Fixing missing bushing on front bed bolt
Discussion in '3rd Gen. Tacomas (2016-2023)' started by muskratX22, May 7, 2021.
  1. May 7, 2021 at 12:50 PM
    muskratX22
    muskratX22 [OP] Well-Known Member
    Dave
    Illinois
    This is for a friend......seriously.
    He had a 2018 Tacoma (not sure what model) and was hearing a loud bang noise from behind the cab. After inspecting everything he said the bushing on the front bed bolt was gone. I would assume it would be an easy fix...no?
  2. May 7, 2021 at 12:57 PM
    ToyoTaco25
    ToyoTaco25 Well-Known Member
    North Carolina
    09 Super-White DCSB 6-Speed
    ProComp 4" D-Bag, I mean Drop Bracket Lift, AMP Research Powersteps, 285/70-R17’s, Magnaflow, AFE CAI, Dipped Badges
    Easy is relative.
    You know what happens when you assume, don’t you?
    ORtoCOTaco likes this.
  3. May 7, 2021 at 12:57 PM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    If the bed plastic (where the bed interfaces with the frame) has been worn down enough, no matter how tight u get the bolt, the bed will be loose to flop, a spacer would have to be made up.
    Gunshot-6A and shakerhood like this.
  4. May 7, 2021 at 1:00 PM
    muskratX22
    Dave
    Illinois
    I just asked him what is missing. I haven't looked on my Tacoma, does the composite bed sit right on the frame or is there a spacer between?
  5. May 7, 2021 at 1:01 PM
    muskratX22
    Dave
    Illinois
    TT25 YES I know what happens when you ASS ume!
  6. May 7, 2021 at 1:02 PM
    muskratX22
    Dave
    Illinois
    So what happens on these? He said warranty won't cover it.
  7. May 7, 2021 at 1:05 PM
    muskratX22
    Dave
    Illinois
    Sorry for so many posts but what does one do to prevent this from happening??
  8. May 7, 2021 at 1:17 PM
    Skydvrr
    Nick
    YMH
    Black '17 OR
    If it's what I think you're talking about, the bed bolts get loose, then the bed vibrates / abraids the frame. Then no matter how much u tighten the bolt, the bed will have a gap against the frame. Could be wrong though
  9. May 7, 2021 at 1:22 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Yes. The bed sits on the frame. I believe there are sleeves that the bed bolts tighten against. If the bed is worn and making a noise, I believe the info previously posted, mainly for the similar 2nd Gens, is to not cut down the sleeves but rather slip in some heavy rubber material between the bed and frame, like a piece of old conveyor belt. That will make up the gap and prevent future wear.
  10. May 7, 2021 at 1:28 PM
    Clearwater Bill
    Billy
    Largo Florida
    There are a couple of thing here to consider.
    1. It happens, but not often
    2. Keep the bolts easy to remove, especially in salt country. Take them out one at a time annually and lube.
    3. Get under the truck and look over the mounting. You'll understand how a correction can be made should you ever have a problem.
  11. May 7, 2021 at 1:32 PM
    barf
    barf Petter of Dogs
    Barf
    WNC
    2019 m/t TRD OR DCSB
    OME Lift Viper Cut
    If he got the fuel pump replaced via the recall and they lifted the bed off to replace it (some people on here said their dealers mentioned doing it this way instead of dropping the tank??) and didn't bolt it down properly, could be covered. If he just wheeled the shit out of his truck and it came loose to vibration/bouncing around, it won't be covered. I agree with Bill ^. Crawl under and take a look. Or post pictures.
    tonered and Gunshot-6A like this.
  12. May 7, 2021 at 2:06 PM
    muskratX22
    Dave
    Illinois
    I just looked under my Tacoma. There are gussets that reinforce where the bed bolt goes through. This sits on a elevated bracket that comes off the frame. So what happens, is a case of a loose bolt???
    davidstacoma likes this.
  13. May 7, 2021 at 2:06 PM
    Malvolio
    Malvolio free zip ties for Stun
    SoCal Dumbgeon
    2017 DCSB SR5 2WD
    Wow, he’s outsourcing hard to his fifth circle of friends; you don’t even know what kind of truck he drives and here you are. You’re too good for him.
    Superhulk LB, Skydvrr and tonered like this.
  14. May 7, 2021 at 2:10 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    T55 (or is it T60?) and 60ft-lbs of torque. Piece of cake.
  15. May 7, 2021 at 2:43 PM
    muskratX22
    Dave
    Illinois
    HEY! A friend in need is a friend indeed!
    Malvolio[QUOTED] likes this.
  16. May 7, 2021 at 3:06 PM
    barf
    barf Petter of Dogs
    Barf
    WNC
    OME Lift Viper Cut
    Dude we can’t diagnose it without pictures. This kid has a Tacoma but no fucking phone? Tell him to send pics. Not of HIS, but of the TRUCKS undercarriage.
  17. May 7, 2021 at 3:12 PM
    jake72
    jake72 Well-Known Member
    Jake
    N.E. PA
    2019 trd off-road dcsb mt
    If he hauls heavy weight in the bed all the time it could cause this problem.
    muskratX22[OP] likes this.
  18. May 7, 2021 at 3:16 PM
    muskratX22
    Dave
    Illinois
    Do a google search--this is not something new to Tacomas.
  19. May 7, 2021 at 3:20 PM
    barf
    barf Petter of Dogs
    Barf
    WNC
    OME Lift Viper Cut
    Then why are you asking us?
  20. May 7, 2021 at 3:20 PM
    robe689
    robe689 Well-Known Member
    Bob
    SE Connecticut
    2020 Silver Tacoma SR5 Access Cab V6 4WD
