Flashing the ECU
Discussion in 'Performance and Tuning' started by caglezxj, Aug 14, 2007.
  1. Aug 14, 2007 at 5:55 AM
    caglezxj
    caglezxj [OP] Well-Known Member
    I talked with a guy last night. Very experienced with the toyota v6 and V8 . He said that I could have the ecu flashed and achieve the same thing or even better than the urd device. He said he could change the fuel/ air mixture and anything else I need. He also said some of the dealerships should be able to do this. If I have him do it, I will have to remove th ECU from the truck, and don't know how hard it is to get to it. Has anyone removed there ecu? This is for a 07 Tacoma
  2. Aug 14, 2007 at 7:14 AM
    4x4Taco
    4x4Taco Well-Known Member
    Ontario
    07 TRD Off-Road 4X4
    Just remember if you get aggressive with the timing in the V6 or A/F ratio you will need to use 92 or 94 octane always as the motor is 10:1 comp.
  3. Aug 14, 2007 at 8:06 AM
    nd
    nd Radical Town. It's a hell of a place!
    Nate
    Greenville, SC
    07 TRD Off-Road 4x4 debadged
    De badged, 5100's, Black Toyota Baja wheels
    yeah, with as high as our compression ration is, i am not planning on messing with my mixtures. If i do, i'm gonna make sure i pay someone who knows what they're doing to do it. I'd be careful if i were you
  4. Aug 14, 2007 at 8:43 AM
    007Tacoma
    007Tacoma I dub thee malicious!
    Mark
    San Antonio, TX
    2015 4Runner Trail Edition Premium
    Cloaking Device
    Reflashing the ECU with what? - A new set of A/F ratios? Where are they getting the ratio table from? :confused:
  5. Aug 14, 2007 at 6:21 PM
    caglezxj
    Well I work for Toyota Motor Manufacturing people, ANd it would be a QC guy that does all the dino test. We build the 4.0 V6 and the 5.7 Tundra Engine. I believe he knows what he is doing.
  6. Aug 14, 2007 at 6:23 PM
    caglezxj
    Once the flash is done then my ecu will be ran on a new 4.0 engine to make sure it is set right, and runs correctly at different RPM's
  7. Aug 14, 2007 at 6:24 PM
    caglezxj
    However I probably have said to much. And will let everyone know how it works afterwards.
  8. Aug 14, 2007 at 7:12 PM
    Spyder327
    Spyder327 Well-Known Member
    Phoenix, AZ
    2005 X-Runner
    Aquamist 2D meth/water injection kit, URD Exhaust, DT Long Tube Headers, Hood Struts, and lots of other miscellaneous stuff...
    hmmm... good luck with that, sounds pretty odd to me though. As soon as you make changes to intake, exhaust, etc. you'll likely have to keep "reflashing" to achieve correct settings again. Although i dont know how they're accomplishing it in the first place.
  9. Aug 16, 2007 at 6:32 AM
    4x4Taco
    Ontario
    07 TRD Off-Road 4X4
    The only way to do it properly would be with the truck (yours) on a chassis dyno using a wideband oxygen sensor and dial the A/F ratio in that way. That is what I had to do for my mustang. And you would be amazed at two identical vehicles on the dyno how much they can differ in A/F ratio and even HP produced. That’s why the manufactures leave such a large safety margin. (rich fuel mixtures)....Yes there is HP to be had but...you will pay a price if not done right.
  10. Aug 16, 2007 at 12:31 PM
    Spyder327
    Phoenix, AZ
    2005 X-Runner
    That is very correct. Thus why there is a wideband installed in my truck permanently :)
  11. Aug 16, 2007 at 1:56 PM
    maverick491
    maverick491 Towing Guru
    South Jersey
    07 4x4 Access Cab, TRD off road, 6 cyl, 6 spd
    Activator III brake controller, Extang Fulltilt toneau, Factory bed mat, Extra D-rings in the bed, 2ndary air filter removed, Garmin Ique GPS, Eco-2, AFE Pro Dry-s filter, USASPEC PA12-toy, Pioneer 3-way speakers, SG II on Blendmount, Gulf States Alarm added.
    Spyder,
    Sorry I need to pick you brain again after your last statement. Would I realistically need to permanantly install the wideband in my truck to prevent damage? Or would a once and done be safe? Assuming of course that the once and done was completed after all the engine and exhaust mods were finished, and provided that I ran the same gas all the time? Last question, (atleast this time) I live and drive primarily, and would tune in South Jersey (near sea level). I would not risk damage to the engine if I drove up to the mountins for the weekend? Correct me if I am wrong, but if I tuned at sea level in winter and drove up to the mountains in summer the thinner, warmer air would just take me back to a running rich scenario?
    Thanks again
  12. Aug 16, 2007 at 2:33 PM
    Spyder327
    Phoenix, AZ
    2005 X-Runner
    nah you don't have a huge need for a permanent wideband. The reason i have one is because i have URD's Supercharger kit. A good tune should pretty much stay at that same AFR for you and you wont have to worry. Of course, like you said, you'd want to do it after all your mods are completed, because each mod can throw around the AFR a bit.
    As far as altitude, what i would recommend you do is tune it at the area your at (obviously). I'd say if you're going to change altitudes big time, you can just put back the stock fuel map and us that for your trip and then just put back on your tuned map when you return.
  13. Aug 16, 2007 at 5:40 PM
    maverick491
    South Jersey
    That makes perfect sense. I hadn't even considered just reverting to stock for ski trips and such. It is so simple and makes so much sense I feel stupid now.
    Thanks again Spyder. I am sure I will come up with more questions still before I pull the trigger on this completely, but I am tapped out of questions for now. I do owe you a beer or two though should we ever find ourselves in the same location.
    Thanks again
  14. Aug 16, 2007 at 5:55 PM
    Spyder327
    Phoenix, AZ
    2005 X-Runner
    Deal!
    Just let me know if you have any more questions ;)
  15. Jul 18, 2008 at 5:41 AM
    Philby
    Philby Active Member
    Cairns Australia
    Hilux SR5 4x4 TRD S/C
    Heh caglezxj, would be interested in yr friends reflashing program as I'm keen to fit the TRD Supercharger but TRD Australia is a closed shop in letting out tech specs.
    Phil.
  16. Jul 18, 2008 at 4:37 PM
    NHinAK
    NHinAK Active Member
    Anchorage
    08 Tundra TRD
    -Debadged
    How much power do you figure your going to "unlock"? Not much I would imagine. Why not just get a TRD CAI and be done with it? Your likely to gain just as much with the CAI as this "reflash".
  17. Sep 4, 2008 at 6:34 PM
    m3dragon
    m3dragon Well-Known Member
    Sacramento
    Old thread but we need to get enough people on the tacoma threads to have a tuner like powerchips make a ECu flash that tunes the ECU for most peoples cars. They do offer extra tunes for those who run more parts like headers and pullies ECT.
