Fitment: 07 with a 3" lift 33"12.5" 17"
Discussion in 'Wheels & Tires' started by Saskyota, Sep 29, 2010.
  1. Sep 29, 2010 at 4:36 PM
    Saskyota
    Saskyota [OP] Member
    Hey guys quick questions.
    Will a 33" tires that is 12.5" wide wide fit on an 07 Tacoma on factory 17's with a 3" lift?
    thanks in advance
  2. Sep 29, 2010 at 4:50 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Quick answer: most people with a 3" lift run 285/75R16 or 285/70R17. which is roughly a 33x11.0 inch tire. Even then they typically trim plastic and some chop the body mount and hammer the pinch weld.
    Expect more rubbing and or more trimming with the 12.5 inch tire. And you'll need a higher negative offset (got that? -- less backspacing for a given wheel width) for the 12.5 not to rub the upper-control-arm.
    EDIT - also, you don't tell us if you're first gen or second gen tacoma. Answer I gave is for second gen. (2005-2011)
  3. Sep 29, 2010 at 5:15 PM
    jrobson
    jrobson Well-Known Member
    Mobile, Alabama
    09 DC 4x4
    Ultimate lift kit, LR UCA's, Bi-xenon 8000K headlights, Xenon 8000K foglites, (4) KC slimlites on N-Fab light bar, Extang trifecta toneau cover
    Quick answer: NO, not without rubbing like crazy.
  4. Sep 29, 2010 at 5:24 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    yeah it will rub
  5. Sep 29, 2010 at 5:40 PM
    Saskyota
    Thanks guys, One of the Tacoma guys out here was interested in some new 33's i have laying around from another truck. Glad he wont be getting tires that wont fit his truck.
  6. Sep 29, 2010 at 6:11 PM
    Saskyota
    what if he were to run a small spacer like a 1/4"? the truck is lifted 3"
  7. Sep 29, 2010 at 6:29 PM
    ktmrider
    Junk
    wheel spacer or top plate or preload spacer. Either way its going to rub but you can easily trim to fit at least the fender, the cab chop is a little more hard.
  8. Sep 29, 2010 at 6:31 PM
    Its_Taco_Time
    Its_Taco_Time Well-Known Member
    Yorba Linda
    07 Tunda DC TRD Offroad
    CST spindles, Magnaflow, TRD intake
    You will need to chop the cab mount for sure. After that they will fit fine.
  9. Sep 29, 2010 at 6:31 PM
    solus
    solus HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
    nope... won't work without modification
  10. Jan 16, 2014 at 11:17 AM
    eddietaco13
    eddietaco13 Well-Known Member
    eddie
    east side ,LA
    2013 4x4 trd off road
    trd skid plate Total chaos uca Fox ext. Trvl. Rmt.res. coilovers in front Rear deaver aal wit fox piggy back shocks mt baja mtz tires flowmaster exhaust
    I cnt find anything on my 2013 that i wud need to chop. Mayb not needed for newr models?
