[Fixed, I think] What is this sound!? I don't think it is normal.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Bob_S, May 7, 2017.
  1. Jun 26, 2018 at 2:02 PM
    #81
    urchim
    urchim Well-Known Member
    Tacoma 2016 TRD Offroad Inferno
    Your dad was a smart man :)
  2. Jul 1, 2018 at 3:22 PM
    #82
    UBYBC
    UBYBC Well-Known Member
    2014 Tacoma TRD OR
    My dealership indirectly confirmed the OEM Bilsteins are causing the noise. They already replaced them once, and since I'm now at 50K miles they will not do it again. No point really, since it will come right back. Left with the option of replacing the parts myself with 5100s or a different brand. Mostly the issue is very annoying and I can even feel the pop vibration through the floorboard. It's minor but I wish it was not there.
    BountyOR_VF2 likes this.
  3. Jul 2, 2018 at 10:44 AM
    #83
    BountyOR_VF2
    BountyOR_VF2 "If in doubt, flat out!"
    NorCal Bay Area
    2017 WHITE TRD TCSB OR
    So replacement with the same brand can help? I'm also debating rather I should change to the 5100 also, but wonder if the same problem will come back or not.
  4. Jul 2, 2018 at 11:35 AM
    #84
    UBYBC
    2014 Tacoma TRD OR
    the OEM Bilstein replacement only fixed the issue for about 6 months, and it returned. Most people have success with the 5100s they say. I'm not sure what brand I will use if I repair it again.
    BountyOR_VF2[QUOTED] likes this.
  5. Jul 2, 2018 at 11:57 AM
    #85
    WSW3
    WSW3 @willwitecki
    Will
    Connecticut
    '08 Tacoma DCSB TRD Sport
    Scratches, dents, and a lot of miles
    I had this issue and was lead to believe it was LCA bushings. I replaced the LCA's (so new bushings and ball joint) and it doesn't make the noise nearly as often. It only makes that noise now with larger articulation of the front end. I have 5100s that were put on a year ago at ~170k miles.
    Going to check cab mount and rad mount next...
    Also, unrelated: I have new calipers that rattle as if the bolts are not torqued down all the way (they are). The noise only happens on the driver side too. :bananadead:
  6. Jul 2, 2018 at 12:52 PM
    #86
    urchim
    pardon my ignorance what is "rad moun" where is it located or to look for ?
  7. Jul 2, 2018 at 12:55 PM
    #87
    WSW3
    WSW3 @willwitecki
    Will
    Connecticut
    Radiator support mount. Check to see if the rubber is degraded.
  8. Jul 2, 2018 at 1:24 PM
    #88
    urchim
    is it something easy to get to or view from top somewhere.
  9. Jul 2, 2018 at 4:18 PM
    #89
    Barcared
    Barcared Well-Known Member
    Philadelphia, PA
    2016 Barcelona Red TRDOR RIP. 2020 MGM TRD OR.
    best view is to take the grill off. takes about 2 minutes: it's a few plastic clips. If you still can't see it, take the front bumper off. that takes 10 minutes.
    honest. I just did it to fix some bumper damage and damage to the headlight mounts this weekend. A little bump from a stump I misjudged pushed everything up and cracked a bunch of plastic crap, but all holding well after some plastic weld and epoxy. It Took longer to read the directions then to actually take the grill and bumper parts off.
    https://www.tacomaworld.com/threads...ont-winch-bumper-install-instructions.446516/
    My radiator mounts were fine: just peeked at them since I had the whole front off.
    UBYBC likes this.
  10. Jul 4, 2018 at 10:56 AM
    #90
    Kirye1337
    Kirye1337 Well-Known Member
    2016 TRD-OFFROAD Access Cab - Silver
    need an update!, mines doing this!
  11. Oct 14, 2018 at 9:36 PM
    #91
    UBYBC
    2014 Tacoma TRD OR
    Circling back to this thread. It's the front suspension, mine was the exact same as the video. Then dealer replaced front shocks, noise stopped. Then the same sound returned 9 months later. Just installed a new aftermarket suspension and the noise is gone!
    whit3 taco likes this.
