fj t-case swap 05 4cyl 4x4 5speed
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 05taco2.7, Dec 29, 2012.
  1. Dec 29, 2012 at 8:36 AM
    05taco2.7
    05taco2.7 [OP] Well-Known Member
    JIMSTER
    omaha nebraska
    Soon to come
    probably a dumb question but ive looked everywhere and couldnt find a answer.
    will a fj t-case work with my 2.7 4x4 5speed?
    the way i figure the v6 tacoma a fj share the same drivetrain basically ( v6, same trans((6 speed or auto)) as well as similar t-case) so i dont think it will but i need some solid answers
    any help would be great thanks :D
  2. Dec 29, 2012 at 9:43 AM
    david2011sr5
    david2011sr5 Well-Known Member
    take a guess
    East Texas
    2011 SR5 4x4
    afe pro dry, weather tech floor liners,5100's on all four corners@ 0, eibach 620 coils. toytec 3/4" spacer driver/s & passenger/s, rear spring tsb w/toytec 1" blocks, 4runner sport wheels, in channel vent visors, 1.25 spidertrax wheel spacers on the front, Wet Okole's, smity tow hook.
    There are a few 4cyl guys that are running fj cases. Check out n0rth's build. He's got a bad 4cyl!
  3. Dec 29, 2012 at 4:32 PM
    05taco2.7
    JIMSTER
    omaha nebraska
    Soon to come
    thanks for the help :D
  4. Dec 29, 2012 at 7:01 PM
    david2011sr5
    take a guess
    East Texas
    2011 SR5 4x4
    No problem. From what I've read the case fits with minor modification. I plan on eventually swapping mine out for one.
  5. Dec 30, 2012 at 10:17 AM
    05taco2.7
    JIMSTER
    omaha nebraska
    Soon to come
    what kind of modification?
    ive been wanting to switch mine too, my case has been making sort of a howling noise, it sound like tire rumble most of the time but if you get it up on a lift and spin it up to 55mph it makes a horrible chatter, check u-joints, rear end, tires, all seems to be coming out the t-case so what better time than to drop in an fj case
