First try at hdr
Discussion in 'Photography' started by 113tac, Apr 11, 2010.
  1. Apr 11, 2010 at 3:58 PM
    113tac
    113tac [OP] Well-Known Member
    Stephen
    Northern Virginia
    2017 Magnetic Gray Tacoma
    Mostly Stock for now, 265 75 16 Falken AT3W, Tinted fronts...
    ive been seeing some of these pictures around and thought they looked good so i tried it myself here it is
    its a little blurry but i dont have a tripod...any feedback on how to make it look better would be greatly appreciated!
  2. Apr 11, 2010 at 4:40 PM
    1337Taco
    1337Taco Well-Known Member
    Kevin
    NorCal
    2015 4X4 Manual
    I think that you need a tripod, it just looks to blurry
  3. Apr 11, 2010 at 4:50 PM
    MY50cal
    MY50cal ---- Tread Lightly ---- Leave No Trace
    Mojo
    Camden County, NC
    09 PM RC / 05 SWB AC (RIP)
    Yep.
    tripod...
  4. Apr 11, 2010 at 5:03 PM
    centraltaco
    centraltaco Well-Known Member
    Central, Louisiana
    '10 Dub cab 4x4
    Better lighting so the truck is not in the shadows. This will cause a faster shutter speed hence the pic will be much clearer. Nice wheels btw.
  5. Apr 11, 2010 at 5:23 PM
    113tac
    Stephen
    Northern Virginia
    alright i guess behind a tree isnt the best haha and thanks
  6. Apr 11, 2010 at 5:35 PM
    taos07
    taos07 Active Member
    2010 PreRunner SR5 TRD Off Road
    What camera and lens did you use?
  7. Apr 11, 2010 at 5:36 PM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    Pass that over here :D
  8. Apr 11, 2010 at 5:52 PM
    113tac
    Stephen
    Northern Virginia
    its a nikon coolpix, i dont have a good camera right now...might get a good one in the future not sure...i was just messing around, tryin to see what i could do haha
  9. Apr 11, 2010 at 6:09 PM
    Drewboto
    Drewboto Well-Known Member
    Drew
    Missouri
    Base model ಠ_à²
    (Former Tacoma owner) 17" Mustang wheels, Eclipse AVN 5435, Deck plate mod, vertical Maglite mount, K&N high-flow air filter, Delta gullwing box, amp, sub, 30 percent tint, floor lighting, tilt activated glove box lighting, lighting behind seat, engine bay lighting, SR5 grill surround, power windows, outside temp display
    It's sort of possible but most point and shoot cameras don't have an option to shoot in 48 bit color (which is optimal for HDR) like DSLR cameras.
  10. Apr 11, 2010 at 7:00 PM
    taos07
    As long as the camera has some sort of exposure bracketing function, you should be able to get your 3 shots. If not, you would have to manually over/underexpose the shots which would make it very difficult to hold the camera still enough without a tripod.
  11. Apr 11, 2010 at 7:09 PM
    113tac
    Stephen
    Northern Virginia
    i had to manually change it, but i just remembered that i have a tripod from my old camcorder, i might try it again tomorrow for better results hopefully
