Flashed transmission
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Lifted blue limo, Dec 22, 2019.
  1. Dec 22, 2019 at 6:43 PM
    Lifted blue limo
    Lifted blue limo [OP] My other car is a Hyundai
    Devin
    Oregon
    13’ nautical DLCB turd sport
    6” RC lift, 35” Ironman mts, 17” pro comp III’s
    Anyone heard of flashing their transmissions computer to receive different shift points?
    have experience doing it? just curious if it’s true and if it works.
  2. Dec 22, 2019 at 6:47 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Yes. It's a doable thing and has been being done for quite some time as of this year. Hit up @nd4spdbh and he can whip up something for you.
    The only caveat is that you will need HPTuners in order to be able to change your tranny tune. So you will have to buy a MPVI2 module and a laptop as well to be able to do all of this.
  3. Dec 23, 2019 at 3:38 AM
    topcathr
    topcathr Well-Known Member
    2015 limited
    When I bought my DCSB Sport the transmission was shifting way to soon, took it in under warranty and they re flashed it. No problems since that.
  4. Dec 23, 2019 at 9:13 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    this, the only way you can really change anything with the trans is with some HPTuner love.
  5. Dec 23, 2019 at 9:19 AM
    seedy_tea
    seedy_tea Well-Known Member
    chris
    Cape Cod
    2009 TRD-OR DC
    @12TRDTacoma and it sooooo worth it. with ND4's trans changes along with JustDSM's engine tune, its like driving a new truck.
  6. Dec 23, 2019 at 11:53 AM
    PzTank
    PzTank Stuck in the Well
    Above the Notches
    ‘15 AC SR5 4X4 4.0 Auto
    ‘07 OR leather shift knob
    I never had an auto transmission lug before- I’m doing 30 on a flat road and it wants to be in overdrive...
    @nd4spdbh , will your tune correct this?
    Thanks!
    Lifted blue limo[OP] likes this.
  7. Dec 23, 2019 at 3:33 PM
    nd4spdbh
    SoCal
    The trans can be tuned to just about however you want it! My trans tune has raised just about every shift point and adjusted torque converter lockup etc.
  8. Dec 23, 2019 at 8:36 PM
    Tylerh147
    Tylerh147 Well-Known Member
    Tyler
    Chattanooga, Tennessee
    2007 DCSB TRD OR 4x4
    5100s, 885s, Icon AAL
    What must one do to get his hands on such tune :D
  9. Dec 24, 2019 at 12:58 AM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    The stock trans shifts into 5th and locks the converter whenever you are not accelerating so at 30 yes it will so your mpg will be better. As soon as you depress the throttle it downshifts and goes. Program works well unless you want to hold higher rpm shift points then get the tune, but for most of us a waste. When I'm going 30 and floor it trans downshifts instantly and off I go. You can manually control with the shift selector of course. The Gen 3 Tacoma has an ECT mode button to hold higher shift points (basically a second program) which on a test drive only made it feel like a Gen 2.
  10. Dec 24, 2019 at 3:55 AM
    PzTank
    Above the Notches
    That’s all well and good but it lugs the engine.
    Others might not care but it bugs the hell out of me.
  11. Dec 24, 2019 at 8:17 AM
    nd4spdbh
    SoCal
    pretty much.
    Assuming v6 5 speed auto:
    Stock shift curves allow the trans to shift from 4th to 5th at 1300 rpms of the rear driveshaft (~31.5mph) at 0-7% accelerator pedal and will apply the torque converter lockup clutch at 1600rpms in 5th gear at 0-12% accelerator pedal (~39mph). Once you are in 5th lockup you can slow down if you stay at low accelerator pedal inputs, till slower than those speeds.
    There is also some areas at very low throttle inputs below the 4th and 5th torque converter apply curves called "flex lockup" (including 3rd according to white papers) where the torque converter will partially apply for mpg reasons.
    Also the later model 2nd gens had a less linear throttle pedal curve which will make them feel like they are lugging more even though you are pushing on the accelerator pedal more n more.
    Anyways, all of this can be tuned and tweaked with hptuners, I am currently on my 12th public revision of my transmission tune which raises all shift points, plays with some downshift points, really changes how the lockup clutch holds, all to make drive ability much better without making a hit on mpgs.
    Start reading - its all here !
    https://www.tacomaworld.com/threads/hp-tuners-for-2005-2015.600793/
    gearcruncher, DVexile and PzTank like this.
  12. Dec 24, 2019 at 8:34 AM
    PzTank
    Above the Notches
    I appreciate the info.
    Got to say nothings easy anymore.
    Do you have a Readers Digest post of simplified information or do I have to read through 266 pages?
  13. Dec 24, 2019 at 10:54 AM
    nd4spdbh
    SoCal
    Haha yeah, i was lucky enough to start in that thread early on and have kept up with it. Id suggest posting in the thread your questions and we can answer them there. Maybe skim though a bit beforehand.
    Skyway and PzTank[QUOTED] like this.
  14. Dec 25, 2019 at 6:46 AM
    Monkeybutt2000
    Monkeybutt2000 Well-Known Member
    This is why I drive mostly with the truck in 4th gear.
    PzTank[QUOTED] likes this.
  15. Dec 25, 2019 at 12:30 PM
    PzTank
    Above the Notches
    Me too but sometimes I have to drop it to 3rd to avoid lugging...
  16. Dec 26, 2019 at 1:11 AM
    DVexile
    DVexile Exiled to the East
    Ken
    2015 DCSB V6 TRD OR 4X4
    Maybe nitpicking on terminology but it is nearly impossible to actually lug an AT. The AT shift points and throttle curves can certainly make it feel like you are at too low an RPM but the engine isn’t actually lugging.
  17. Dec 26, 2019 at 4:57 AM
    PzTank
    Above the Notches
    What do I call that bogged down lag when I’m doing 30 mph and step on the gas while the engine’s under 800 rpms?
  18. Dec 26, 2019 at 7:17 AM
    seedy_tea
    chris
    Cape Cod
    2009 TRD-OR DC
    i slugged thru all 266 pages, and it was well worth it. i skipped all of the supercharger talk, as that didnt apply to me, so its really much less than 266 pages. I purchased around page 180 or so. but my truck did the lugg in 5th lockup at low rpms (38-40mph). this was the main reason i purchased, to adjust the TCC unlock values. truck drives so much better with the engine tune and ND4's v12 trans tune, it was well worth the purchase.
