FJ Auxiliary Light Switch Install? Diy? Part Numbers?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by steveo27, Jan 26, 2017.
  1. Jan 26, 2017 at 8:36 PM
    steveo27
    steveo27 [OP] Ask me about my weiner
    Pittsburgh
    '11 TRD Off Road & 1992 VW GLI
    The same shit everyone else has.
    After some debate, I think I finally figured out what I wanna do for my light bar switch. The Ch4x4 and Mictuning switches all look cheap and dont match enough to pass as OEM. The solution is an OEM auxiliary driving light switch. Its an OEM part so itll match 100%.
    Said switch -
    Im working on putting together a list of parts to do the install.
    Parts List -
    - AUXILIARY DRIVING LIGHT SWITCH - PT297-35070-AS
    - HOUSING, CONNECTOR, FEMALE - 90980-10933
    - FEMALE TERMINALS - ????
    I need to source female terminals still. Toyota sells repair wires, but Id much rather crimp new connectors on the existing harness to complete the job.
    I believe these are the correct terminals Sumitomo TS / SL Female Terminal 0.5 - 1.25 mm2 ( 20 - 16 AWG ) These terminals are used for the heated mirror switches and I believe they are the same for the light switch plugs
    Can anyone verify these are correct?
    Ill update this thread with more info once I have the correct terminals found and ordered
    jmaack likes this.
  2. Jan 26, 2017 at 9:18 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
  3. Jan 26, 2017 at 9:43 PM
    steveo27
    Pittsburgh
    I should have mentioned that I explored those as an option as well, but prefer the OEM switch better
    crashnburn80 likes this.
  4. Jan 26, 2017 at 9:46 PM
    rondog
    rondog Well-Known Member
    Ronnie
    Escondido/San Diego
    +1 for air on board switches. The lights are the air on board switches and a trac switch is oem. They are identical
  5. Jan 27, 2017 at 4:26 AM
    Hit n Run
    Hit n Run Well-Known Member
    14 Black DCLB Sport
  6. Jan 27, 2017 at 10:39 AM
    steveo27
    Pittsburgh
    Thanks for the input. I'm set on the oem switch as it'll do what I want the way I want.
    Thanks for the link to the harness. I've seen that while searching. It's a last resort option as it's much rather spend a few bucks on terminals and do the harness myself.
  7. Jan 27, 2017 at 11:58 AM
    Up2NoGood
    Up2NoGood Well-Known Member
    Jaimes
    BC, Canada
    2014 TRD Sport DCLB
    You are correct on the terminals being the same as the heated mirrors switches. I've picked up that exact switch, just haven't wired it up yet.
  8. Jan 27, 2017 at 1:59 PM
    steveo27
    Pittsburgh
    Awesome! I knew I could count on you :thumbsup:
