FJ coilovers on Tacoma?
Discussion in 'Suspension' started by toytaco11, Feb 13, 2012.
  1. Feb 13, 2012 at 2:39 PM
    toytaco11
    toytaco11 [OP] Well-Known Member
    Albuquerque
    11 TRD 4x4 lwb doublecab
    coming soon!
    I have been looking at lifts and have decided to do Coilovers since that's what I did with my Tundra and loved it. I'm going to go with Camburg or SAW's and I've been told a couple of times that I should go with the FJ SAW coilovers for my Tacoma instead because the FJ SAW coilovers are 14/700 and the Tacoma SAWS are 13/650. The longer FJ coilover means less compression for lift and a smoother ride. Has anyone done this? Thanks.
  2. Feb 13, 2012 at 2:44 PM
    chadderkdawg
    chadderkdawg Don't ask questions you don't want the answer to..
    Des Moines, Iowa
    09 FX4 F150
    I have fj coilovers on my taco, they are fantastic.
  3. Feb 13, 2012 at 2:47 PM
    BAMFTACO
    BAMFTACO Another day another beer
    Juan
    Woodlandland hills , CA
    2007 Tacoma AC Prerunner
    Kings bruh
    Don't what to thread jack but what's the difference between the two
  4. Feb 13, 2012 at 2:48 PM
    chadderkdawg
    Des Moines, Iowa
    09 FX4 F150
    See bolded text above
  5. Feb 13, 2012 at 2:49 PM
    jandrews
    '09 FourDubDee TRD OR
    I haven't researched, but apparently spring length and rate judging by the posts above.
  6. Feb 13, 2012 at 2:52 PM
    BAMFTACO
    Juan
    Kings bruh
    Oh gotcha
  7. Feb 16, 2012 at 9:49 AM
    txduckhunter
    txduckhunter Well-Known Member
    centex
    08 Tacoma DC LB SR5 4x4
    2.5" lift, ARE Shell, Ducks Unlimited Rubber Floor Mats. ROGUE badges,
    So if we just swapped stock taco coilovers for some FJ how much height would it actually gain?
    I'm just interested..
  8. Feb 16, 2012 at 9:50 AM
    Bishop2Queens6
    Bishop2Queens6 Well-Known Member
    SoCal
    2009 DCSB SR5 4x4
    Icon 2.5 RR/w CDCV 700# springs Front Shocks JBA UCA's Wheeler's Offroad Superbump Front Bump Stops Icon 2.5 RR/w CDCV 4"+ Rear Shocks AllPro Expo Rear Leaf Pack Timbren Rear Bump Stops ARB Front Bumper @Shmellmopwho Rock Sliders w/ Kickout RCI Aluminum Front Skid Plate Prinsu Roof Rack Roll-N-Lock Tonneau Cover CBI Ditch Light Brackets Cali-Raised LED Ditch Lights Cali-Raised Amber Fogs Cali-Raised Flush Mount LED Pods
    Should be around 1.5-1.75 inches without preloading. Max of 3 inches.
  9. Feb 16, 2012 at 9:50 AM
    chadderkdawg
    Des Moines, Iowa
    09 FX4 F150
    None, but the ride would most likely be softer.
  10. Feb 16, 2012 at 9:54 AM
    Caduceus
    Caduceus Well-Known Member
    in the Bluegrass
    09 DCSB TRD 4x4
    I don't know offhand, but this topic has been covered maybe a half-dozen times in the last few years. Try searching some of them?
  11. Feb 16, 2012 at 9:54 AM
    Bishop2Queens6
    SoCal
    2009 DCSB SR5 4x4
    Stock spring rate for the tacoma is around 550 lbs. You're throwing in a 700 lbs spring without preload; You're still gonna get some lift.
  12. Feb 16, 2012 at 10:14 AM
    txduckhunter
    centex
    Im using tapatalk. The search function sucks..
    I would just think if this was a legit way for 1.5-2" lift up front guys on a budget would be all over this as a way better alternative to buying spacers...
    I imagine one could surf the FJ site and get stock coilovers fairly easily and cheap if not free..
  13. Feb 22, 2012 at 6:12 PM
    txduckhunter
    centex
  14. Feb 22, 2012 at 7:25 PM
    chadderkdawg
    Des Moines, Iowa
    09 FX4 F150
    What are you bumping for?
  15. Feb 22, 2012 at 7:49 PM
    amain
    amain Well-Known Member
    Brian
    Anacortes, Washington USA
    07 SC TRD FJ - The Black Lemon
    Fender Cracks
    We were talking SAW's right? Budget? They cost 1k for a set. They are adjustable from 0 to 3" and the only difference between the two is coil wraps and rated weight. No need to run FJ coils unless you have added weight on your rig (Bumper, winch, skids ect.) You may cause more problems running them if you do not have any additional weight by over extending your travel upward and always topping them out. Then you might need limit straps. SAW makes a great product and I would use what is recommended for your truck. As for the stock coilovers on an FJ they are the exact same as the Tacoma - No different. I currently run OME but I will be upgrading to SAW soon.
  16. Feb 22, 2012 at 9:11 PM
    txduckhunter
    centex
    Oh ok. Gotcha, I was thinking it was initially talking about stock coil overs on an FJ.
    I thought they were the same as a Taco but then after reading and being confused thought they were longer or had more preload.
