FJ Cruiser Steelies Tire Size
Discussion in 'Wheels & Tires' started by gmata, May 6, 2013.
  1. May 6, 2013 at 3:45 PM
    gmata
    gmata [OP] Well-Known Member
    Gonzalo
    Delaware
    2007 DCB 4x4 TRD sport
    I have tried the search function with not the best of luck so i was hoping somebody from this section could help me.
    I have a 2007 Tacoma with a ProComp 3 inch lift currently I have 275/70/R18
    I want to get FJ cruiser Steelies I figured out they are 17 x 7.5 backspace 4.5"
    I want to know if I can fit 285/70/R17 tires on them or would they rub? If so 265's the biggest tire i can fit?
    I am going with Duratracs
    Thanks!
  2. May 6, 2013 at 9:47 PM
    SCSPerformance
    SCSPerformance Stealth Custom Series™ Vendor
    Vin
    Bay Area, CA
    2005 Tacoma
    Camburg LT kit DMZ SUA kit SCS wheels Destroyer Gray
    You should be able to fit a 285/70/17 tire on those FJ steelies without a problem. You might get away some only minor rubbing on the cab mount, but the only sure way to find out is to get them on there. For daily driving, you're good to go.
  3. May 6, 2013 at 9:50 PM
    gmata
    Gonzalo
    Delaware
    Thanks for the response man,
    I am going to try them tomorrow at Discount tire to see if they fit.
    However I want to be able to do some offroading as well with that setup since I am going to be taking the truck to Baja.
  4. May 6, 2013 at 10:03 PM
    SCSPerformance
    Vin
    Bay Area, CA
    2005 Tacoma
    You'll have good clearance on the suspension side so if anything a CMC mod will take care of any additional rubbing.
  5. May 7, 2013 at 9:59 AM
    gmata
    Gonzalo
    Delaware
    Turns out they don't fit, when I turn all the way they hit the Chassis behind the shock on the side edge of the tire.
    I was thinking maybe some spacers? I found this thread saying that people fit the size of tire i wanted with spidertrax.
    http://www.tacomaworld.com/forum/wheels-tires/1518-wheel-spacers.html
    But then i called wheelers where they sell them and they told me it would still rub.
    Any suggestion?
  6. May 7, 2013 at 10:54 AM
    SCSPerformance
    Vin
    Bay Area, CA
    2005 Tacoma
    When you say chassis behind the shock, what exactly are you referring to? The upper control arm or the frame?
    I actually used to have some FJ steelies myself on my 1st gen for a short period, but I never measured the BS on them. I just did a little research and it looks like the BS is actually 4.75" and not 4.50" like you listed. Mine rubbed a little on the frame at full lock, but it was minor.
    You should be able to add some spidertrax adapters to get extra clearance, but this might cause it to rub the cab mount area when you push the wheels out.
  7. May 7, 2013 at 11:28 AM
    gmata
    Gonzalo
    Delaware
    Pretty much right there on top of the LCA, below the white tag.
  8. May 7, 2013 at 11:49 AM
    gmata
    Gonzalo
    Delaware
  9. May 7, 2013 at 11:49 AM
    SCSPerformance
    Vin
    Bay Area, CA
    2005 Tacoma
    That's the typical area where it likes to rub on the frame. As I mention, you can either live with that or add the spidertrax and do the CMC mod so it doesn't rub there.
    Or you can go with the "pizza cutter" look with 255/80/17. The overall height is similar, but the tire is only ~10" wide instead of 11.5" wide.
  10. May 7, 2013 at 11:54 AM
    gmata
    Gonzalo
    Delaware
    Thanks just ordered a pair of 1.25 Spidertrax, hopefully that will fix the problem.
    I was looking at the CMS MOD but unless I am looking it wrong it looks like a different place where they cut the frame.
  11. May 7, 2013 at 11:58 AM
    SCSPerformance
    Vin
    Bay Area, CA
    2005 Tacoma
