[Fixed, I think] What is this sound!? I don't think it is normal.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Bob_S, May 7, 2017.
  1. May 7, 2017 at 3:28 PM
    Bob_S
    Bob_S [OP] Well-Known Member
    2016 TRD OR 4x4 DCSB
    None yet
    If I ever figure it out, I will be sure to update and let you know. Hoping to get it in this week, but kinda busy.- aren't we all!
    shakerhood likes this.
  2. May 7, 2017 at 6:13 PM
    Toyota4Runner
    Toyota4Runner New Member
    You might want to check the bushings for the cam bolts.
  3. May 7, 2017 at 6:16 PM
    Toyota4Runner
    Bolts that are used to do alignments.
  4. May 7, 2017 at 6:30 PM
    kkoole
    kkoole New Member
    2016 Tacoma access cab TRD OR
    I have the exact same issue with my '16 trd OR. I also had a loose body mount. Totally different noise. That sounds like a marble rolling around the chassis. These are easy to check though. This noise seems to be coming from the front end.
    I always assumed it were my hid ballasts or cables knocking against the inside of the front. But this video sounds way to familiar!! I'll check the radiator and transmission coolers couplings and report back. To be fair, I've had this noise from day 1 and it doesn't seem to be getting worse. I have about 3k miles on mine.
  5. May 7, 2017 at 7:38 PM
    ToyoMann
    ToyoMann Well-Known Member
    2017 Tacoma TRD Off Road
    Sounds like a shock mount, but I am not sure.
    kgilly likes this.
  6. May 7, 2017 at 7:50 PM
    ToyoMann
    It sounds like someone either lied to you or was just plain dismissive.
  7. May 7, 2017 at 7:56 PM
    KFITE1
    KFITE1 New Member
    2016 Toyota Tacoma SR5 V6
    Mine does that too 2016
  8. May 7, 2017 at 8:05 PM
    surfrat
    surfrat Well-Known Member
    LI, NY
    icon coilover, total chaos UCA, allpr expo, icon 2.0 rear,wet okole
    Check torque on lca cam bolts 100 ftlbs
  9. May 7, 2017 at 8:11 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Are the brake pads shifting up and down in the caliper? try lightly pressing the brake when you go over a bump and see if the noise goes away.
    Also check sway bar links
  10. May 8, 2017 at 7:51 AM
    Bob_S
    None yet
    Even with light braking, I get the noise. I know the noise you mean with the calipers, this is definitely something else. Thanks for the input though.
  11. May 14, 2017 at 1:36 PM
    Bob_S
    None yet
    I think it is fixed. Took it to the dealer and they used the chassis scopes. Found it was coming from the front shocks. They replaced front shocks, and mounts, as well as replaced front body mounts. All seems to be working good so far. Thanks for the ideas, and if anyone else has this, maybe this will help you out. We will see if it lasts.
    kgilly, BountyOR_VF2 and shakerhood like this.
  12. May 14, 2017 at 3:07 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Better go off-roading soon just to be sure
  13. May 29, 2017 at 9:20 PM
    Chrispytaco91
    Chrispytaco91 Well-Known Member
    Christopher
    San Diego,CA
    2016 Tacoma trd offroad 4x4
    Update on the fix ?
  14. May 29, 2017 at 11:12 PM
    James_Bond
    James_Bond Well-Known Member
    Southern California
    '16 TRD Sport DCLB
    All stock
    I have the same high pitched clunk. TRD Sport. Please update on the fix.
  15. May 30, 2017 at 1:02 AM
    #35
    SoupaSoup
    SoupaSoup Not so well-known member
    Washington
    17' Off Road
    "To clarify a little" lol thanks for the clarification :crazy::crazy:
    tacoguy88 likes this.
  16. Jul 28, 2017 at 7:13 PM
    #36
    Bob_S
    None yet
    Been to Moab, did mild off roading, driven about 2000 miles since the fix. No noise yet, I'll keep my fingers crossed
    tcjacado likes this.
  17. Jul 28, 2017 at 7:28 PM
    #37
    ICU1
    ICU1 Well-Known Member
    Your dealership isn't normal
  18. Jul 28, 2017 at 7:39 PM
    #38
    Northern Taco
    Northern Taco Well-Known Member
    2022 Tacoma trd off road premium 2023 tundra trd off road
    My 2nd Gen started making this noise a month or two after frame replacement. I put new shocks on all around, and this noise (same as in your video) is driving me nuts. Did they say the front rad mounts were worn through? Or was it likely the top shock mounts?
  19. Jul 28, 2017 at 9:39 PM
    #39
    Chrispytaco91
    Christopher
    San Diego,CA
    I had the same noise. What it is the the front lower shock bushing.
    I took mine to the dealer they didn't want to warranty it....
  20. Jul 29, 2017 at 6:58 AM
    #40
    Northern Taco
    I've read that as well from YouTube comments. I took my lower shock bolt out and anti seized it, my bilstiens only had a few thousand miles on them when this creaking started.
    I'm going to have to find some time to disassemble the front shocks and have a look.
