Flashing Check Engine Light help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Garrett93, Nov 8, 2017.
  1. Nov 8, 2017 at 7:50 AM
    Garrett93
    Garrett93 [OP] Well-Known Member
    Garrett
    San Diego, CA
    2006 Tacoma: Overland Build
    2006 Toyota Tacoma TRD OR
    220k miles
    Issue:
    Truck has been a little shaky (weird/high idle) on startup this past week. Went to start it today and got the flashing CEL. Went out and came back and fired it back up and the truck fired right up and idled fine (with no CEL).
    Inspection:
    Went to Advance 2nd time and pulled PO306 (cylinder 6 misfire). I had this same code back in July and was fixed with new spark plugs. Also had
    Should I be expecting a fuel injector or spark plug wire/coil?
  2. Nov 8, 2017 at 7:54 AM
    Clearwater Bill
    Clearwater Bill Sometimes when I close my eyes, I can't see.
    Billy
    Largo Florida
    '13 5 lug base AC w/convenience package
    You still have to get the code read to start a diagnosis.
    Code readers are inexpensive and can be multifunctional these days. @220k miles it's a worthwhile tool to own.
    ScanGuage II, Ultra Gauge, Torque app.; any would be a decent choice.
    TacoCat likes this.
  3. Nov 8, 2017 at 7:59 AM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Or a regular OBD2 reader.
    $20 or less on Amazon.
  4. Nov 8, 2017 at 8:03 AM
    Garrett93
    Garrett
    San Diego, CA
    Yeah I realize that. I have an Amazon one that won't read the Tacoma for some reason. I'll grab a Scangauge or UltraGauge today. There is no CEL anymore... what could have triggered it and what are the odds that it comes back? The last thing I want is to start the truck up for work and it do that again...
  5. Nov 8, 2017 at 8:07 AM
    T4RFTMFW
    If something is wrong, it’ll come back.
    Any decent reader will show you pending codes, not just current.
    I’d just try another parts store. It’s Wednesday morning, can’t imagine any are closed.
  6. Nov 8, 2017 at 8:18 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+295k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED), 2006 F350 King Ranch 6.0L
    Flashing CEL is universal for misfiring. I would inspect the coils, wires, and plugs first. I had that issue years ago (before CELs) in a 93 Toyota pick-up. Same symptoms as you describe and it was a bad wire.
    T4RFTMFW likes this.
  7. Nov 8, 2017 at 8:21 AM
    MainerDave19995VZ
    MainerDave19995VZ Well-Known Member
    David
    Maine
    1999 Tacoma Extra Cab SR5 TRD 5 Speed 5VZFE
    2nd generation 16" wheels with 1.25" BORA spacers
    In my first gen V6 I had rough running for a few tanks of gas and then when pushing up to 3500 rpm (which I don't do that much) I got the check engine light. The code was for lean running. I ran Lucas Deep Fuel System Cleaner in the next tank and it's been running like a top since. Might be a good place to start?
  8. Nov 8, 2017 at 8:22 AM
    Garrett93
    Garrett
    San Diego, CA
    Yeah code is PO306 for a cylinder 6 misfire. Had this same code back in July and put new plugs and it fixed it.
  9. Nov 8, 2017 at 8:50 AM
    TacomaZL
    TacomaZL Well-Known Member
    Illinois
    2013 Toyota Tacoma 2.7L
    WeatherTech Floor Mats; 15" Cragar Black "D" Window Wheels; Custom Center Caps; 235/75/R15 Goodyear Radial Wranglers; "TOYOTA" Tailgate Decal; Magnetic Tool Storage (in Cabin); Stant Locking Gas Cap; Salex Glove box Organizer Debadged; BHLM; Aftermarket Fog lights; FlashWolves 1000 Lumen Reverse lights; DEPO Black LED Tail lights; Differential Extended Breather Mod; FalconZero F170HD+ Dashcam; Scosche MagicMount; Tyger Auto Tri-Fold Pickup Tonneau Cover;
    If you replaced the spark plugs that recent then you might need to replace a coil pack.
  10. Nov 8, 2017 at 8:55 AM
    jc11taco89
    jc11taco89 Well-Known Member
    jon
    Naugatuck CT
    2011 Tacoma aclb 4wd
    3 inch toytec 5100 SPC uca's Pelfreybilt front plate bumper with center hoop Pelfreybilt rear plate bumper with swing out B.A.M.F. sliders with kick out Mobtown ifs and trans skid. 33's with rims that are to large.
    There's no wires it's direct coil on plug. I used to work for Autozone you can go to any of there stores they all have OBD2 readrrs.
  11. Nov 8, 2017 at 8:55 AM
    Garrett93
    Garrett
    San Diego, CA
    When you say coil pack do you mean an ignition coil?
  12. Nov 8, 2017 at 8:57 AM
    Garrett93
    Garrett
    San Diego, CA
    Already went back (they were closed early this morning). Code was PO306 (cylinder 6 misfire).
  13. Nov 8, 2017 at 8:58 AM
    TacomaZL
    Illinois
    This thing:
  14. Nov 8, 2017 at 9:05 AM
    jc11taco89
    jon
    Naugatuck CT
    Yessir that is a coil pack
    TacomaZL likes this.
  15. Nov 8, 2017 at 9:07 AM
    Garrett93
    Garrett
    San Diego, CA
    Thank you!
    Good to know. On RockAuto it calls that an Ignition Coil.
  16. Nov 8, 2017 at 9:07 AM
    jc11taco89
    jon
    Naugatuck CT
    Same thing different words
    kidthatsirish and TacomaZL like this.
  17. Nov 8, 2017 at 9:09 AM
    Garrett93
    Garrett
    San Diego, CA
    Learn something new each day, thanks!
    jc11taco89 likes this.
  18. Nov 8, 2017 at 9:11 AM
    TacomaZL
    Illinois
    If you are short on cash (I'm not saying you are, but I sure as hell have been lol) you can swap the cylinder 6 coil pack with a nearby cylinder and see if the code changes to a misfire at that new cylinder...this is a sure fire way to tell if a coil pack is faulty or not.
    Or just replace it outright. That's never a bad idea. Just a trick I learned and felt like sharing.
  19. Nov 8, 2017 at 9:15 AM
    jc11taco89
    jon
    Naugatuck CT
    Yea exactly what he said this is best way to figure out if that coil is bad.
  20. Nov 8, 2017 at 9:19 AM
    Garrett93
    Garrett
    San Diego, CA
    Great idea. I'll wait until my Ultragauge gets here and swap them out. Hoping that's the case and just an easy fix. Would hate for it to be something more serious... Do the injectors ever cause issues? I haven't seen too many threads on them.
