fj cruiser an tacoma have the same engine right?
Discussion in 'Off-Topic Discussion' started by NWtacoma, Mar 16, 2010.
  1. Mar 16, 2010 at 6:57 PM
    NWtacoma
    NWtacoma [OP] Well-Known Member
    Kent,WA
    2011 TRD Sport 4x4
    265/70/17 bfg AT
    my friend has an fj and says he has to use premium fuel??? i thought the tacoma and the fj shared the same 4.0 V6. what am i missing here?
  2. Mar 16, 2010 at 7:00 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    Yeah same engine. Just one of those things as far as I can tell. If you use premium you can also expect the same HP numbers the FJ is boasting. And if i'm not mistaken which I have been known to do, he doesn't have to run premium.
  3. Mar 16, 2010 at 7:01 PM
    AzogSS
    AzogSS Well-Known Member
    Andy
    Soda City, SC
    2008 Tacoma / 2011 FJC
  4. Mar 16, 2010 at 7:04 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    For 2010 the engines in the Tacoma, FJ, and 4runner are the same. Says toyota. What year is your buddy's FJ?
  5. Mar 16, 2010 at 7:06 PM
    NWtacoma
    Kent,WA
    2011 TRD Sport 4x4
    265/70/17 bfg AT
    he has an 08
  6. Mar 16, 2010 at 7:08 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    "Toyota unveiled the FJ Cruiser for the 2007 model year, cashing in on the retro theme played out on other crossovers and SUVs — but underpinning it with real truck toughness. Built on the 4Runner architecture, with a shortened floorpan, the FJ Cruiser's standard (and only) engine is the same 4.0-liter aluminum-block V-6 with variable valve timing that's offered in the 4Runner, Tundra, and Tacoma. Here it makes 239 horsepower and 278 lb-ft of torque. The engine's mated to either a five-speed automatic transmission (again shared with the 4Runner) or a six-speed manual transmission exclusive to the FJ."
  7. Mar 16, 2010 at 7:16 PM
    walleyeguy
    walleyeguy Well-Known Member
    '12 4x4 DCSB TRD OR Auto MGM
    Incorrect. For 2010 the V6 engine in the FJ Cruiser and 4runner are the same. ...but different than the V6 in the Tacoma and Tundra. For 2010 Toyota added dual VVT-I to the 4.0 V6 in the FJ Cruiser and 4runner but not the Tacoma and Tundra.
    Same fuel for all though...regular unleaded.
  8. Mar 16, 2010 at 7:30 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    Right but the engines are the same. The FJ and 4Runners just have dual VVT-I. No physical change to the engine.
