First Time DIY Oil Change 2.7l
Discussion in '4 Cylinder' started by FlightMedic178, Jan 11, 2014.
  1. Jan 24, 2014 at 8:42 AM
    bicyclist
    bicyclist Well-Known Member
    Yes, that's the way it's done on the 6 cyl engine. The 4 cyl has it's filter in a different location.
  2. Jan 25, 2014 at 8:00 AM
    FlightMedic178
    FlightMedic178 [OP] Well-Known Member
    Nate
    Phoenix
    2020 SR Utility, 2013 Land Cruiser
    Bone stock
    Negative. Hand tight. Thanks!
  3. Feb 11, 2014 at 5:44 PM
    clc clc
    clc clc Well-Known Member
    PA
    2012 4x4 reg cab tacoma/2020 subaru crosstrek
    Sorry to rehash a old thread but this has been most helpful as im about to do my first ever oil change. So, is it best to take the filter off before or after you drain the oil? And why?
  4. Feb 11, 2014 at 6:45 PM
    Yotabilly
    Yotabilly Well-Known Member
    The Bluegrass
    2013 4cyl,5spd.4x4 Reg Cab
    UWS low profile toolbox, tint, rainguards, color matched grill surround 265/75r16 Goodyear Duratracs Ultra-Guage XB fogs, Weathertech Floor Liners, OME 884s, 2"AAL, Bilstein 5100s, FJ Trail Team wheels, Matt123 skid plate, 30" light bar, Rigid Duallys, Bed extender
    ^^^On the 2.7 I take the filter off first, just because. You'll need a filter wrench and not a universal one. You need the 64mm, 14 slat oil filter wrench. I got mine at Advanced Auto for four or five dollars.
  5. Feb 11, 2014 at 6:50 PM
    clc clc
    PA
    Sweet thanks. Just hand tighten the new filter right?
  6. Feb 11, 2014 at 7:02 PM
    clc clc
    PA
    Oh. Also, what do you do with your used motor oil?
  7. Feb 11, 2014 at 7:09 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    Is the Fumoto valve that much of a benefit on the 4-cyl, where the filter will make a mess anyway and have oil run down your forearm? :p
  8. Feb 11, 2014 at 7:12 PM
    Yotabilly
    The Bluegrass
    Yeah, just hand tight. Most auto parts stores have recycling tanks. I just pour it from the catch pan back into the new empty oil jugs and take it to Autozone.
  9. Feb 11, 2014 at 7:20 PM
    Xaks
    Xaks Cranky & often armed sysadmin
    Xaks
    Oklahoma City area
    work beast '06 reg cab 4 cyl 5 spd
    I have a couple of buddies with garages, and I take my truck there with oil/filter/etc that I buy, usually alternating shops.
    While I wait for the engine to cool enough to change the oil, I work on their computer issues for free.
    Then I change the oil using mostly my tools and such, but their floor jacks/creeper/disposal of old oil service.
    Works out well for both.
  10. Feb 11, 2014 at 7:25 PM
    Yotabilly
    The Bluegrass
    I actually take mine to Advanced Auto they let me walk to the back and pour it in the tank, but I have to take the empty jugs with me. I don't mind since I'd have to throw them away even if I had a "dedicated oil jug". I didn't know WM took used oil.
  11. Feb 18, 2014 at 3:23 PM
    Hot2na
    Hot2na Well-Known Member
    Anybody have a picture of the oil filter location on the 2.7 ???
  12. Feb 18, 2014 at 8:15 PM
    Xaks
    Xaks
    Oklahoma City area
    If there isn't one handy when I get home from work tomorrow, I'll go outside and take some above/below pics for ya. I've got the manual 2.7.
  13. May 13, 2014 at 6:08 AM
    Jimbos13
    Jimbos13 Well-Known Member
    James
    Rhode Island
    2011 2.7L SR5 4x4
    Lets open this thread again just for fun! :goingcrazy: Use the dip stick! Not everyone is draining the same amount of oil during oil changes. Some people on here say they let in drain over night, others may drain for 5 mins. The more/longer you drain the more oil you need to add. Use the damn dip stick.
  14. May 13, 2014 at 7:41 PM
    09sr5
    09sr5 gonna be a long ride
    East Tennessee
    2009 sr5 2.7 4x4 AC
    265/75 AT3's on stock wheels. 5100's@1.75". Trail Gear sliders. Toytec AAL
    Yup. 1 5qt jug and 1qt, slam the hood and go lol
  15. May 17, 2014 at 1:13 PM
    #35
    car78412
    car78412 Well-Known Member
    Hudson Valley NY
    13 Tacoma reg cab 4x4
    The drain plug on my 2.7 is facing straight down. When I remove the drain plug it empties with such force that it splatters all over the garage floor from the catch pan below. I never owned a vehicle with such a dumb location of the drain plug.
  16. May 17, 2014 at 2:51 PM
    #36
    Xaks
    Xaks
    Oklahoma City area
    My peeve is the filter on the 2.7. Almost unpossible to not get oil all over the frame if you aren't on a lift.
  17. May 17, 2014 at 6:10 PM
    #37
    Yotabilly
    The Bluegrass
    The filter is the only messy part for me, but it's not bad. It's probably good for your frame.:D
  18. May 17, 2014 at 8:09 PM
    #38
    rickcrna
    rickcrna Well-Known Member
    Rick
    Central Oregon
    '13 AC SR5 4WD I4 Auto MGM
    A fumoto drain valve makes the job so much easier. Next time I do my oil change I am going to use some ramps to give me extra room underneath. Should make getting to the oil filter a lot easier.
  19. May 17, 2014 at 8:21 PM
    #39
    Xaks
    Xaks
    Oklahoma City area
    When I change mine at a buddy's shop with a full lift and telescoping collect cans (on wheels!), I don't spill a drop basically.
    Out in the driveway without jacking? Yer gettin' wet, son.
  20. May 19, 2014 at 3:34 AM
    #40
    SVHANC
    SVHANC Kermit
    Sam
    Knoxville, TN
    '10 4x4 5sp 4cyl Access Cab
    Weathertech Floor Liners, Scangauge 2, Tailgate Hose Clamp, Rear Seat Headrests Removed
    Fumitory valves are the way to go. Flip it open and walk away for 15 minutes.
    The only way I have found to keep from making a mess with the filter is to use a walmart bag to take it off (kind of like picking up dog poop).
