FJ transfer case swap work in a 2.7?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacoMitch93, Aug 22, 2014.
  1. Aug 22, 2014 at 6:37 AM
    TacomaJack09
    TacomaJack09 Well-Known Member
    Jackson
    Montana!
    06 Access Cab 4x4
    Billie 5100's, Ride Rite Airbags, Tech Deck
  2. Aug 22, 2014 at 6:42 AM
    ajohnson
    ajohnson Glamour Shot
    Andy
    Charlotte, NC
    07 DCLB TRD Sport Prerunner 4x4
    Things and stuff and such
  3. Aug 22, 2014 at 8:01 AM
    TacoMitch93
    TacoMitch93 [OP] Tasty Taco
    Mitch
    Nova Scotia, Canada eh
    09 Tacoma SR5
    I'm serious about gaining information! Probably wouldn't happen until the spring/summer if it was going to happen!
    That is a really badass truck though
  4. Aug 22, 2014 at 12:17 PM
    n0rth
    n0rth Well-Known Member
    J.W.
    New Mexico
    2019 Tundra Platinum
    2009 Tacoma Access Cab SR5, 4wd, 2.7L URD S/C, 4:88's ARB lockers, 36x9.8r16 Radial TSL
    The fj case will mate to the 5 speed without any changes, I added the crawl box after the fact. If you need more info you can check out my build or pm me. Wyatt at RST is the expert on these swaps.
    Taco47 likes this.
  5. Aug 22, 2014 at 5:47 PM
    tacoma4
    tacoma4 Well-Known Member
  6. Aug 23, 2014 at 6:23 AM
    TacoMitch93
    Mitch
    09 Tacoma SR5
    I don't think you can get it to work! not enough space.
    Thanks for posting the link! finally got to see what the twin sticks look like coming out of the floor haha
  7. Feb 11, 2015 at 6:04 PM
    awsumdc
    awsumdc Well-Known Member
    O.C. Cali
    SASED '05 Taco
    SAS, crawler box, 14" coilover shocks, 39.5 tires,dual batteries, and a bunch of other stuff
    OK came across this thread while looking for other information and wanted to clear somethings up for some guys.
    The transfer case out of the automatic transmission FJ Cruiser will work in the 2.7 5 speed 2nd gen and the 4.0 automatic 2nd gen. Both have the 23 spline input shaft.
    If you want to put the FJ Cruiser t case into your six speed Tacoma then you'll still get the t case from an automatic trans FJ and swap out the planetary gear sets and the large rings on the planetary gearsets to make it work. Your six speed t case has the larger 22 spline input that you'll need in your new FJ T case.
    YOU CANNOT USE THE TRANSFER CASE FROM THE SIX SPEED FJ CRUISER AS IT IS A FULL TIME CASE WITH A CENTER DIFF LOCK.
    Here are a couple of links to help you out and if you need more info you can register at RockSolidToys and ask all the questions you have running in your head. I'll be happy to answer them all if I can.
    http://www.rocksolidtoys.com/forum/showthread.php?t=60
    http://www.rocksolidtoys.com/forum/showthread.php?t=112
    http://www.rocksolidtoys.com/forum/showthread.php?t=35
    http://www.rocksolidtoys.com/forum/showthread.php?t=295
    http://www.rocksolidtoys.com/forum/showthread.php?t=725
    Yes, I know. It's more than a couple of links but I wanted to get you guys as much info as I could.
    If you have any questions please ask over on RST as I'm rarely here. I just don't have enough time in the day to monitor all this stuff.
  8. Feb 11, 2015 at 8:50 PM
    TacoMitch93
    Mitch
    09 Tacoma SR5
    Thanks for all the info! That's awesome!
    The tcase swap is on the to-do list with my truck!
  9. Jan 4, 2018 at 2:58 PM
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    So does this mean that the 2.7L 5spd and the 4.0L (with automatic trans) are the same and thus interchangeable?
  10. Jan 4, 2018 at 3:48 PM
    buyobuyo
    buyobuyo Read The Fucking Manual
    Jeremy
    Camden, AR
    08 PreRunner SR5, I4, Manual, Silver
    A thing or two...
    :facepalm: Not even remotely.
  11. Jan 4, 2018 at 3:48 PM
    TireFire
    Olympic Peninsula
    You always this friendly? Can u just answer?
  12. Jan 4, 2018 at 3:54 PM
    buyobuyo
    Jeremy
    Camden, AR
    A thing or two...
    What all this means is that the 5 speed and v6 auto have the same interface between the transmission and transfer case, so the transfer cases swap. The front ends where the transmissions bolt to the engine are different, and the transmissions don't swap.
  13. Jan 4, 2018 at 3:57 PM
    TireFire
    Olympic Peninsula
    Thank you, that's what I figured. I'm not looking to swap the transmission. Just the transfer case. I have a V6 auto and the tcase is on its way out. I can locally get another case from a 2.7 for cheap but wanted to make sure it bolts up before pulling the trigger
