FJ beadlock, bronze. Different backspace? Can it fit a larger or wider tire?
Discussion in 'Wheels & Tires' started by deeezy, Sep 2, 2013.
  1. Sep 2, 2013 at 10:25 AM
    deeezy
    deeezy [OP] Well-Known Member
    Dana
    Hawaii
    2013 4x4 DC, 6 spd, TRD Sport
    ADS ext travel coilovers with clickers, Icon tubular UCA's Rear-Icon VS 10" RR, Allpro Expos, TRD cat-back, Hurst/Core short shift kit, etc...
    These FJ wheels stick out 3/4" approx over stock tacoma. Will I be able to fit a larger or wider tire because of this? Anyone?
  2. Sep 2, 2013 at 10:42 AM
    RelentlessFab
    RelentlessFab Tacoma offroad armor fabricating beast Vendor
    Eric
    Eastern side of the Sierras: Sparks, NV
    07 SR5 4x4> 03 SR5 4x4 total> 14 Crewmax TRD
    Had tons on the old Taco's.... new Tundra is pretty stock
    It would probably help with UCA clearance on 285's, but I dont have rear world experience with running them so I cant give an exact answer as to exactly what/if they can fit without rubbing. Typically its the backspace on the wheels that cause the factory tacoma 16's/17s to not fit 285s without rubbing, so if the FJ wheels have less backspace it should definitely help.
    But consider the future, if you want to start running anything wider than a 285 the wheels will likely again become too narrow and too much backspace.
  3. Sep 2, 2013 at 10:59 AM
    deeezy
    Dana
    Hawaii
    It's a little too late because I have already bought these. Lol. I'm trying to decide what tire size to buy with these wheels using a small lift of 1"-3/4" leveling up to a 3" lift. If these wheels allow for 285's with a leveling kit then that's what I will buy. Does anyone have a tacoma with these wheels that are running 285's? Or if you do have these wheels, what size tire are you running and with what lift?
  4. Sep 3, 2013 at 2:28 AM
    iJDub
    iJDub Well-Known Member
    I have these on 285/75/16 with a roughly 3.25" lift in the front. Fits awesome no rubbing - but rubbing is a YMMV deal.
  5. Sep 3, 2013 at 7:59 AM
    deeezy
    Dana
    Hawaii
    Thats the size tire I wanted to get. Can you post a picture and did you have to trim anything? What kind of lift do you have? Sorry for all the questions but I just want to get this right when I order my lift and tires.
