Fishing Line
Discussion in '2nd Gen. Tacomas (2005-2015)' started by plmber58, Mar 28, 2009.
  1. Mar 28, 2009 at 5:49 PM
    plmber58
    plmber58 [OP] Well-Known Member
    Jim
    California
    09 PreRunner sr5 package Pyrite Mica color
    BLU Logic, Ipod interface, storage lock box for existing storage area, debadged, new color grill, wet okole seat covers, coming a Kenwood DNX6140 radio head unit, and a Protecta bed mat
    What stops the fishing line from destroying the paint when removing badges? I so want to get rid of all the badges on the doors and tail gate. I do have an 09. Is there anything different doing it on an 09? I want to do it but so afraid of screwing up the paint
  2. Mar 28, 2009 at 6:02 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    No, the fishing line will not mess up your paint. Heat up the badges first with a blow dryer. I did mine in my garage when it was 32 degrees. Just make sure you use a sawing action.;)
  3. Mar 28, 2009 at 6:08 PM
    neontrail
    neontrail ✈ ✈ ✈ ✈ ✈ ✈ ✈
    Idaho
    2004 NISSAN XTERRA XE/SE
    De-badged, Tint 20%, Blue 48 LED dome-light, .......
    the glue is so fresh, your badges will come off like butter with fishing line and a little heat.
  4. Mar 28, 2009 at 6:08 PM
    rpoint16
    rpoint16 Well-Known Member
    Tempe, AZ
    2022 TRD Off-Road, Super White.
    Bone Stock
    A guy at work took his TRD to a nice collision shop yesterday & had his TRD sticker & emblems removed. Charged him $50.00. All buffed & waxed.
  5. Mar 28, 2009 at 6:12 PM
    Hardcorehehaw
    Hardcorehehaw 1 man wolf pack
    Evan
    09 Magnetic Gray PreRunner
    Debadged, 20" Liquid Metal Magmas, Yokohama Parada Spec x 285/50/20, Llumar clear bra, Fold-A-Cover G4, Weathertech liners, Wet Okole seat covers, JBS technologies keyless entry keypad.
    I used 40lb braided fishing line to saw through the glue. I tried using a blow dryer to heat the badges first but it was taking way too long.
    Using just the fishing line, it took me less than 1 minute per badge.
    Because of the way to have to hold it, the fishing line rubs more against the badge than the paint, it will not affect the paint at all.
  6. Mar 28, 2009 at 6:15 PM
    TrdPETE
    TrdPETE Well-Known Member
    Maui
    08 double-cab 4x4
    TSB, Motto Metal 954, 5100s all around, front set @ 2.5, M/T baja atz radial, 285/70/17,Kenwood dd712,halo cccf,de-badged
    I took mine off without even heating them up. The line cuts between the double sided tape and the emblem. Doesn't really come in contact with paint, or very little.
    Of course it was 76 dgrees here when I did it. Ditto on the sawing action.
  7. Mar 28, 2009 at 6:45 PM
    plmber58
    Jim
    California
    Lately it has been close to 80 hear.. Once emblems are off then what. I so do not want to hurt my truck but I want to make it look good I just do not want to screw it up so I take it you run the fishing line behind the emblam and saw away out toward you..Then what to do as I read somewhere here that a new glue is being used and a shadow is left behind. Is that true? Anyone done this to an 09? Here is a couple of pictures of my ride after her first bath
  8. Mar 29, 2009 at 3:01 AM
    Hardcorehehaw
    Evan
    I have a 2009 and debadged it about 2 weeks after bringin it home.
    Your truck will be fine, trust me. There will be no shadows, scratches or swirls.
    When removing the badges you will be forced to hold the line at an angle that is cutting more towards the badge than the paint's surface because of the way to have to hold the line to get a grip on it, you will see when you start doing it.
    It will not be necessary for you to heat up the badges first because your truck is brand new and it's warm enough outside.
    Do as this thread says and you will be fine:
    http://www.tacomaworld.com/forum/detailing/14432-de-badging-painting-badges-re-badging.html
    After getting all the glue residue off with the goo gone, I washed and waxed the entire truck.
  9. Mar 29, 2009 at 4:45 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
  10. Mar 29, 2009 at 4:48 AM
    TheKneeBiter
    TheKneeBiter Active Member
    I used weedwacker line and sprayed quick detailer while doing it. Worked perfect. Black sand pearl and no scratches.
  11. Mar 29, 2009 at 5:56 AM
    longbow
    longbow I see you now..................
    Bill
    Indiana
    05 Tacoma Silver Mica TRD 4 Door
    Toy-tec Coil over lift, Eibach 700 lb springs, Sway bar relocate, Total Chaos UCA's, Moto metal wheels, BFG mudterrians, HID, custom 3 piece grill, Highlift jack w/custom mount, Highlift jack cover, bed matt, de-badged 100%, storage box lock mod, using defrost w/o AC mod, short antenna mod, horn re-locate, Tire Gate flat spare tire mount, engine cover painted, bed light (1) mod, wreck bar carrier, Blue Sea 5026 fuse block, center console outlet, flash light mod, Blue Sea inline fuse, Shrockworks sliders, All-Pro front bumper, Piaa 510 driving lights, Warn shackles front, Kennesaw rear bumper, "Tag Boltz" plate lights, Warn shackles rear, Warn M8000 winch, devil horns, BHLM, weathech liners front and rear.....T.W. sticker of course. Custom Sock bed decal for Michele
    I have and 05 and took the badges off a year ago, just take your time. I know it seems like you are going to mess something up, but you wont.
    I used goo gone to remove any glue junk, then used 1 Grand and then a good waxing.
    No shadow at all.
    I didn't use a hair dryer, just sat it in the sun for awhile.
  12. Mar 29, 2009 at 7:36 AM
    jward2331
    jward2331 Well-Known Member
    Fleming Island, Fl
    '08 PreRunner SR5 TRD Sport
    Debadged, tinted windows, upper/lower Grillcraft (horns relocated), Hella 500's with HID Mod (55W 5000) behind grill, shorty antenna, WeatherTech side window deflectors, suspension TSB, Westin Signature Nerf bars, JVC KD A-615 Head Unit with Sirius Direct tuner, Blacked out headlights, DTDL Mod (Switch for on/off), Hard Wired GPS, NOKYA Arctic Hyper Yellow Fog lights, Fog lights on anytime Mod, Michelin LTX M/S2 (P265/65R17), Powder coated OEM wheels. LED ANZO tail lights, Weather Tech FloorLiners.
    Since your truck is so new... don't worry about it. It was the first thing I did to mine. I did use Mineral Spirits to clean the glue off. Wiped clean then waxed.
    Get rid of the "Stealership" front license plate though! Either find something that is a hobby (Harley) or take it off. Luckily mine didn't have anything so the front is clean.
  13. Mar 29, 2009 at 7:41 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    X2. Except I used the fishing line.
    OP, The spary detailer acts as a lubricant on the line, helping it to cut thru.
  14. Mar 29, 2009 at 11:30 AM
    neslerrah
    neslerrah Taco lovin'
    Harrelsen
    Tucson
    5 lug BEAST!
    Secondary air filter removed, elbow mod, BFG T/A KO (31x10.5R15), 15" American Racing Mojaves, BHLM, Dome Light MOD (Blue), Pioneer headunit, Sockmonkey 'TACOMA' Decals, Readylift 5-lug SST, Rear Shocks - Bilstein TRD, Dynomax Super Turbo #17748, DDM Slim Ballast HID Kit H4 Hi/Lo -35W 6000K in headlights, Apexcone Raptor HID Kit H3 - 35W 6000K in Hella 500s, aFe CAI #51-10762, WeatherTech Floorliner, 200W Smart AC Inverter
    The help from the Tuc-sizzle 95 degree weather made this MOD a breeze! I used a fishing line, a 10-lb rated line.
  15. Mar 29, 2009 at 10:30 PM
    plmber58
    Jim
    California
    Well tomorrow I am going to do it and I want to thank all for their input
    Thanks
