First Time Towing - 2 SeaDoos + trailer need advice!
Discussion in 'Towing' started by The Traveler, Jul 19, 2012.
  1. Jul 19, 2012 at 1:36 PM
    The Traveler
    The Traveler [OP] Desert Chief
    SoCal
    1991 Toyota Pickup 4x4 Prerunner
    Hey guys,
    We're doing a camping trip out to Lake Mead this August, and after reserving a houseboat and wakeboard boat, my cousin who is in charge of organizing things, got us 2 waverunners for the weekend as well :eek: The catch is, unlike the houseboat and wakeboard boat, the skis are here in OC, meaning I'm taking my truck because I'm now the only person in my extended family who owns anything that can tow. (persians...don't ask).
    Never towed anything in my life. I've only helped my dad back up our old camper in the Suburban a few times, other than that, no experience.
    Trip is roughly 300 miles, consisting of mostly flat desert with several sections of gradual elevation change, including one downhill grade that can get a little hairy for semi trucks, and one uphill grade but I'm not worried about that. I know I'll probably drop to 11-12mpg with my 33" tires...prepared for that.
    I'm looking for some tips and tricks for driving on the interstate, turns, and most importantly, the best drive mode (2hi, 4hi, 4lo?) to get in and out of the boat launch at the lake's marina...and can I do this without a diff breather mod??
    I'm spending next weekend relocating my 7-pin connector after shredding it to pieces out at Ocotillo Wells last month...Thanks again :)
  2. Jul 19, 2012 at 1:45 PM
    Hunter500ky
    Hunter500ky Well-Known Member
    E-Town Ky
    06 Tacoma 4x4 SR5
    Weathertech Mats, Toolbox, 6k HID fogs, Hardwire Escort 8500 x50,
    Cake, just watch your turns. You'll have to swing a little more (not wide but not like you normally do)
    2hi for launching unless you start slipping (highly doubt it), if you must do 4hi BUT drive straight don't turn then get out of 4hi.
    Should be a easy run for you.
    Also remember it'll take you longer to stop.
  3. Jul 19, 2012 at 9:32 PM
    RightYouAreKen
    RightYouAreKen Well-Known Member
    Seattle, WA
    '11 4x4 DCLB TRD Sport
    You probably know since you've backed up your dads rig, but a tip for backing up: put your hand at the bottom of the wheel and move it in the direction you want the trailer to turn. To turn the trailer right, move your hand right (which turns the wheel left) and visa versa.
  4. Jul 19, 2012 at 9:36 PM
    Project.paradigm
    Project.paradigm Well-Known Member
    Oil Country,Alberta, Canada
    04 TRD 4X4 Dub cab
    Airlift rear air bags. Hood struts. sockmonkey bedside decal. TRD supercharger(not installed). Deckplate. Grey wire mod. Extended rear diff breather. 6000k HIDS. 18"Magnaflow. Truxxx 3" level kit. (Temporary) Wet Okole seat covers. BoxRocket bed rack. Bora 0.75 wheel spacers All pro sliders. BAMF BPV. B&M trans cooler.
    Don't forget to cross the safety chains. It'l give the tongue some thing to rest on if it comes loose, instead of hitting the ground.
  5. Jul 20, 2012 at 10:40 AM
    The Traveler
    SoCal
    Thanks for the tips! Never thought about crossing the chains...that's a great idea.
    Any insight on whether or not to do the diff breather mod before going on this trip? I'd hate to fill my diff with lake water :(
  6. Jul 20, 2012 at 10:46 AM
    Hunter500ky
    E-Town Ky
    06 Tacoma 4x4 SR5
    Sure, do it.
  7. Jul 20, 2012 at 11:35 AM
    Project.paradigm
    04 TRD 4X4 Dub cab
    It's an easy mod. Better to be safe than sorry.
  8. Jul 20, 2012 at 3:03 PM
    Large
    Large Red
    It's also illegal if you don't cross them, here in TX anyway.
  9. Jul 20, 2012 at 3:12 PM
    newertoy
    newertoy Well-Known Member
    Kevin
    East Tn
    2003 4x4 extra cab
    2" lift AAL and Bilstiens-front-rear,front diff drop. main drive drop
    Just a little tip for launching the seado--keep it OUT OF GEAR or in neutral when backing down the launch ramp. I find it easier. 4x4 for the pull out-Lo is easiest for control. If it is pavement(not gravel) you might be able to get out in regular 2wd.
    PWC are not as HEAVY as larger boats.
    HAVE FUN
  10. Jul 20, 2012 at 3:18 PM
    rcfreak201
    rcfreak201 Well-Known Member
    Driving with a trailer is easy, just gotta remember its back there. Usually with jetskiis its no big deal, we tow jetskiis and jet boats down to laughlin every summer. Only thing I would suggest is keep extra room for breaking, dont make U-turns(usually the storage box on the trailer will hit your tailgate if its too sharp) and when backing up the trailer will go the opposite way(You go right, trailer will go left). Again don't get yourself into a situation where the trailer is turned too much to where it might hit the truck, just go forward and start over.
    Not sure on tacomas, but on our GMC Sierra the handle on the trailer needs to be facing the storage box when putting the tailgate down or else it will hit it.
  11. Jun 13, 2013 at 9:16 PM
    mistahgood
    mistahgood Active Member
    Mistah
    South Carolina
    2013 Tacoma Access Cab 2wd 4cyl
    Anyone have any experience with the 2wd 4cyl tires on the ramps? Just looking to dump a jet ski in, nothing heavy. I'm just worried there isn't much meat on those model tires and the back end will be light.
  12. Jun 14, 2013 at 4:07 AM
    exploringcarolina
    exploringcarolina Well-Known Member
    Bill
    North Carolina
    2003 Tacoma
    No issues pulling my 2000lb SeaDoo boat out of the water on a paved ramp with a 2WD 2.4L Taco. Have not tried it on a gravel ramp, yet.
  13. Jun 14, 2013 at 4:17 AM
    exploringcarolina
    Bill
    North Carolina
    2003 Tacoma
    Trailer tires are not rated for speeds over 65MPH. I only submerge the trailer wheels to push & float the boat off or load on the trailer, but the Taco rear tires just touch the water unloading & loading my boat. If there is a rubber cap on the trailer wheel hubs, remove it to see if there there is a grease zerk to give one or two shots of grease with a grease gun to the wheel bearings before the trip.
  14. Jun 14, 2013 at 6:29 AM
    MowTaco
    MowTaco Well-Known Member
    Kansas
    16 Chevrolet Silverado
    If you have to drive in far enough to submerge the diff, you should probably drive back out and unstrap the skis from the trailer :p
    Depending on the angle of the ramp, you might get the taco a little wet but I'm guessing it sits up pretty high if you have 33s. I occasionally get the bottom of the rear bumper and dip the exhaust in, but that's with my dad's suburban so all that is really low to the ground.
    It ain't rocket surgery though, a little common sense and you'll be good :)