  12. Oct 15, 2018 at 12:42 AM
    #92
    Jfish12
    Jfish12 Well-Known Member
    2017 Black Tacoma TRD Sport RWD
    Wow.... I thought that was a normal sound like everything else on my ‘17 taco sport. I hear that noise in front going over bumps or exiting in and out of parking lot ramps.
    I usually have the radio on high to ignore the my problems and drive on. Looks like I’ll drop my taco to the speakership so it can be reported into the turd gen files.
  13. Oct 15, 2018 at 8:28 AM
    #93
    whit3 taco
    whit3 taco Well-Known Member
    Derek
    2016 trd off road. AC AT
    What suspension did you end up getting?
  14. Oct 15, 2018 at 7:57 PM
    #94
    UBYBC
    2014 Tacoma TRD OR
    OME 884 and 90021 shocks front, dakar's rear. I love driving my truck again.
    whit3 taco[QUOTED] likes this.
  15. Nov 30, 2018 at 6:40 PM
    #95
    Loomin
    Loomin Member
    Cement 2019 TRD Off Road
    OK, how about this? 2019 TRD Off-Road. I literally picked it up from the dealership Saturday. I haven't even owned it for a week. It's clunking when I hit a bump driving around town. It sounds like someone is knocking on the floor under the passenger front seat. The truck has less than 300kms (190 miles) on it. I'm not even through the first tank of gas! My previous vehicle was a diesel leaf sprung 93 Landcruiser and it didn't make any noises like this. Kind of irritated by this.
  16. Nov 30, 2018 at 8:40 PM
    #96
    Clingman
    Clingman Well-Known Member
    17 Inferno TRDOR DCSB
    I will say I just replaced radiator support mounts and it didn't fix my truck, although the mounts were degraded. I believe it is the driver front strut on mine now.
  17. Jan 22, 2021 at 2:29 PM
    #97
    Tacos and beer
    Tacos and beer Active Member
    Carlsbad, Cali
    2018 Tacoma OR 4x4
    I have been experiencing same noise as in original thread video. The shop that did my alignment told me it was cv axle that was sliding back and forth. When the control arm compresses and decompresses from going into driveways it puts the pressure on the axle causing the noise. I was told that he could fix it or take it to Toyota as it should be covered under warranty. Brought it into Toyota only to be told that they cannot duplicate the noise. Even though my alignment tech heard it as soon as he pulled it out of driveway. Dealer told me to wait until they allow ride alongs again to see if we can re-create noise when technician is in truck too. Dealer also said that the movement in the cv axle was normal. Still had to pay a diagnostic fee even with no diagnosis.
  18. Jan 22, 2021 at 4:00 PM
    #98
    Sosk
    Sosk Well-Known Member
    Evan
    Vancouver Canada
    2018 TRD Sport
    Re torque your cam bolts. even slightly over torque.
  19. Jan 25, 2021 at 8:50 AM
    #99
    Tacos and beer
    Carlsbad, Cali
    2018 Tacoma OR 4x4
    Thanks. Ill try this out.
  20. Jan 31, 2021 at 5:33 PM
    #100
    HB Taco
    HB Taco Well-Known Member
    Curt
    Huntington Beach, CA
    2019 F150 FX4 S Crew 3.5 TT
    Same noise here. I've been living with this for years. I upgraded to 5100's like 7 years ago and didn't have the noise just wanted the upgrade and lift adjustability. After a few years I was getting the dreaded click or clack noise when I hit a dip or something. At one point I put the stock shocks on and no noise. So about 4 years ago I put on a set of Bilstein 6112's on and no noise until about a year or two ago. I go back and forth saying oh well it's no big to dammit this pisses me off. Long story short I've taken the LCA's apart and lubed the bolts and torqued the shit out of them many times. I've had the sway bar out then put it back in. Lightly had the brakes on while hitting the infamous dip. Always happens when the front end compresses. I was going to change the Rad support bushing and had them almost out but honestly didn't look that bad so just holding off for now. I mean the noise goes away when I change the shocks? The top mounts never look bad for me but I put a new set on this last time. But the shocks don't look too bad so WTF is causing the shocks to make this noise. I dont really want to spring for another set of 6112's because otherwise they still work great. Back to living with it? or maybe get a set of 5100's? Has anyone replaced the lower shock bushings only? Maybe I should spring for something other then Bilstein's?
