Fab Light Bar, Metra Ipod Adapter, Scosche Auto Start
    You probably didn't even feel your tires skipping off the pavement. You probably didn't hurt anything. Unless it's real shitty out, like alot of snow and ice or if you are offroad in some loose shit, I wouldn't use it.
  4. Aug 20, 2008 at 11:26 PM
    nighthawk87
    I read the manual, so I engaged it at about 40mph and maybe went 50mph....
  5. Aug 21, 2008 at 6:00 AM
    Demoncleaner
    Demoncleaner Well-Known Member
    Upstate NY
    05 Dcab 6spd 4x4 TRD Sport w/Tow
    TRD exhaust Homemade bed mat & bed extender, front Drings, Short clutch throw, Summer: Stock 17's Winter: Blizzaks on 16' black steelies
    Your fine. Generally you want to be on a loose surface when in 4wd. The main thing to be careful of is tight turns on a traction surface. If you can't avoid that, taking a wide arch turn is the right call. You can engage 4hi up to 60 mph, but once 'in' 4hi, there is no speed limit.
